Trying to retrain the pruned model and my spec file is attached.retrain_spec_resnet34.log (3.6 KB)
According to the tutorial here, I need to set regularizer type is ‘NO_REG’. But I have error
File "/usr/local/bin/tlt-train-g1", line 8, in <module>
sys.exit(main())
File "./common/magnet_train.py", line 33, in main
File "./faster_rcnn/scripts/train.py", line 48, in main
File "./faster_rcnn/spec_loader/spec_wrapper.py", line 36, in __init__
File "./faster_rcnn/spec_loader/spec_wrapper.py", line 575, in validate_spec
File "./faster_rcnn/spec_loader/spec_wrapper.py", line 756, in validate_training_config
AssertionError:
Regularizer can only be L1(l1), or L2(l2), got no_reg
Why I have error in Frcnn?
Could you try “none”?
See https://docs.nvidia.com/metropolis/TLT/tlt-getting-started-guide/index.html#training_configuration
The regularizer type. Can be either ‘L1’(L1 regularizer), ‘L2’(L2 regularizer), or ‘none’(No regularizer).
I still have error as
sys.exit(main())
AssertionError:
Regularizer can only be L1(l1), or L2(l2), got none
I am retraining pruned model for Frcnn with TLT docker version 2.0.
Sorry, unfortunately, TLT 2.0_dp docker does not support no regularizer.
TLT 1.0 supports no regularizer.
For temp workaround, in TLT 2.0 training spec, please set a small L2 reg like 1e-10 to essentially disable it for now.
We will fix it in next release.
