Software Version
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.1.10844
other
Host Machine Version
other
After I converted resnet18.onnx to tensorrt engine with DLA, I want to instantiate 3 objects to do somothing using the converted engine file, but the moment I instantiate the third object I will get an error “[trt] 1: [nvdlaUtils.cpp::deserialize :: 154] Error code 1: DLA (NvMediaDlaInit : Init failed.)”. I don’t know what’s going on, please help.
Dear @liuhaomin1,
Did you use trtexec or C++ code for this experiment? Are you trying to run 3 models on same DLA in parallel. Could you share repro steps?
- I use c++ code for this experiment. My code is something like:
1. Model model1("test.engine"); //init model1
2. Model model2("test.engine"); //init model2
3. Model model3("test.engine"); //init model3 will get the error described before
- The strange is when call model1.~Model() after Model model1(…), Model model3(…) can be inited successfully.
2. model1.~Model();
3. Model model3("test.engine"); //init model3 will be successfully inited
Dear @liuhaomin1,
It looks like you are generating trt model for same DLA. Could you share your repro c++ code? How about generating 3 rd model for different DLA and test? Is it ok?
Does “different DLA” mean when converting an onnx model to trt engine the arg "–useDLACore={nums} " should be set to different num value? And How am I gonna know how many DLACores I have on the device tegra orin?
Sorry , I made a mistake, even I add model1.~Model(); model3 cannot be inited successfully.
I tried to set arg --useDLACore=1 for the 3rd model converting , but I still get the init error
Dear @liuhaomin1,
It has two DLAs. So you can generate two DLA models corresponding to DLA 0 and DLA1 and check running them in parallel. Running two models in parallel on same DLA may not be possible.
You can quickly verify inferencing with two DLA in parallel using trtexec and let us know if you see any issues.
OK, could u please give me an example of how to run 2 models in parallel using trtexec . For example , if I have a model test.onnx , is the command should be like this:
trtexec --onnx=test.onnx --useDLACore=0 --useDLACore=1 .......?
Dear @liuhaomin1,
For this you can run two instance of trtexec on two different terminals. One terminal uses useDLACore=0 and another uses useDLAcore=1.
after I converted my onnx model to 2 trt engine using --useDLACore=0/1, should I explicitly set which dlacore to run in my inference code?
Yes.
Hi SivaRamaKrishnaNV, I tried
The 2 engines cannot run in parallel on DLACore0 and DLACore1 respectively. I got the error again
Does it mean that this device cannot run my models in parallel ? or any solution to my problem?
Dear @liuhaomin1,
Could you share model file to repro issue with trtexec
resnet18.onnx (44.6 MB)
This is the model I use for test.
Does this error mean that there is just one dlacore ?
Dear @liuhaomin1,
Does this mean when you use --useDLACore=0, it is working and you see issue with --useDLACore=1. I notice from TensorRT model use too much memory on DriveOrin - #6 by liuhaomin1 you seems to have same issue with other models as well.
Can you restart the DRIVE AGX Orin Devkit and check again?
