Retrain TrafficCamNet with custom vehicle dataset using TLT 3.0
• Hardware (T4/V100/Xavier/Nano/etc) - Tesla T4
• Network Type (Detectnet_v2/Faster_rcnn/Yolo_v4/LPRnet/Mask_rcnn/Classification/etc) - Detectnet_v2
• TLT Version - 3.0
I am trying to retrain the exisiting trafficcamnet model unpruned model available in NGC by adding custom dataset to the class car and two-wheelers to increase accuracy in detecting cars and two-wheelers.
I have prepared a annotated dataset in KITTI format with RGB images in 960(w)*544(h) with cars and two-wheelers labelled in each image. I am going to use the detectnetv2 jupyter notebook file for the training of this detection model.
Queries:
  • What are the hyperparameters that I have to change in the specs directory as there are multiple files in the directory in order to add the custom data to exisiting classes car and two-wheelers in the model? Could you please send me a sample for this?
  • Is it possible to add the images annotated as two-wheelers to bicycle class or should i add it as a separate class?
  • The image i have annotated is similar to the below image. As per the trafficcamnet documentation in NGC it was mentioned that the model was trained with images with 5ft height and traffic signal content. Will my annotation using similar images as below affect the performance of the model or should i make any changes in the training spec file that might help to capture these cars from this particular angle as the cars are a bit smaller in size?
    Note: I haven’t annotated the cars that are too far and tiny.
Waiting for your reply. Thanks in advance.
Please refer to the last one: detectnet_v2_train_resnet18_kitti.txt. Change to the corresponding classes you want to train. I am afraid you will train a two classes model, car and two-wheelers. So, just set car and two-wheelers in the spec. Delete other class info.
Your training images are not similar to the trafficcamnet’s. And also trafficcament(i.e, detectnet_v2 network) will not work well for very small objects(for example, less than 20x20) , so you can consider using yolov4-tiny to train from scratch.
@Morganh Thanks for the information. What should I do to add custom datasets to the exisiting classes in the trafficcamnet i.e car,persons,bicylce and road signs? Can I add my annotated dataset to the class that is already exisiting i.e add more car images to class car? If yes, how can I do that?
Please prepare dataset for car and two-wheelers.
Then, set corresponding section for car and two-wheelers.
Do not need to set anything for persons,bicycle and road signs .
@Morganh Thanks for the prompt reply. I’ll attach my detectv2_train spec file. Can you please correct me if I’m wrong with the configurations anywhere.?
random_seed: 42
dataset_config {
  data_sources {
    tfrecords_path: "/workspace/tlt-experiments/data/tfrecords/kitti_trainval/*"
    image_directory_path: "/workspace/tlt-experiments/data/training"
  image_extension: "png"
  target_class_mapping {
    key: "car"
    value: "car"
    key: "two-wheelers"
    value: "two-wheelers"
    key: "cyclist"
    value: "cyclist"
    key: "pedestrian"
    value: "pedestrian"
    key: "person_sitting"
    value: "pedestrian"
    key: "van"
    value: "car"
  validation_fold: 0
augmentation_config {
  preprocessing {
    output_image_width: 1248
    output_image_height: 384
    min_bbox_width: 1.0
    min_bbox_height: 1.0
    output_image_channel: 3
  spatial_augmentation {
    hflip_probability: 0.5
    zoom_min: 1.0
    zoom_max: 1.0
    translate_max_x: 8.0
    translate_max_y: 8.0
  color_augmentation {
    hue_rotation_max: 25.0
    saturation_shift_max: 0.20000000298
    contrast_scale_max: 0.10000000149
    contrast_center: 0.5
postprocessing_config {
  target_class_config {
    key: "car"
    value {
      clustering_config {
        clustering_algorithm: DBSCAN
