Revert back to version Ubuntu 18 instead Ubuntu 20
Updated to 20 ubuntu by mistake.
The UI doesn’t start.
I want to erase all data and go back to Ubuntu 18.
Flash your board with sdkmanager.
How to do it?
Didn’t you do that in the first time you used your AGX?
JetPack manager on host only about nvidia soft? But where is Ubuntu reset?
How to clear all the memory? I want to reset to factory settings. So that the device is out of the box
No, sdkmanger also includes to reflash the whole system…
Twice a failure.
The “Jetson SDK Components” does not matter in this issue. You can skip that at this moment.
Please just try that “Flash jetson OS”. If it has error, please press that"EXPORT LOGS" button and attach the full log here.
“Flash jetson OS” - successfully, but nothing happened. Still Ubuntu 20.
Please share two logs
  1. EXPORT LOGS from sdkmanager.
  2. Use below method to dump the serial console log.
SDKM_logs_JetPack_4.6_(rev.2)_Linux_for_Jetson_AGX_Xavier_modules_2021-11-03_15-07-37.zip (40.9 KB)
[0000.085] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet lev.
[0000.093I> MB1 (prd-version: 1.5.1.2-t194-41334769-9ec1833d)
[0000.09 I> Boot-mode: Coldboot
[0000.101] I> Chip revision : A02P
[0000.104] I> Bootrom patch version : 15 (correctly patched)
[00.110] I> ATE fuse revision : 0x200
[0000.113] I> Ram repairuse : 0x0
[0000.116] I> Ram Code : 0x2
[0000.119] I> rst_souce : 0x0
[0000.121] I> rst_level : 0x0
[0000.125] I> Boot-dece: eMMC
[0000.140] I> sdmmc DDR50 mode
[0000.144] W> No valid slot nuer is found in scratch register
[0000.149] W> Return default ot: _a
[0000.153] I> Active Boot chain : 0
[0000.156] I> Boot-deve: eMMC
[0000.160] W> MB1_PLATFORM_CONFIG: device prod data iempty in MB1 BCT.
[0000.167] I> Temperature = 36500
[0000.170] W> Skipping boost for clk: BPMCPU_NIC
[0000.175] W> Skipping boost for clk: BPMP_APB
[000079] W> Skipping boost for clk: AXI_CBB
[0000.183] W> Skipping boost for clk: AON_CPU_NIC
[0000.187] W> Skipping boost for k: CAN1
[0000.191] W> Skipping boost for clk: CAN2
[0000.195I> Boot-device: eMMC
[0000.198] I> Boot-device: eMMC
[0000.207] I> Sdmmc: HS400 mode enabled
[0000.212] I> ECC regn[0]: Start:0x0, End:0x0
[0000.216] I> ECC region[1]: Start:0x0, End:0x0
[0000.220] I> ECC regn[2]: Start:0x0, End:0x0
[0000.224] I> ECC region[3]: Start:0, End:0x0
[0000.228] I> ECC region[4]: Start:0x0, End:0x0
[0000.232] I> Non-ECC region[0]: Start:0x80000000, End:0x1000000
[0000.238] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.2] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.247] I> NonECC region[3]: Start:0x0, End:0x0
[0000.251] I> Non-ECC regio4]: Start:0x0, End:0x0
[0000.257] E> FAILED: Thermal config
000.264] E> FAILED: MEMIO rail config
[0000.283] I> Boot-device: eMMC
[0000.292] I> sdmmc bdev is aeady initialized
[0000.363] I> MB1 done
����main enter
SPE VERSION #: R01…14 Created: Sep 19 2018 @ 11:03:21
HW Function test
Start Scheduler.
in late init
[000371] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobe-fc4604fb)
[0000.372] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.373] I> Default Heap @ [0xd486400 - 0xd48a400][0000.373] E> DEVICE_PROD: .
