Hi,nvidia colleges:
We have some problems with the camera. The specific operations are as follows.
Interface:8m(yuv)camera → cphy->orin. we have connected 8 cameras of the same type.
A set of 4trio C-phy connected to two cameras
Power up, wait kernel up
Step1:Execute in sequence
v4l2-ctl --set-fmt-video=width=3840,height=2162,pixelformat=YUYV --set-ctrl bypass_mode=0 --stream-mmap -d /dev/video0
v4l2-ctl --set-fmt-video=width=3840,height=2162,pixelformat=YUYV --set-ctrl bypass_mode=0 --stream-mmap -d /dev/video1
v4l2-ctl --set-fmt-video=width=3840,height=2162,pixelformat=YUYV --set-ctrl bypass_mode=0 --stream-mmap -d /dev/video2
v4l2-ctl --set-fmt-video=width=3840,height=2162,pixelformat=YUYV --set-ctrl bypass_mode=0 --stream-mmap -d /dev/video4
v4l2-ctl --set-fmt-video=width=3840,height=2162,pixelformat=YUYV --set-ctrl bypass_mode=0 --stream-mmap -d /dev/video5
v4l2-ctl --set-fmt-video=width=3840,height=2162,pixelformat=YUYV --set-ctrl bypass_mode=0 --stream-mmap -d /dev/video6
Working fine
step2:
close all v4l2-ctl
step3:
I found that video6 could not be opened. The specific phenomenon is as follows.
Rec log is:
This problem can be reproduced every time you repeat this operation
Why does this problem occur? I look forward to your reply.