        dbscan_confidence_threshold: 0.9
        coverage_threshold: 0.00499999988824
        dbscan_eps: 0.20000000298
        dbscan_min_samples: 0.0500000007451
        minimum_bounding_box_height: 20
    key: "two-wheelers"
    value {
      clustering_config {
    key: "cyclist"
    value {
      clustering_config {
        dbscan_eps: 0.15000000596
    key: "pedestrian"
    value {
      clustering_config {
        coverage_threshold: 0.00749999983236
        dbscan_eps: 0.230000004172
model_config {
  pretrained_model_file: "/workspace/tlt-experiments/detectnet_v2/pretrained_trafficcamnet/trafficcamnet_vunpruned_v1.0/resnet18_trafficcamnet.tlt"
  num_layers: 18
  use_batch_norm: true
  objective_set {
    bbox {
      scale: 35.0
      offset: 0.5
    cov {
  training_precision {
    backend_floatx: FLOAT32
  arch: "resnet"
evaluation_config {
  validation_period_during_training: 10
  first_validation_epoch: 30
  minimum_detection_ground_truth_overlap {
    key: "car"
    value: 0.699999988079
    key: "two-wheelers"
    key: "cyclist"
    value: 0.5
    key: "pedestrian"
    value: 0.5
  evaluation_box_config {
    key: "car"
    value {
      minimum_height: 20
      maximum_height: 9999
      minimum_width: 10
      maximum_width: 9999
    key: "two-wheelers"
    value {
      minimum_height: 20
      minimum_width: 10
      maximum_width: 9999
    key: "cyclist"
    value {
      minimum_height: 20
      minimum_width: 10
      maximum_width: 9999
    key: "pedestrian"
    value {
      minimum_height: 20
      minimum_width: 10
      maximum_width: 9999
  average_precision_mode: INTEGRATE
cost_function_config {
  target_classes {
    class_weight: 1.0
    coverage_foreground_weight: 0.0500000007451
    objectives {
      initial_weight: 1.0
      weight_target: 1.0
    objectives {
      initial_weight: 10.0
      weight_target: 10.0
target_classes {
    class_weight: 1.0
    objectives {
      initial_weight: 1.0
      weight_target: 1.0
    objectives {
      weight_target: 10.0
  target_classes {
    class_weight: 8.0
    objectives {
      initial_weight: 1.0
      weight_target: 1.0
    objectives {
      weight_target: 1.0
  target_classes {
    class_weight: 4.0
    objectives {
      initial_weight: 1.0
      weight_target: 1.0
    objectives {
      weight_target: 10.0
  enable_autoweighting: true
  max_objective_weight: 0.999899983406
  min_objective_weight: 9.99999974738e-05
training_config {
  batch_size_per_gpu: 4
  num_epochs: 120
  learning_rate {
    soft_start_annealing_schedule {
      min_learning_rate: 5e-06
      max_learning_rate: 5e-04
      soft_start: 0.10000000149
      annealing: 0.699999988079
  regularizer {
    type: L1
    weight: 3.00000002618e-09
  optimizer {
    adam {
      epsilon: 9.99999993923e-09
      beta1: 0.899999976158
      beta2: 0.999000012875
  cost_scaling {
    initial_exponent: 20.0
    increment: 0.005
    decrement: 1.0
  checkpoint_interval: 10
bbox_rasterizer_config {
    key: "car"
    value {
      cov_center_x: 0.5
      cov_center_y: 0.5
      cov_radius_x: 0.40000000596
      cov_radius_y: 0.40000000596
      bbox_min_radius: 1.0
    key: "two-wheelers"
    value {
      cov_center_x: 0.5
      cov_center_y: 0.5
    key: "cyclist"
    value {
      cov_center_x: 0.5
      cov_center_y: 0.5
      cov_radius_x: 1.0
      cov_radius_y: 1.0
    key: "pedestrian"
    value {
      cov_center_x: 0.5
      cov_center_y: 0.5
      cov_radius_x: 1.0
      cov_radius_y: 1.0
  deadzone_radius: 0.400000154972
Is this correct or should I make any other changes by removing the cyclist , pedestraian from the file?
Please remove all the info which is not car and two-wheelers, and also
output_image_width: 1248 → 960
output_image_height: 384 → 544
@Morganh
Ok. Will change the width and height and remove the other info and try training using the images.
