Hello, i have a pretrained yolov5 model trained on coco dataset with 80categories
currently i would like to remove from the model 78 categories and use just two of them, what’s the best way to do it?
do i need to download the coco dataset, select just the two categories of interest and retrain the model from scratch?
do i need to download the coco dataset, select just the two categories of interest and retrain the model starting from the checkpoint that i currently have?
Is there any other way to reach this goal?
Environment
**Training **: google colab
**Training **: NVIDIA Tesla
deploy
**TensorRT **:8 GPU Type: Nvidia Jetson CUDA Version: 10.2 Operating System: Ubuntu 1804 Python Version (if applicable): 3.6.9
Request you to share the ONNX model and the script if not shared already so that we can assist you better.
Alongside you can try few things:
validating your model with the below snippet
check_model.py
import sys
import onnx
filename = yourONNXmodel
model = onnx.load(filename)
onnx.checker.check_model(model).
2) Try running your model with trtexec command.
In case you are still facing issue, request you to share the trtexec “”–verbose"" log for further debugging