[0000.379] W> device prod register failed
[0000.383] I> Boot-device: eMMC
[0000.386] I> Boot_device: SDMMC_BO instance: 3
0000.394] I> sdmmc bdev is already initializeds
[0000.399] I> sdmmc-3 params source = boot args
[0000.405] I> Found partitions in SDMMC_BOOT (instance 3)
[0000.412] I> Found 42artitions in SDMMC_USER (instance 3)
[0000.414] W> No valid slot number is found in scratch register
[0000.420] W> turn default slot: _a
[0000.423] I> Active Boot chain : 0
[00.427] I> parsing oem signed section of bpmp-fw header done
[0000.432] I> bpmp-fw binary init read from storage
[00.437] I> oem authentication of bpmp-fw header done
[0000.443]> bpmp-fw binary done read from storage
[0000.446] I> bpmp-fw: Authentication init Done
[0000.451] I> parsing oem sned section of cpubl header done
[0000.456] I> cpubl binary it read from storage
[0000.461] I> bpmp-fw: Authentication Finalize Done
[0000.465] I> oem authentication of cpubl hder done
[0000.470] I> cpubl binary done read from storage
[00.474] I> cpubl: Authentication init Done
[0000.479] I> parsing oem signed section of rce header done
[0000.484] Irce binary init read from storage
[0000.488] I> Relocating BRCT
[0000.491] I> cpubl: Authentication Finalize Done
[0000.496] I> oem authentication of rce header done
[0000.50 I> rce binary done read from storage
[0000.504] I> rce: Authtication init Done
[0000.509] I> parsing oem signed section of ape header done
[0000.514] I> ape binary init read fm storage
[0000.518] I> rce: Authentication Finalize Done
[00.523] I> oem authentication of ape header done
[0000.527] I> ape binary done read from storage
[0000.531] I> ape: thentication init Done
[0000.536] I> parsing oem signed secti of tos header done
[0000.541] I> tos binary init read from storage
[0000.545] I> ape: Authentication Finalize Done[0000.550] I> oem authenticatione
[0000.554I> tos binary done read from storage
[0000.558] I> tos: Authentication init Done
[0000.562] I> parsing oem signed stion of bpmp-fw-dtb header done
[0000.568] I> bpmp-fw-dtb biny init read from storage
[0000.573] I> tos: Authentication Finalize Done
[0000.579] I> oem authentication of bpmp-fdtb header done
[0000.583] I> bpmp-fw-dtb binary done read fr storage
[0000.588] I> bpmp-fw-dtb: Authentication init Done
[0000.593] I> parsing oem signed section of cpubl-dtb ader done
[0000.598] I> cpubl-dtb binary init read from stora
[0000.603] I> bpmp-fw-dtb: Authentication Finalize Done
[0000.640] I> oem authentication of cpubl-dtb header done[0000.640] I> cpubl-dte
[0000.641] I> cpubl-dtb: Authentication init Done[0000.643] I> parsing oem signe
[00.643] I> eks binary init read from storage
[0000.644] I> cpubl-dtb: Authentication Finalize Done
[0000.645] I> o authentication of eks header done
[0000.648] I> eks binary de read from storage
[0000.653] I> eks: Authentication init Done
[0000.656] I> eks: Authentication Finalize Done
[00.661] I> EKB detected (length: 0x410) @ VA:0x5270a400
��NOTI: BL31: v1.3(release):23b153a63
NOTICE: BL31: Built : 11:54:09, Dec 16 2019
ipc-unittest-main: 1519: Welcome to I unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-untest-srv: 329: Init unittest services!!!
