Reusing PWM (32a0000.pwm / pwmchip1) for a custom application instead of pwm-fan
I am using a custom Jetson Orin NX board with JetPack 6.2.2.
Currently, pwmchip1 (32a0000.pwm) is used by the pwm-fan driver. The output of /sys/kernel/debug/pwm is:
platform/32a0000.pwm, 1 PWM device
 pwm-0 (pwm-fan): requested enabled period: 45334 ns duty: 178 ns polarity: normal
We referred to this forum thread to see the duty cycle information:
I understand that while pwm-fan owns this PWM, it cannot be exported through /sys/class/pwm/pwmchip1/export, and attempting to export it returns:
Device or resource busy
My requirement is different from controlling the fan.
In a future hardware revision, the fan will be removed, and the same PWM controller (32a0000.pwm / pwmchip1) will be connected to an external device.
Could you please clarify the recommended approach?
  1. What steps should I perform to remove the pwm-fan node from the device tree and repurpose 32a0000.pwm for another PWM application?
Any guidance or documentation would be appreciated.
Thank you.
Hi archa.cp,
Yes, you need to disable pwm-fan node in device tree and remove nvfancontrol service.
Please share the full dmesg and device tree for further check.
