I have a C functions, that allocate memory on CUDA device, and then return back the pointer to that device memory. There are two possible ways for this C functions:
- a function with a double** argument
- a function return double*
It’s easy to implement in C. However, as I read that Fortran is not easy to handle pointer-to-pointer, I chose the second one. For the second interface, I tried using type(c_ptr), yet it doesn’t work
in C:
double* foofuunc() {...}
Fortran interface:
type(c_ptr) foofunc() bind(c)
and then I try to cast to a device memory variable in Fortran, declared with
double precision, dimension(:), allocatable, device :: a
I got “illegal number of type of argument”
type(c_ptr) :: c_a
c_f_pointer(c_a, a)
Could someone give me an advice.
Thanks,
Tuan
