Hello, there.
Thank you for reading this topic!
I made a code which just add two vectors, :)
However, its result is not matched real result as below.
Where do I have to change for calculating results come correct.
Thank you in advance.
#include <stdio.h>
#include <stdlib.h>
__global__ void add( int *a, int *b, int *c)
int tid = threadIdx.x;
c[tid] = a[tid] + b[tid];
int main()
int N = 1500;
int i;
int sum;
int *a, *b, *c;
int *dev_a, *dev_b, *dev_c;
// memory allocation in CPU
a = (int *)malloc(N*sizeof(int));
b = (int *)malloc(N*sizeof(int));
c = (int *)malloc(N*sizeof(int));
// allocation each parameter space in GPU
cudaMalloc( (void**)&dev_a, N*sizeof(int) );
cudaMalloc( (void**)&dev_b, N*sizeof(int) );
cudaMalloc( (void**)&dev_c, N*sizeof(int) );
// each value is stored into a and b vector
for (int i=0; i<N; ++i)
a[i] = i;
b[i] = i*2;
c[i] = 0;
// Copy data into device(e.g. GPU) memory from host memory
cudaMemcpy( dev_a, a, N*sizeof(int), cudaMemcpyHostToDevice );
cudaMemcpy( dev_b, b, N*sizeof(int), cudaMemcpyHostToDevice );
// Call function name as add
// <<< , this number concerns iteration number >>>
add<<<1, N>>>(dev_a, dev_b, dev_c);
cudaMemcpy( c, dev_c, N*sizeof(int), cudaMemcpyDeviceToHost);
// The result
for (int i=0;i<N;++i)
printf("%d + %d = %d\n",a[i],b[i],c[i]);
// free memory
cudaFree(dev_a);
cudaFree(dev_b);
cudaFree(dev_c);
return 1;