@Morganh
Im able to convert the dataset to TF records and I’m facing a error during running the training cell in the jupyter notebook
2022-02-09 14:20:52,793 [INFO] root: Registry: ['nvcr.io']
2022-02-09 14:20:52,851 [INFO] tlt.components.instance_handler.local_instance: Running command in container: nvcr.io/nvidia/tao/tao-toolkit-tf:v3.21.11-tf1.15.4-py3
2022-02-09 14:20:52,866 [WARNING] tlt.components.docker_handler.docker_handler:
Docker will run the commands as root. If you would like to retain your
local host permissions, please add the "user":"UID:GID" in the
DockerOptions portion of the "/home/glueck/.tao_mounts.json" file. You can obtain your
users UID and GID by using the "id -u" and "id -g" commands on the
terminal.
Using TensorFlow backend.
WARNING:tensorflow:Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
WARNING:tensorflow:From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/cost_function/cost_auto_weight_hook.py:43: The name tf.train.SessionRunHook is deprecated. Please use tf.estimator.SessionRunHook instead.
2022-02-09 06:20:57,595 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/cost_function/cost_auto_weight_hook.py:43: The name tf.train.SessionRunHook is deprecated. Please use tf.estimator.SessionRunHook instead.
WARNING:tensorflow:From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/tfhooks/checkpoint_saver_hook.py:25: The name tf.train.CheckpointSaverHook is deprecated. Please use tf.estimator.CheckpointSaverHook instead.
2022-02-09 06:20:57,676 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/tfhooks/checkpoint_saver_hook.py:25: The name tf.train.CheckpointSaverHook is deprecated. Please use tf.estimator.CheckpointSaverHook instead.
WARNING:tensorflow:From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py:69: The name tf.logging.set_verbosity is deprecated. Please use tf.compat.v1.logging.set_verbosity instead.
2022-02-09 06:20:57,677 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py:69: The name tf.logging.set_verbosity is deprecated. Please use tf.compat.v1.logging.set_verbosity instead.
WARNING:tensorflow:From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py:69: The name tf.logging.INFO is deprecated. Please use tf.compat.v1.logging.INFO instead.
2022-02-09 06:20:57,677 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py:69: The name tf.logging.INFO is deprecated. Please use tf.compat.v1.logging.INFO instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/__init__.py:117: The name tf.global_variables is deprecated. Please use tf.compat.v1.global_variables instead.
2022-02-09 06:20:57,684 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/__init__.py:117: The name tf.global_variables is deprecated. Please use tf.compat.v1.global_variables instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/__init__.py:143: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
2022-02-09 06:20:57,684 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/__init__.py:143: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
2022-02-09 06:20:58,032 [INFO] iva.common.logging.logging: Log file already exists at /workspace/tao-experiments/detectnet_v2/experiment_dir_unpruned/status.json
2022-02-09 06:20:58,033 [INFO] __main__: Loading experiment spec at /workspace/tao-experiments/detectnet_v2/specs/detectnet_v2_train_resnet18_kitti.txt.
2022-02-09 06:20:58,034 [INFO] iva.detectnet_v2.spec_handler.spec_loader: Merging specification from /workspace/tao-experiments/detectnet_v2/specs/detectnet_v2_train_resnet18_kitti.txt
2022-02-09 06:20:58,735 [INFO] __main__: Cannot iterate over exactly 9227 samples with a batch size of 4; each epoch will therefore take one extra step.
WARNING:tensorflow:From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/cost_function/cost_auto_weight_hook.py:107: The name tf.variable_scope is deprecated. Please use tf.compat.v1.variable_scope instead.
2022-02-09 06:20:58,736 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/cost_function/cost_auto_weight_hook.py:107: The name tf.variable_scope is deprecated. Please use tf.compat.v1.variable_scope instead.
WARNING:tensorflow:From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/cost_function/cost_auto_weight_hook.py:110: The name tf.get_variable is deprecated. Please use tf.compat.v1.get_variable instead.
