• Hardware Platform (Jetson / GPU) Jetson • DeepStream Version 6.2 • JetPack Version (valid for Jetson only) 5.1 • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only)
I am working on a deepstream pipeline with a object detection model followed by tracker and classifier. Object detection model will detect the Retail items, tracker will assign the tracking id, and classifier will further classify it to a sub category like pepsi, diet-pepsi or any other.
The issue I am facing is
For example there are two objects detected by object detection model as Item1, and Item2 (here 1 and 2 is tracker id) and classifier classified both object into subcategory, but I want get the class_id for the item1 assigned by the classifier.
I am working with an object detection model that detects a single class, “Retail Item,” and a classifier that assigns subcategories like Coke, Pepsi, and others. Here’s the scenario:
When the object detection model detects two instances of “Retail Item,” the tracker assigns IDs (e.g., 1 and 2) to these instances. Both detected items are then passed to the classifier, which assigns a classification ID to each instance.
My question is: How can I retrieve the classification ID assigned by the classifier specifically to the item with tracking ID 1?