keystore-demo: 141: Hello world from keystore-demo app
keystordemo: 207: main: EKB contents match expected value
exit calle thread 0xffffffffea88ed58, name trusty_app_2_7d18fc60-e9fc-11e8
platform_bootstrap_epilog: trusty bootstrap complet
welcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
inializing platform
bpmp: platform_init
tag is c1b4e372932429f2737cf722e1219e71
tag_show initialize
dt initialized
mail initialized
chipid initialized
fuse inialized
sku initialized
speedo initialized
ec_get_ec_list: fnd 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 nitors
vmon initialized
adc initialized
fmon_populate_monits: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
392 clocks registed
WARNING: pll_c4 has no dyn ramp
clk_mrq_init: mrq handler gistered
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 contller initialized
initialized i2c mrq handling
i2c initialize
regulator initialized
avfs_clk_platform initialized
soctherm initialized
aotag inialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: node not found
tj_init initialized
uphy_mrq_init: mrq handl registered
uphy_dt initialized
uphy initialized
safereg initialized
�mrq initializedWelcome to Cboot
fmon_post initialized
��[0001.075] I> Cbootersion: t194-8a9e8a5a
[0001.075] I> CPU-BL Params @ 0xf2820000
[0001.075] I> 0) Base:0x00000000 Size:0x00000000
001.077] I> 1) Base:0xf1100000 Size:0x00100000
[0001.081] I>2) Base:0xf2000000 Size:0x00200000
[0001.086] I> 3) Base:0xf1200000 Size:0x00200000
[0001.090] I> 4) Base:0xf10000 Size:0x00100000
[0001.095] I> 5) Base:0xf0f00000 Size:0x000000��clk_dt_late initialized
machine_check initialized
pm_post initialized
dbells initialized
avfs_clk_platform_st initialized
dmce initialized
cvc initialized
ccplex_avfsw_init: nafll_cluster0: not monitored
ccplex_avfs_hw_init: nafll_cluster1: not monitored
ccplex_avfs_hw_init: nafllluster2: not monitored
ccplex_avfs_hw_init: nafll_cluster3: n monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermalest initialized
serial_late initialized
clk_post initializedclk_dt_post initialized
mc_reg initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
sedo_debugfs initialized
adc_debugfs initialized
clk_debugfs itialized
[0001.164] I> 6) Base:0xf3800000 Size:0x00400000
0001.173] I> 8) Base:0xf0e00000 Size:0x001000000
[0001.177] I 9) Base:0xf0d00000 Size:0x00100000��emc_debugfs initialized
dvs_debugfs initialized
[0001.186] I> 10) Base:0xf00000 Size:0x00800000��fmon_debugfs initialized
vmon_debugfs itialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile inialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_bugfs initialized
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fsnitialized
debugfs_mrq initialized
debug_mrq initialized
deg_safereg initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
] ��[0001.237] I> 11) Base:0x40000000 Size:0x00040000
[0001.241] 12) Base:0xf0c00000 Size:0x00100000
[0001.246] I> 13) Base:0x40046000 Size:0x00002000
[0001.250] I> 14) Base:0x400000 Size:0x00002000
[0001.255] I> 15) Base:0xac000000 Size:0x004000
[0001.259] I> 16) Base:0x4004a000 Size:0x00002000
[0001.264] I> 17) Base:0xf0b00000 Size:0x00100000
[0001.8] I> 18) Base:0x4004c000 Size:0x00002000
[0001.273] I> 19) Be:0xf2200000 Size:0x00600000
[0001.277] I> 20) Base:0x4004e000 Size:0x00002000
[0001.282] I> 21) Base:0xf09d0000 Si:0x0000c000
[0001.286] I> 22) Base:0x00000000 Size:0x00000000[0001.290] I> 23) Base:0xf09e00
[0001.295] I> 24) Base:0xf6000000 Size:0x02000000
[0001.299] I> 2 Base:0x40050000 Size:0x00002000
[0001.304] I> 26) Base:0x400000 Size:0x00006000
[0001.308] I> 27) Base:0xf1800000 Size:0x00400000
[0001.313] I> 28) Base:0xf4c00000 Size:0x014000
[0001.317] I> 29) Base:0xf1400000 Size:0x00400000
[0001.3] I> 30) Base:0xf0a00000 Size:0x00100000
[0001.326] I> 31) Base:0x00000000 Size:0x00000000
[0001.331] I> 32) Base:08000000 Size:0x08000000
[0001.335] I> 33) Base:0x00000000 Siz0x00000000
[0001.340] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.344] I> 35) Base:0xab000000 Size:0x01000000
[00.348] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.353] I> 37Base:0xf2800000 Size:0x00800000
[0001.357] I> 38) Base:0x80000000 Size:0x20000000
[0001.362] I> 39) Base:0xb0000000ize:0x08000000
[0001.366] I> 40) Base:0x00000000 Size:0x000000
[0001.371] I> 41) Base:0x00000000 Size:0x00000000
[0001.375] I> 42) Base:0x00000000 Size:0x00000000
[0001.380] 43) Base:0x00000000 Size:0x00000000
[0001.384] I> 44) Base:00000000 Size:0x00000000
[0001.389] I> 45) Base:0x00000000 Size:0x00000000
[0001.393] GIC-SPI Target CPU: 0
[0001.3] Interrupts Init done
[0001.399] calling constructors
[000102] initializing heap
[0001.404] I> Heap: [0xa0690588 … 0xab000000]
[0001.409] initializing threads
[0001.412] itializing timers
[0001.414] creating bootstrap completion thrd
[0001.419] top of bootstrap2()
[0001.422] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.426] initializing platfm
[0001.429] E> DEVICE_PROD: Invalid value data = 0, size = 0
[0001.435] W> deviced
[0001.438] I> Bl_dtb @0xaaf00000
[0001.445] E> “plugin-manager” doesn’t ist, creating
[0001.446] E> “ids” doesn’t exist, creating
[01.451] E> “connection” doesn’t exist, creating
[0001.455] E> “configs” doesn’t exist, creating
[0001.467] I> Find /c@3160000’s alias i2c0
[0001.467] I> Reading eeprom i2c=0 addss=0x50
[0001.493] I> Device at /i2c@3160000:0x50
[0001.493] I> Reading eeprom i2c=0 address=0x56
[0001.517] I> Device at /i2c@3160000:0x56
[0001.520] I> Find 2c@3180000’s alias i2c2
[0001.520] I> Reading eeprom i2c=2 address=0x54
[0001.522] E> I2C: slave not found in slaves.