2022-02-09 06:20:58,736 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/cost_function/cost_auto_weight_hook.py:110: The name tf.get_variable is deprecated. Please use tf.compat.v1.get_variable instead.
WARNING:tensorflow:From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/cost_function/cost_auto_weight_hook.py:113: The name tf.assign is deprecated. Please use tf.compat.v1.assign instead.
2022-02-09 06:20:58,738 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/cost_function/cost_auto_weight_hook.py:113: The name tf.assign is deprecated. Please use tf.compat.v1.assign instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:517: The name tf.placeholder is deprecated. Please use tf.compat.v1.placeholder instead.
2022-02-09 06:20:58,777 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:517: The name tf.placeholder is deprecated. Please use tf.compat.v1.placeholder instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:4138: The name tf.random_uniform is deprecated. Please use tf.random.uniform instead.
2022-02-09 06:20:58,778 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:4138: The name tf.random_uniform is deprecated. Please use tf.random.uniform instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:1834: The name tf.nn.fused_batch_norm is deprecated. Please use tf.compat.v1.nn.fused_batch_norm instead.
2022-02-09 06:20:58,794 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:1834: The name tf.nn.fused_batch_norm is deprecated. Please use tf.compat.v1.nn.fused_batch_norm instead.
2022-02-09 06:20:59,870 [INFO] __main__: Training was interrupted.
Time taken to run __main__:main: 0:00:02.192935.
2022-02-09 14:21:00,897 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
The below attached is my detectnetv2_train spec file
random_seed: 42
dataset_config {
  data_sources {
    tfrecords_path: "/workspace/tao-experiments/data/tfrecords/kitti_trainval/*"
    image_directory_path: "/workspace/tao-experiments/data/training"
    key: "car"
    value: "car"
    key: "two-wheelers"
  validation_fold: 0
  preprocessing {
    output_image_width: 960
    output_image_height: 544
    min_bbox_width: 1.0
    zoom_min: 1.0
    zoom_max: 1.0
    key: "car"
    value {
      clustering_config {
    key: "two-wheelers"
    value {
      clustering_config {
model_config {
  pretrained_model_file: "/workspace/tao-experiments/detectnet_v2/trafficcamnet_pretrained_unpruned_v1.0/trafficcamnet_vunpruned_v1.0/resnet18_trafficcamnet.tlt"
  num_layers: 18
  objective_set {
    bbox {
      scale: 35.0
      offset: 0.5
    cov {
  arch: "resnet"
evaluation_config {
    key: "car"
    key: "two-wheelers"
    value: 0.5
    key: "car"
    value {
      minimum_height: 20
      minimum_width: 10
      maximum_width: 9999
    key: "two-wheelers"
    value {
      minimum_height: 20
      minimum_width: 10
      maximum_width: 9999
  target_classes {
    class_weight: 1.0
    objectives {
      initial_weight: 1.0
      weight_target: 1.0
    objectives {
      weight_target: 10.0
  target_classes {
    class_weight: 8.0
    objectives {
      initial_weight: 1.0
      weight_target: 1.0
    objectives {
      weight_target: 1.0
training_config {
  num_epochs: 250
  learning_rate {
  regularizer {
    type: L1
  optimizer {
    adam {
  cost_scaling {
    increment: 0.005
    decrement: 1.0
    key: "car"
    value {
      cov_center_x: 0.5
      cov_center_y: 0.5
    key: "two-wheelers"
    value {
      cov_center_x: 0.5
      cov_center_y: 0.5
      cov_radius_x: 1.0
      cov_radius_y: 1.0
Can you please help me on this issue?
To narrow down, can you run in terminal instead of jupyter notebook?
Login the docker:
$ tao detectnet_v2 run /bin/bash
Run training
# detectnet_v2 train xxx
@Morganh I fixed it and the training cell started running successfully. Earlier had set the $KEY variable as the key generated from the NGC which is set in ngc config set and also used as the docker login nvcr.io password.
I browsed through the forum post and one post said to add %env KEY=tlt_encode which was earlier set by NVIDIA. By doing that the training cell is working now.
