Hi:
In OEM product design guide,the part of powering sequence(figure 3 & figure 4) shows that CARRIER_PWR_ON is active(high) before RESET_OUT# goes high(inactive). However, the table 88(Module Pins Pulled High on the Module Prior to CARRIER_PWR_ON Active) shows that RESET_OUT# is inactive(high) before CARRIER_PWR_ON active(high). It makes me confused, so which part could be accepted?
Thank you!
Hi, Table 88 only indicates the power-on default status, for power sequence please refer to figure 3 and 4.