[01.522] E> I2C: Could not write 0 bytes to slave: 0x00a8 with peat start true.
[0001.523] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.524] E> I2C_DEV: Could noread 256 registers of size 1 from slave 0xa8 at .
[0001.532] E> eeprom: Failed to read I2C slave device
[0001.536] I> Eeprom read failed 0x3526070d
[000140] I> Reading eeprom i2c=2 address=0x57
[0001.545] E> I2C: sve not found in slaves.
[0001.549] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start t.
[0001.7] E> I2C_DEV: Failed to send register address 0x00000000.
[01.562] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at .
[0001.572] Eeeprom: Failed to read I2C slave device
[0001.576] I> Eeprom ad failed 0x3526070d
[0001.580] I> Reading eeprom i2c=2 address=0x52
0001.589] E> I2C: Could not write 0 bytes to slave: 0x00a4 witrepeat start true.
[0001.597] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.602] E> I2C_DEV: Could t read 256 registers of size 1 from slave 0xa4 at .
[0001.612] E> eeprom: Failed to read I2C slave device
[0001.617] I> Eeprom read failed 0x3526070d
[00.622] I> Find /i2c@c240000’s alias i2c1
[0001.625] I> Readingeprom i2c=1 address=0x52
[0001.630] E> I2C: slave not found in slaves.
[0001.633] E> I2C: Could not write 0 bytes tslave: 0x00a4 with repeat start tru.
[0001.641] E> I2C_DEV: iled to send register address 0x00000000.
[0001.646] E> I2C_DEV: Could not read 256 registers of size 1 from slave 04 at .
[0001.656] E> eeprom: Retry tread I2C slave device.
[0001.661] E> I2C: slave not found in slaves.
[0001.665] E> I2C: Could not write 0 bytes tolave: 0x00a4 with repeat start tru.
[0001.673] E> I2C_DEV: Fled to send register address 0x00000000.
[0001.678] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0x at .
[0001.688] E> eeprom: Failed tread I2C slave device
[0001.692] I> Eeprom read failed 0x3526070d
[0001.696] I> Reading eeprom i2c=1 address=0x50
001.701] E> I2C: slave not found in slaves.
[0001.705] E> I2CCould not write 0 bytes to slave: 0x00a0 with repeat start tru.
[0001.713] E> I2C_DEV: Failed to send register addrs 0x00000000.
[0001.718] E> I2C_DEV: Could not read 256 regisrs of size 1 from slave 0xa0 at .
[0001.728] E> eeprom: Retry to read I2C slave device.
[01.733] E> I2C: slave not found in slaves.
[0001.737] E> I2C: uld not write 0 bytes to slave: 0x00a0 with repeat start tru.
[0001.745] E> I2C_DEV: Failed to send register addres0x00000000.
[0001.750] E> I2C_DEV: Could not read 256 registe of size 1 from slave 0xa0 at .
