Retrain DetectNet_v2 with QAT=True
• Network Type (Detectnet_v2)
• TLT Version (TAO v5.5.0)
I have trained DetectNetv2 with QAT=True initially. Then, I have pruned the model and trying to retrain the model with QAT=True again. I’m not able to retrain the model with QAT enabled.
Any specific reason why we can’t train multiple times with QAT enabled for DetectNetv2 ?
Attaching the reference here as previous discussion. Wanted to know any changes have been implemented now for supporting QAT again for DetectNetv2 while retraining
Please suggest. Thanks in advance
[quote=“venkatesha2411, post:1, topic:328209”]
Can you double check?
Please
  • Set the load_graph flag to true, so that the newly pruned model structure is imported.
Refer to Improving INT8 Accuracy Using Quantization Aware Training and the NVIDIA TAO Toolkit | NVIDIA Technical Blog.
Hi!
Thanks for the inputs,
  1. we verified with set log_graph = true and I have briefed steps followed below:
We checked with initially training Model with QAT = True → Pruned the trained model → Retrain the pruned model with QAT enabled.
But this still fails while execution. Could you please confirm on this ? Is it a bug or any reason is it restricted for DetectNetv2 model ?
Could you please share full logs and commands? Thanks a lot.
