I wan to know what is the address of reset status register of Tx2,i have to read it in uboot to know the reason of boot,like reboot/shudown/watchdog.
any help will be appreciated.
We have pmic reset value in kernel. But does not have this function in uboot.
If you can read i2c data in uboot.
i2ctransfer -f -y 4 w1@0x3c register-offset r bytes to read
For the given setting it should be
i2ctransfer -f -y 4 w1@0x3c 0x04 r1 #reads 1Byte from 0x3c at register offset 0x04
we dont need function only i need address.
#define RESET_STATUS_REG 0x7000e5b4
#define RESET_STATUS_LEN 0x40
In TX1: i used to read the status of reset status bit
addr = RESET_STATUS_REG;
length = RESET_STATUS_LEN;
buf = map_sysmem(addr, length);
if(buf == NULL){
printf("failed to address point buffer into RAM\n");
return -EINVAL;
value = *(uint64_t * )buf & 0xf;
unmap_sysmem(buf);
like this we were reading in Tx1,so can you tell that is possible in Tx2 or not,i want to know the address in Tx2
How did you get this address on TX1?
