Resnet onnx to trt conversion failed
I am encountering an issue while attempting to convert a ResNet onnx model to trt format using the trtexec command provided by TensorRT. The ResNet model is originally in TensorFlow format and has been converted to ONNX using the tf2onnx.converter . Please find the logs.
trtexec.log (190.7 KB)
This is the error message
[03/15/2024-19:34:56] [V] [TRT] Parsing node: StatefulPartitionedCall/resnet50/predictions/MatMul [MatMul]
[03/15/2024-19:34:56] [V] [TRT] Searching for input: StatefulPartitionedCall/resnet50/avg_pool/Mean:0
[03/15/2024-19:34:56] [V] [TRT] Searching for input: StatefulPartitionedCall/resnet50/predictions/MatMul/ReadVariableOp:0
[03/15/2024-19:34:56] [V] [TRT] StatefulPartitionedCall/resnet50/predictions/MatMul [MatMul] inputs: [StatefulPartitionedCall/resnet50/avg_pool/Mean:0 -> ()[FLOAT]], [StatefulPartitionedCall/resnet50/predictions/MatMul/ReadVariableOp:0 -> (2048, 1000)[FLOAT]],
[03/15/2024-19:34:56] [V] [TRT] Registering layer: StatefulPartitionedCall/resnet50/predictions/MatMul/ReadVariableOp:0 for ONNX node: StatefulPartitionedCall/resnet50/predictions/MatMul/ReadVariableOp:0
[03/15/2024-19:34:56] [V] [TRT] Registering layer: StatefulPartitionedCall/resnet50/predictions/MatMul for ONNX node: StatefulPartitionedCall/resnet50/predictions/MatMul
[03/15/2024-19:34:56] [E] Error[4]: StatefulPartitionedCall/resnet50/predictions/MatMul: last dimension of input0 = 1 and second to last dimension of input1 = 2048 but must match.
[03/15/2024-19:34:56] [E] [TRT] ModelImporter.cpp:726: While parsing node number 123 [MatMul -> "StatefulPartitionedCall/resnet50/predictions/MatMul:0"]:
[03/15/2024-19:34:56] [E] [TRT] ModelImporter.cpp:727: --- Begin node ---
[03/15/2024-19:34:56] [E] [TRT] ModelImporter.cpp:728: input: "StatefulPartitionedCall/resnet50/avg_pool/Mean:0"
input: "StatefulPartitionedCall/resnet50/predictions/MatMul/ReadVariableOp:0"
output: "StatefulPartitionedCall/resnet50/predictions/MatMul:0"
op_type: "MatMul"
[03/15/2024-19:34:56] [E] [TRT] ModelImporter.cpp:729: --- End node ---
[03/15/2024-19:34:56] [E] [TRT] ModelImporter.cpp:732: ERROR: ModelImporter.cpp:185 In function parseGraph:
[6] Invalid Node - StatefulPartitionedCall/resnet50/predictions/MatMul
[03/15/2024-19:34:56] [E] Failed to parse onnx file
[03/15/2024-19:34:56] [I] Finish parsing network model
[03/15/2024-19:34:56] [E] Parsing model failed
[03/15/2024-19:34:56] [E] Failed to create engine from model or file.
[03/15/2024-19:34:56] [E] Engine set up failed
Please find the onnx file as well.
Gdrive link
Can use TAO Resnet model finetuning and transition to tensorrt for best performance