[0001.760] E> eeprom: Failed to read I2C slave device
[00.764] I> Eeprom read failed 0x3526070d
[0001.768] I> create_pids: id: 2888-0004-400-K, len: 15
[0001.774] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:03
[0001.785] I> createm_ids: id: 2822-0000-700-K, len: 15
[0001.790] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:03
[0001.801] I> Addi plugin-manager/ids/2888-0004-400=/i2c@3160000:module@0x50
[0001.808] E> “i2c@3160000” doesn’t exist, creating
[000812] E> “module@0x50” doesn’t exist, creating
[0001.817] I> Aing plugin-manager/ids/2822-0000-700=/i2c@3160000:module@0x56
[0001.824] E> “module@0x56” doesn’t exist, creating
[01.832] I> Adding plugin-manager/cvm
[0001.833] E> “chip-id” esn’t exist, creating
[0001.837] I> Adding plugin-manager/chip-id/A02P
[0001.841] I> Plugin-manager override startg
[0001.846] I> node /plugin-manager/fragement-tegra-wdt-en mches
[0001.856] I> node /plugin-manager/fragement-soft-wdt matches
[0001.864] I> node /plugin-manager/fragment-pcie5-rp matches
[0001.868] I> node /plugin-manager/fragment-tegrufs-lane10 matches
[0001.880] I> Disable plugin-manager status in FDT
[0001.880] I> Plugin-manager override finishesuccessfully
[0001.881] I> gpio framework initialized
[0001.3] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra194-gpio’ driver
[0001.891] I> tegrabl_gpio_driver_registe register ‘nvidia,tegra194-gpio-aon’ dr
[0001.897] I> tegbl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0001.904] E> fetch_driver_phandle_from_dt: failed to get node with coatible ti9
[0001.912] E> fetch_driver_phandle_from_dt:ailed to get node with compatible nx9
[0001.919] W> tegrabl_tca9539_init: failed to fetch phandle from dt
0001.932] E> fetch_driver_phandle_from_dt: failed to get node with compatible t9
0001.946] W> tegrabl_tca9539_init: failed to fetch phandle from dtcompatible nx9
[0001.954] I> fixed regulator driver initialized[0001.968] I> register ‘maxim’ e
[0001.969] I>irtual i2c enabled
[0001.969] I> registered ‘maxim,max20024’ pmic
[0001.970] I> tegrabl_gpio_driver_register: regisr ‘max20024-gpio’ driver
[0001.975] I> Boot-device: eMMC
[00.978] I> Boot_device: SDMMC_BOOT instance: 3
[0001.987] I> sdmmc-3 params source = boot args
[0001.987] I> sdmmc bd is already initialized
[0001.991] I> sdmmc-3 params source =oot args
[0002.022] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0002.034] I> Found 42 partitio in SDMMC_USER (instance 3)
[0002.045] I> enabling ‘vdd-hdmi-5v0’ regulator
[0002.050] I>egulator ‘vdd-hdmi-5v0’ already enabled
[0002.051] E> tegrabl_display_init_regulator: hdmi cable is not connected[0002.s
[0002.056] E> invalid display type
[0002.061] E> invalid display type
[0002.062] E> cannot find any other nvsp nodes
[0002.062] E> no valid display unit config found in b
[0002.064] W> display init failed
[0002.064] I> Load in CBoot Boot Options partition and parse it
[0002.067] E> nnot read beyond partition boundary for CPUBL-CFG
[0002.073] tegrabl_read_cbo Failed to read CPUBL-CFG partition
[0002.079] W> platform_init: tegrabl_read_cbo failed with errorxd0d0104
[0002.086] I> Hit any key to stop autoboot: 4 3 2 1
[0004.093] initializing target
[0004.093] calling apps_in()
[0004.094] starting app kernel_boot_app
[0004.113] I> found decompressor handler: lz4-legacy
[0004.11 I> decompressing BMP blob …
