@bcao
I Have been experimenting with removing an object from a stream if it is within an ROI using nvdsAnalytics via a pad probe on the src pad of nvdsanalytics element using “pyds.nvds_remove_obj_meta_from_frame(frame_meta, obj)”
So far it works as expected and the object and bounding box dont appear on the OSD, but the tracker still has information about the removed object.
To access the tracker meta I use the pad on the tiler, I assume it has to do with the past frame meta.
How can I remove the tracker meta when I remove the object in my analytics callback
batch_tracker_decoded = {}
user_meta_list = batch_meta.batch_user_meta_list
while user_meta_list is not None:
user_meta = pyds.NvDsUserMeta.cast(user_meta_list.data)
if user_meta.base_meta.meta_type != pyds.NvDsMetaType.NVDS_TRACKER_PAST_FRAME_META:
continue
past_frame_object_batch = pyds_tracker_meta.NvDsPastFrameObjBatch_cast(user_meta.user_meta_data)
for past_frame_object_stream in pyds_tracker_meta.NvDsPastFrameObjBatch_list(past_frame_object_batch):
streamId = past_frame_object_stream.streamID
print(' past_frame_object_stream:', past_frame_object_stream)
print(' streamID:', past_frame_object_stream.streamID)
print(' surfaceStreamID:', past_frame_object_stream.surfaceStreamID)
for past_frame_object_list in pyds_tracker_meta.NvDsPastFrameObjStream_list(past_frame_object_stream):
print(' past_frame_object_list:', past_frame_object_list)
print(' numObj:', past_frame_object_list.numObj)
print(' uniqueId:', past_frame_object_list.uniqueId)
print(' classId:', past_frame_object_list.classId)
print(' objLabel:', past_frame_object_list.objLabel)
for past_frame_object in pyds_tracker_meta.NvDsPastFrameObjList_list(past_frame_object_list):
print(' past_frame_object:', past_frame_object)
print(' frameNum:', past_frame_object.frameNum)
print(' tBbox.left:', past_frame_object.tBbox.left)
print(' tBbox.width:', past_frame_object.tBbox.width)
print(' tBbox.top:', past_frame_object.tBbox.top)
print(' tBbox.right:', past_frame_object.tBbox.height)
print(' confidence:', past_frame_object.confidence)
print(' age:', past_frame_object.age)
try:
user_meta_list = user_meta_list.next
except StopIteration:
break
