I run RTSP and multifilesink at the same time.
However, the result of multifilesink is executed only when an RTSP client is connected.
Here is the script and flow:
test-launch --gst-debug=3 "v4l2src device=/dev/video0 \
! queue \
! tee name=w \
! queue \
! videoconvert \
! video/x-raw, format=(string)GRAY8 \
! multifilesink location=/tmp/%d.y max-files=100 -e w. \
! queue \
! nvvidconv \
! video/x-raw(memory:NVMM), width=1920, height=1080 \
! omxh264enc \
! h264parse \
! queue \
! rtph264pay name=pay0 pt=96 \
1. Run test-launch (multifilesink using with tee)
2. client RTSP connect
3. Check client RTSP normal output
4. client RTSP stop
Sections 2 and 3 where multifilesink files are created in the above process.
Multifilesink file is created only when RTSP client is connected.
Can’t I create a multifilesink file regardless of the RTSP client connection? (created from number 1)
