Retrieve the vector from output_layer.buffer
I have a regression model that has one layer with output shape 1x11x20
so i use metaTensorData and this function here:
All is working well but i need to get the output vector itself from that one and only layer i have,
So how to retrieve the output_layer.buffer, i want something that replace the ```
pyds.get_detections(output_layer.buffer, 0)
For a suppport, here's the reproduce of the function that mentioned in the link for my model:
> import sys
> import pyds
> def layer_finder(output_layer_info, name):
>     """ Return the layer contained in output_layer_info which corresponds
>         to the given name.
>     for layer in output_layer_info:
>         # dataType == 0 <=> dataType == FLOAT
>         if layer.dataType == 0 and layer.layerName == name:
>             return layer
>     return None
> def nvds_infer_parse_custom_crowd_count(output_layer_info):
>     output_layer = layer_finder(output_layer_info, "output")
>     print("output", output_layer)
>     if not output_layer:
>         sys.stderr.write("ERROR: output layer is missing in output tensors\n")
>         return []
>     num_detection = 0
>     print("output_layer.buffer", output_layer.buffer)
>     if output_layer.buffer:
>         num_detection = int(pyds.get_detections(output_layer.buffer, 0))
>         print("num detection", num_detection)
**• Hardware Platform (GPU)**
**• DeepStream 5**
**• TensorRT 7.0.0**
@bcao
This is another dependent problem of this question , but it’s more specific xD
Hey, pyds.get_detections only get one element one time from the buffer, so you need to iterate on the buffer to get the whole 1x11x20 elements.
found this solution,
and it worked for me
Great work.
Thank you very much for your help
