Hi, I would like to allocate a large contiguous section of physical memory in the device tree. I want to reserve 2+ GiB. It could be a couple of contiguous blocks to add up to 2+ GiB as well.
Currently I am editing the file tegra186-quill-p3310-1000-a00-00-base.dts in the kernel sources and re compiling the device tree. I have successfully reserved 1.25 GiB with the following entry.
memory@80000000 {
device_type = "memory";
reg = <0x0 0x80000000 0x0 0x70000000>;
/* reserved memory */
reserved-memory {
#address-cells = <2>;
#size-cells = <2>;
ranges;
reserved_c2h_50000000: c2h_50000000@0xa0000000{
reg = <0x0 0xa0000000 0x0 0x50000000>; // 1.25 GiB
When I allocate more space in the memory@80000000 it seems to run into some problems. Can someone help me understand which physical addresses I can reserve to get 2 or more GiB of reserved space?
thank you.
