i am trying to train on Pascal Voc dataset, i prepared the dataset i.e., converted it to kitti format.
generated all necessary spec_files after resolving some common errors the training started successfully.
Later this UnknowError occured i am bit confused now.
File "/usr/local/bin/tlt-train-g1", line 10, in <module>
sys.exit(main())
File "./common/magnet_train.py", line 37, in main
File "</usr/local/lib/python2.7/dist-packages/decorator.pyc:decorator-gen-2>", line 2, in main
File "./detectnet_v2/utilities/timer.py", line 46, in wrapped_fn
File "./detectnet_v2/scripts/train.py", line 632, in main
File "./detectnet_v2/scripts/train.py", line 556, in run_experiment
File "./detectnet_v2/scripts/train.py", line 490, in train_gridbox
File "./detectnet_v2/scripts/train.py", line 136, in run_training_loop
File "/usr/local/lib/python2.7/dist-packages/tensorflow/python/training/monitored_session.py", line 676, in run
run_metadata=run_metadata)
File "/usr/local/lib/python2.7/dist-packages/tensorflow/python/training/monitored_session.py", line 1270, in run
raise six.reraise(*original_exc_info)
File "/usr/local/lib/python2.7/dist-packages/tensorflow/python/training/monitored_session.py", line 1255, in run
return self._sess.run(*args, **kwargs)
File "/usr/local/lib/python2.7/dist-packages/tensorflow/python/training/monitored_session.py", line 1327, in run
File "/usr/local/lib/python2.7/dist-packages/tensorflow/python/training/monitored_session.py", line 1091, in run
File "/usr/local/lib/python2.7/dist-packages/tensorflow/python/client/session.py", line 929, in run
run_metadata_ptr)
File "/usr/local/lib/python2.7/dist-packages/tensorflow/python/client/session.py", line 1152, in _run
feed_dict_tensor, options, run_metadata)
File "/usr/local/lib/python2.7/dist-packages/tensorflow/python/client/session.py", line 1328, in _do_run
run_metadata)
File "/usr/local/lib/python2.7/dist-packages/tensorflow/python/client/session.py", line 1348, in _do_call
raise type(e)(node_def, op, message)
tensorflow.python.framework.errors_impl.UnknownError: Horovod has been shut down. This was caused by an exception on one of the ranks or an attempt to allreduce, allgather or broadcast a tensor after one of the ranks finished execution. If the shutdown was caused by an exception, you should see the exception in the log before the first shutdown message.
[[node DistributedAdamOptimizer_Allreduce/HorovodAllreduce_gradients_resnet18_nopool_bn_detectnet_v2_bn_conv1_FusedBatchNorm_grad_tuple_control_dependency_2_0 (defined at <string>:78) ]]
[[node DistributedAdamOptimizer_Allreduce/HorovodAllreduce_gradients_resnet18_nopool_bn_detectnet_v2_block_3a_bn_1_FusedBatchNorm_grad_tuple_control_dependency_2_0 (defined at <string>:78) ]]
Caused by op u'DistributedAdamOptimizer_Allreduce/HorovodAllreduce_gradients_resnet18_nopool_bn_detectnet_v2_bn_conv1_FusedBatchNorm_grad_tuple_control_dependency_2_0', defined at:
sys.exit(main())
File "./detectnet_v2/scripts/train.py", line 466, in train_gridbox
File "./detectnet_v2/scripts/train.py", line 320, in build_training_graph
File "./detectnet_v2/model/detectnet_model.py", line 496, in build_training_graph
File "./detectnet_v2/training/train_op_generator.py", line 60, in get_train_op
File "./detectnet_v2/training/train_op_generator.py", line 75, in _get_train_op_without_cost_scaling
File "/usr/local/lib/python2.7/dist-packages/tensorflow/python/training/optimizer.py", line 403, in minimize
grad_loss=grad_loss)
File "/usr/local/lib/python2.7/dist-packages/horovod/tensorflow/__init__.py", line 230, in compute_gradients
avg_grads = self._allreduce_grads(grads)
File "/usr/local/lib/python2.7/dist-packages/horovod/tensorflow/__init__.py", line 209, in allreduce_grads
for grad in grads]
File "/usr/local/lib/python2.7/dist-packages/horovod/tensorflow/__init__.py", line 88, in allreduce
summed_tensor_compressed = _allreduce(tensor_compressed)
File "/usr/local/lib/python2.7/dist-packages/horovod/tensorflow/mpi_ops.py", line 91, in _allreduce
return MPI_LIB.horovod_allreduce(tensor, name=name)
File "<string>", line 78, in horovod_allreduce
File "/usr/local/lib/python2.7/dist-packages/tensorflow/python/framework/op_def_library.py", line 788, in _apply_op_helper
op_def=op_def)
File "/usr/local/lib/python2.7/dist-packages/tensorflow/python/util/deprecation.py", line 507, in new_func
return func(*args, **kwargs)
File "/usr/local/lib/python2.7/dist-packages/tensorflow/python/framework/ops.py", line 3300, in create_op
op_def=op_def)
File "/usr/local/lib/python2.7/dist-packages/tensorflow/python/framework/ops.py", line 1801, in __init__
self._traceback = tf_stack.extract_stack()
UnknownError (see above for traceback): Horovod has been shut down. This was caused by an exception on one of the ranks or an attempt to allreduce, allgather or broadcast a tensor after one of the ranks finished execution. If the shutdown was caused by an exception, you should see the exception in the log before the first shutdown message.
