Returning only response without explanation
I tried using Code Llama 13B and it’s very good. However is it possible to return only response without the wordy explanation? Or preferably even specify an output format like string or json? Thanks!
Are you using The AI Playground | NVIDIA Research ?
I’m using this via the API method:
