Reusing same memory spaces with a different vaiable name
Ok, I want to know if it’s possible to reuse the same shared memry space in a kernel for different purposes. I have three different arrays of different sizes residing in shared memory, but I am never using more than one array at a time, which means I can use the same array for different purposes.
The problem is that the arrays are of different types, sizes and dimensionality. For arrays of dimensionality 1, I can use a pointer to the first element of the big array, with a typecast, but this increases the register usage by 1. Is there any way to do that without extra overhead and ugly unions?
[codebox]
struct type1
  16byteData;
struct type2
  12byteData;
global void kernel(…)
__shared__ type1 arr1[BLOCK_Y_MT][BLOCK_X_MT];		//biggest array
__shared__ type2 smTemp[BLOCK_X_MT][BLOCK_Y_MT];	// Not as big of an array
// The following cast will not work
//Vector3<float> **smTemp = (type1 **)&charge[0];
// This will work, but introduces one extra register
type2 *arr3 = (type2 *)&charge[0][0];	// small array
[/codebox]
Well, I guess I’m stuck to using a union. It is elegant in that it requires minimal code change, and ugly in the fact that the union must be referenced whenever one of the component arrays is.
[codebox]
union unitedArrays
type1[] arr1;
type2[][] arr2;
type2[] arr3;
//in the kernel
global void optimizedKernel(…)
__shared__ unitedArrays uArr;
// reference arr1
foo(uArr.arr1[]);
[/codebox]