Here is my spec_file:
random_seed: 42
model_config {
pretrained_model_file: "/workspace/pretrained_model/tlt_resnet18_detectnet_v2_v1/resnet18.hdf5"
num_layers: 18
freeze_blocks: 0
arch: "resnet"
use_batch_norm: true
objective_set: {
cov {}
bbox {
scale: 35.0
offset: 0.5
training_precision {
backend_floatx: FLOAT32
bbox_rasterizer_config {
target_class_config {
key: "car"
value: {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 0.4
cov_radius_y: 0.4
bbox_min_radius: 1.0
key: "bicycle"
value: {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "person"
value: {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
deadzone_radius: 0.67
cost_function_config {
target_classes {
class_weight: 1.0
coverage_foreground_weight: 0.05
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
initial_weight: 10.0
weight_target: 10.0
target_classes {
class_weight: 1.0
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 1.0
target_classes {
class_weight: 1.0
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
enable_autoweighting: True
max_objective_weight: 0.9999
min_objective_weight: 0.0001
training_config {
batch_size_per_gpu: 32
num_epochs: 20
learning_rate {
soft_start_annealing_schedule {
min_learning_rate: 5e-6
max_learning_rate: 5e-4
soft_start: 0.1
annealing: 0.7
regularizer {
type: L1
weight: 3e-9
optimizer {
adam {
epsilon: 1e-08
beta1: 0.9
beta2: 0.999
cost_scaling {
enabled: False
initial_exponent: 20.0
increment: 0.005
decrement: 1.0
augmentation_config {
preprocessing {
output_image_width: 480
output_image_height: 320
output_image_channel: 3
min_bbox_width: 1.0
min_bbox_height: 1.0
spatial_augmentation {
hflip_probability: 0.5
vflip_probability: 0.0
zoom_min: 1.0
zoom_max: 1.0
translate_max_x: 8.0
translate_max_y: 8.0
color_augmentation {
color_shift_stddev: 0.0
hue_rotation_max: 25.0
saturation_shift_max: 0.2
contrast_scale_max: 0.1
contrast_center: 0.5
postprocessing_config {
key: "car"
value: {
clustering_config {
coverage_threshold: 0.005
dbscan_eps: 0.13
dbscan_min_samples: 0.05
minimum_bounding_box_height: 1
key: "bicycle"
value: {
clustering_config {
dbscan_eps: 0.15
key: "person"
value: {
clustering_config {
dbscan_eps: 0.15
dataset_config {
data_sources: {
tfrecords_path: "/workspace/tf_records/*"
image_directory_path: "/workspace/dataset/VOCdevkit/VOC2012"
image_extension: "jpg"
target_class_mapping {
key: "car"
value: "car"
key: "person"
value: "person"
key: "bicycle"
value: "bicycle"
validation_fold: 0
evaluation_config {
validation_period_during_training: 10
first_validation_epoch: 1
minimum_detection_ground_truth_overlap {
key: "car"
value: 0.7
key: "bicycle"
value: 0.5
key: "person"
value: 0.5
Same root cause as https://devtalk.nvidia.com/default/topic/1064911/transfer-learning-toolkit/tlt-first-tutorial-error/ or https://devtalk.nvidia.com/default/topic/1066439/transfer-learning-toolkit/unkown-error-by-horovod/?offset=3#5400841
Hey, since we are dealing with the same error on https://devtalk.nvidia.com/default/topic/1066439/transfer-learning-toolkit/unkown-error-by-horovod/?offset=3#5400841
it’s better i don’t clutter the forum. i didn’t found any option to delete this topic.
how can i delete this one or if you can delete then please do it.
