I am starting out with cuda, and am trying a simple example where I send two arrays into a global function, copy one to the other, and return the second one.
I have:
__global__
void add(int n, int *tri, int *y)
int index = threadIdx.x;
int stride = blockDim.x;
for (int i = index; i < n; i += stride)
y[i] = tri[i];
and:
//local copy of data
int *tri2 = tri; // data checked, and is valid
int *y = new int[width * height]; // same size as `tri`
int N = width * height;
// Allocate Unified Memory – accessible from CPU or GPU
cudaMallocManaged(&tri2, N * sizeof(int));
cudaMallocManaged(&y, N * sizeof(int));
// initialize y array on the host
for (int i = 0; i < N; i++) {
y[i] = 2;
// Run kernel on the GPU
add << <1, 256 >> >(N, tri2, y);
// Wait for GPU to finish before accessing on host
cudaDeviceSynchronize();
//copy back to host
int i = 0;
int f = -999.0; /* CPU copy of value */
cudaMemcpy(&f, &y[i], sizeof(int), cudaMemcpyDeviceToHost);
std::cout << "back: " << f << std::endl;
std::cout << "orig: " << tri[i] << std::endl;
The orig value is 128, the same as when it went in. the returned f value is always 0. What am i missing?
