• Hardware Platform (Jetson / GPU) Jetson Nano
• DeepStream Version 6.0
• JetPack Version (valid for Jetson only) 4.6.1
Hello guys,
I’m trying to have an audio application running in python.
Until now I was abble to construct the python bindings to define the NvDsAudioFrameMea, NvBufAudio and NvBufAudioParams.
Similar to what we use to retrieve the frame from a vision app → get_nvds_buf_surface function, I try to wrote my on function to retrieve the audio sample.
m.def("get_nvds_buf_audio",
[](size_t gst_buffer, int batchID) {
auto *buffer = reinterpret_cast<GstBuffer *>(gst_buffer);
GstMapInfo inmap;
gst_buffer_map(buffer, &inmap, GST_MAP_READ);
auto *inputnvsurface = reinterpret_cast<NvBufAudio *>(inmap.data);
gst_buffer_unmap(buffer, &inmap);
// int size = sizeof(inputnvsurface->audioBuffers) / sizeof(NvBufAudioParams);
// std::cout << "num elemnts: " << size << '\n';
// std::cout << "BufAudio batch size: " << inputnvsurface->batchSize << "\n";
auto input_surface = inputnvsurface->audioBuffers[batchID];
// std::cout << "0 audio buf with batch id: : " << batchID << "\n";
// std::cout << "0 audio buf: : " << input_surface.duration << "\n";
uint32_t rate = input_surface.rate;
uint32_t channels = input_surface.channels;
uint32_t bpf = input_surface.bpf;
uint32_t data_size = input_surface.dataSize;
uint64_t duration = input_surface.duration;
auto dtype = py::dtype(
py::format_descriptor<unsigned char>::format());
// std::cout << "BufAudio num filled: " << inputnvsurface->numFilled << "\n";
// std::cout << "BufAudio iscontiguius: " << inputnvsurface->isContiguous << "\n";
// std::cout << "AudioParams datasize: " << data_size << "\n";
// std::cout << "AudioParams bufPTS: " << input_surface.bufPts << "\n";
// std::cout << "AudioParams Duration: " << duration << "\n";
// std::cout << "AudioParams rate: " << rate << "\n";
// std::cout << "AudioParams channels: " << channels << "\n";
// std::cout << "AudioParams bpf: " << bpf << "\n";
return py::array (dtype,
{data_size,},
{sizeof(unsigned char) * 8},
(const unsigned char *) input_surface.dataPtr,
py::cast(input_surface.dataPtr)
"gst_buffer"_a,
"batchID"_a,
py::return_value_policy::reference,
pydsdoc::methodsDoc::get_nvds_buf_surface
I was only able to retrieve a very small amount of data.
Can someone help me out with this?
In the documentation the NvBufAudio.batchSize and NvBufAudio.numFilled as exactly the same description.
NvBufAudio.batchSize value is always 1, but NvBufAudio.audioBuffers can be accessed in other indexes.
The data is not clear. Should we iterate over the NvBufAudio.audioBuffers? Is for that reason that the NvBufAudioParams.dataSize is always 2520?
What is the NvBufAudioParams.duration units? an example of a value is 28571428.
Hope someone can help me with this! Thanks in advance!
