Reset video capture for nvv4l2camerasrc
I am working on a GStreamer-based application where the video source can be unreliable in certain scenarios, causing the video signal to be lost and then restored after some time. To handle this, I set the pipeline to NULL on EOS and then back to PLAYING when the video signal is restored.
This approach works fine with v4l2src as the source element. However, when using NVIDIA’s hardware-accelerated GStreamer plugins, such as in the following pipeline:
nvv4l2camerasrc device=/dev/video0 ! video/x-raw(memory:NVMM),format=UYVY ! nvvidconv ! nvv4l2h264enc ! rtph264pay ! udpsink host=<host> port=<port>
the video capture does not recover properly after being set to NULL and back to PLAYING. Additionally, I can not see any related errors to the capture channel in dmesg.
Is there a recommended way to safely restart video capture with nvv4l2camerasrc within the same pipeline context?
Thanks in advance!
To address the issue of safely restarting video capture with NVIDIA’s hardware-accelerated GStreamer plugins, such as nvarguscamerasrc, after the video signal has been lost and then restored, it’s essential to understand the nuances of handling EOS (End Of Stream) and the specifics of the nvarguscamerasrc element.
Understanding the Issue
The approach of setting the pipeline to EOS (End Of Stream) and then back to playing when the video signal is restored works fine with software-based source elements. However, when using hardware-accelerated plugins like nvarguscamerasrc, the video capture does not recover properly after being set to EOS and back to playing. This indicates a potential issue with how the hardware-accelerated elements handle the EOS state and subsequent recovery.
Recommended Approach
  1. Handling EOS with nvarguscamerasrc: When using nvarguscamerasrc, it’s crucial to ensure that the pipeline is properly cleaned up before attempting to restart it. This might involve explicitly setting the pipeline to NULL state before restarting, to ensure all resources are released.
  2. Using queue Element: Inserting a queue element before the sink can help in managing the buffer and handling the EOS state more gracefully. The queue element can provide a buffer to absorb any bursts of data and can help in handling the situation when the video signal is lost and then restored.
  3. Setting processing-deadline Property: For live pipelines, setting the processing-deadline property to 0 can help in ensuring that the pipeline recovers quickly from an EOS state. This property is particularly useful when using elements like nv3dsink, as it configures a processing deadline for the sink, allowing for more timely recovery.
  4. Monitoring and Error Handling: Even though you mentioned not seeing related errors in dmesg, it’s essential to implement robust error handling within your application. This includes monitoring the pipeline’s state and any error messages that might be emitted by the elements, especially when transitioning between states.
  5. Pipeline Construction and State Management: Ensure that the pipeline is constructed and managed properly, taking into account the specific requirements of the hardware-accelerated elements. This might involve custom handling for the EOS signal, potentially resetting the source element or the entire pipeline under certain conditions.
Comparison with Other Elements
  • Software-based Source Elements: These elements typically handle EOS and state transitions more straightforwardly, as they do not rely on hardware acceleration and thus do not have the same constraints as hardware-accelerated elements like nvarguscamerasrc.
  • Other Hardware-accelerated Elements: The behavior of other hardware-accelerated elements may vary. Some might handle EOS and recovery similarly to nvarguscamerasrc, while others might have different requirements or behaviors. It’s essential to consult the documentation for each specific element.
Example Pipeline
To illustrate the recommended approach, consider the following example pipeline that incorporates a queue element and sets the processing-deadline property:
gst-launch-1.0 nvarguscamerasrc ! "video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1" ! queue ! nv3dsink processing-deadline=0
This pipeline uses nvarguscamerasrc as the source, includes a queue for buffering, and sets the processing-deadline to 0 for the nv3dsink to ensure timely processing and recovery from EOS.
Conclusion
Safely restarting video capture with NVIDIA’s hardware-accelerated GStreamer plugins requires careful handling of the EOS state and pipeline management. By understanding the specific requirements of these elements, implementing robust error handling, and utilizing elements like queue to manage buffers, developers can create more resilient pipelines that recover properly from video signal loss and restoration. Always refer to the latest documentation for the specific GStreamer version and plugins being used, as behaviors and best practices may evolve.
Unfortunately, the LLM answer does not resolve the problem. As described, I have added queue elements and my capture card does not work with nvarguscamerasrc, so I have to rely on nvv4l2camerasrc.
For further debugging, I have checked v4l2-ctl --list-buffers and can see that the timestamps do not refresh, but still it seems like it somehow tries to actively grab the video, since dmesg is logging starting stream when restarting the gstreamer pipeline. As a result, gstreamer clock is not counting on the receving side.
Only workaround here is to terminate gstreamer application, but I can not reset video capture within the same application.
hello proton067,
let me have confirmation,
did you meant you had unstable camera stream, and you would like to have application to have error handling, such as auto-restart?
Yes. My video capture card is an HDMI-to-CSI bridge, and the video source is a PC connected via HDMI. I want the application to be able to safely recover the video stream when the PC wakes up from sleep.
For v4l2src I can simply restart the gstreamer pipeline by setting it to NULL and then to PLAYING. But if I use nvv4l2camerasrc as a source element instead, this does not suffice anymore and I would have to have to restart the whole application.
You are right. This is not handled in nvv4l2camerasrc. The plugin is open source and you can check the source code and customize it to handle the state transition. Please download source code from the link:
Jetson Linux Release 36.4.4 | NVIDIA Developer
Driver Package (BSP) Sources
Alright. Thanks for your help!
