• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 5.1
• TensorRT Version
• NVIDIA GPU Driver Version (valid for GPU only) 440.33.01
• Issue Type( questions, new requirements, bugs) question
I was running an application with deepstream-5.1, it was working on a server from a container, however, when I pullled the docker image on another server and launched the container on that server, running the application got below error, which didn’t appear on the first server.
Unable to set device in gst_nvstreammux_change_state
0:00:00.097936700 1413 0x59800f0 WARN bin gstbin.c:2832:reset_state: Failed to switch back down to NULL
2022-06-01 23:55:27,468 - set pipeline state to be PLAYING
It turned out pipeline.set_state(Gst.State.NULL) was not executed successfully as the debugging information “set pipeline state to be NULL” was not seen.
pipeline.set_state(Gst.State.PLAYING)
logger.info(f"set pipeline state to be PLAYING")
try:
loop.run()
except:
pass
logger.info(f"set pipeline state to be NULL")