[0004.119] I> Kernel type = Normal
[000419] I> Loading partition kernel-bootctrl at 0xa42b0000 from dece(0x1)
[0004.126] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0004.126] W> tegrabl_get_keel_bootctrl: use default dummy boot control data
[0004.127] I########## SD boot ##########
[0004.127] I> No sdcard
[0004.127] I> -0 params source =
[0004.130] E> Blockdev ope exit error
[0004.134] E> SD boot failed, err: 724238353
[00.138] I> ########## USB boot ##########
[0004.147] W> No valid slot number is found in scratch register
[0004.148] Return default slot: _a
[0004.163] I> USB Firmware Version: .06 release
[0004.220] I> regulator of usb2-0 already enabled
[0004.229] regulator of usb2-1 already enabled
[0004.238] I> regulator of usb2-2 already enabled
[0004.249] I> enabling ‘vdd-5v-sata’ regulator
[0005.256] E> failed to initialize xhci controller
[0005.256] E> ror in init of XUSB host driver, err: 79790026
[0005.256] E> iled to initialize device 5-0
[0005.257] E> USB boot failed, err: 2037973030
[0005.257] I> ########## Fixed storageoot ##########
[0005.257] I> Already published: 00010003
[00.258] I> Look for boot partition
[0005.261] I> Fallback: assuming 0th partition is boot partition
[0005.267] I> Dett filesystem
[0005.294] I> Loading extlinux.conf …
[0005.2] I> rootfs path: /sdmmc_user/boot/extlinux/extlinux.conf
[0005.331] I> L4T boot options
[0005.331] I> [1]: “primary kernel”
[0005.332] I> Enter choice:
[0008.333] I> Continuing with default option: 1
[0008.333] Loading kernel sig file from rootfs …
[0008.333] I> rootfsath: /sdmmc_user/boot/Image.sig
[0008.352] I> Loading kernel bary from rootfs …
[0008.352] I> rootfs path: /sdmmc_user/boot/Image
[0008.572] I> Validate kernel …
[0008.572] I> T19x: Authentate kernel (bin_type: 37), max size 0x5000000
[0008.914] I> No kernel-dtb binary path
[0008.914] I> Loadingernel-dtb binary from partition …
[0008.915] W> No valid slotumber is found in scratch register
[0008.915] W> Return defau slot: _a
[0008.915] I> A/B: bin_type (38) slot 0
[0008.916] I> Loading partition kernel-dtb at 0x91000000 from deve(0x1)
[0008.925] I> Validate kernel-dtb …
[0008.925] I> Tx: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0008.931] I> Loading ramdisk from rootfs …
[0008.93 I> rootfs path: /sdmmc_user/boot/initrd
[0008.985] I> Kernel hdr @0xa42b0000
[0008.985] I> Kernel dtb0x90000000
[0008.986] I> decompressor handler not found
[000986] I> Copying kernel image (34191376 bytes) from 0xa42b0000 to 0x80080000e
[08.994] I> Updated bpmp info to DTB
[0008.995] I> Ramdisk: Bas 0x92000000; Size: 0x54eadd
[0008.996] I> Updated initrd info to DTB
[0008.996] W> WARN: Fail to override “console=ne” in commandline
[0008.998] E> tegrabl_linuxboot_add_disp_pam, du 0 failed to get display params
[0009.005] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display pams
[0009.013] E> tegrabl_linuxboot_add_disp_param, du 0 faileto get display params
[0009.020] W> No valid slot number is found in scratch register
[0009.026] W> Return default ot: _a
[0009.029] I> Active slot suffix:
[0009.032] I> add_ot_slot_suffix: slot_suffix =
[0009.037] I> Linux Cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 co
[0009.070] I> Updated bootarg info to DTB
[0009.074] W> MAC addr valid!
[0009.077] E> Failed to get WIFI MAC address
[0009.08 W> MAC addr invalid!
[0009.084] E> Failed to get Bluetooth MAC address
[0009.088] I> eeprom_get_mac_addr: MAC (ty: 2): 48:b0:2d:05:af:1f
[0009.095] E> “plugin-manager” doesn’exist, creating
[0009.100] I> Adding /chosen/plugin-manager/cvm
[0009.104] E> “chip-id” doesn’t exist, creating
[09.108] I> Adding /chosen/plugin-manager/chip-id
[0009.113] E>configs" doesn’t exist, creating
[0009.117] I> Adding /chosen/plugin-manager/configs
[0009.121] E> “ids” doesn’t ext, creating
[0009.125] I> Adding /chosen/plugin-manager/ids
009.130] E> “odm-data” doesn’t exist, creating
[0009.134] I> Adding /chosen/plugin-manager/odm-data
[0009.143] E> “mory” doesn’t exist, creating
[0009.144] I> [0] START: 0x800000, END: 0xac000000
[0009.148] I> [1] START: 0xac004000, END: 0xf09d0000
[0009.152] I> [2] START: 0xf09dc000, END: f09e0000
[0009.157] I> dram_block larger than 80000000
[000961] I> [3] START: 0x100000000, END: 0x880000000
[0009.166] I> added [base:0x80000000, size:0x2c000000] to /memory
[09.172] I> added [base:0xac200000, size:0x44600000] to /memory[0009.178] I> ady
[0009.185] I> Updated memory info to DTB
[0009.8] E> add_disp_param: failed to get display params for du=0
[09.194] E> “reset” doesn’t exist, creating
[0009.199] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0009.203] I> Enabd cpu-0 (mpidr: 0x0) node in FDT
[0009.207] I> NVG: Logical C: 1; MPIDR: 0x80000001
[0009.212] I> Enabled cpu-1 (mpidr: 0x1) node in FDT
[0009.217] I> NVG: Logical CPU: 2; MPID 0x80000100
[0009.221] I> Enabled cpu-2 (mpidr: 0x100) node iFDT
[0009.226] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0009.231] I> Enabled cpu-3 (mpidr: 0x101) node in FDT
[09.236] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0009.241] IEnabled cpu-4 (mpidr: 0x200) node in FDT
[0009.246] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0009.250] I> Enabledpu-5 (mpidr: 0x201) node in FDT
[0009.255] I> NVG: Logical CP 6; MPIDR: 0x80000300
[0009.260] I> Enabled cpu-6 (mpidr: 0x300) node in FDT
[0009.265] I> NVG: Logical CPU: 7; MPI: 0x80000301
[0009.270] I> Enabled cpu-7 (mpidr: 0x301) node FDT
[0009.276] E> “misc-data” doesn’t exist, creating
[0009.279] I> Boot-device: eMMC
[0009.282] I> Add boot-sdm to plugin-manager/misc-data
[0009.287] I> Add storage-sdmmc plugin-manager/misc-data
[0009.292] W> Unknown storage device
[0009.296] I> Add serial number:1421920068312 as DT operty
[0009.303] I> Plugin-manager override starting
[0009.6] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0009.313] I> node /plugin-manager/fragement-soft-wdt matcs
[0009.321] I> node /plugin-manager/fragment-pcie-c5-rp matcs
[0009.325] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0009.339] I> Disable plugin-manager status FDT
[0009.339] I> Plugin-manager override finished successfuy
[0009.341] I> tegrabl_load_kernel_and_dtb: Done
[0009.343] E> tegrabl_display_clear: display is not initialized
009.348] W> Boot logo display failed…
[0009.352] I> Kernel : 0x80080000, DTB: 0x90000000
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140egra (buildbrain@mobile-u64-2390-d3000) (gc9
[ 0.000000] Boot CPU: AArch64 Pcessor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 2c000000
[ 0.000000] OF: fdt: - ac200000 , 44600000
[ 0.000000] OF: fdt: - 100000000 , 780000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (tions ')
[ 0.000000] bootconsole [tegra_comb_uart0] enabl
[ 6.423990] cgroup: cgroup2: unknown option “nsdelegate”
[ 7.891751] using random self ethernet address
[ 7.8918] using random host ethernet address
Ubuntu 20.04.3 LTS root1-desktop ttyTCU0
root1-desktop login: [ 25.411824] random: crng init done
[ 25.412003] random: urandom warning(s) missed due to ratelimiting
The flash process didn’t succeed.
It stuck in this line.
2.8056 ] tegrarcm_v2 --download mb2 nvtboot_applet_t194_sigheader.bin.encrypt
[ 2.8066 ] Applet version 01.00.0000
[ 2.9353 ] Sending mb2
[ 2.9355 ] […] 100%
[ 3.0942 ]
[ 3.0979 ] tegrarcm_v2 --boot recovery
[ 3.0991 ] Applet version 01.00.0000
[ 3.2795 ]
[ 4.2826 ] tegrarcm_v2 --isapplet
[ 4.4206 ]
[ 4.4228 ] tegrarcm_v2 --ismb2
[ 4.4237 ] MB2 Applet version 01.00.0000
Are you sure the sdkmanager GUI told you that the flash is finished with success?
This time the process ended unsuccessfully.
Please also share log. It is not possible to help you just with one comment “ended unsuccessfully”.
Also, is your ubuntu host a VM?
My host is Virtual Box Ubuntu 18.04 on MacBook Pro.
SDK Manager log pinned as zip file here - Revert back to version Ubuntu 18 instead Ubuntu 20 - #12 by user23343
SDKM does not support VM or VB. Please try with native ubuntu 18.04 host.
