Revit Connector 203.0: Incorrect Mesh Transforms in Unreal Engine
Hello NVIDIA Omniverse Team,
I am investigating a change in the USD transformation hierarchy between NVIDIA Omniverse Revit Connector versions 202.1 and 203.0.
Environment
  • Autodesk Revit 2024
  • NVIDIA Omniverse Revit Connector 202.1 and 203.0
  • USD format: USDA
  • Target application: Unreal Engine
  • Comparison application: NVIDIA Omniverse USD Composer
    I exported the same Revit 2024 model using NVIDIA Omniverse Revit Connector 202.1 and 203.0 and compared the resulting USDA files.
    1. Transformation hierarchy
    In the 202.1 export, the transform is authored directly on the Mesh prim:
    Xform
    └── Mesh
        └── xformOp:transform (property)
    In the 203.0 export, the transform is authored on the parent Xform prim:
    Xform
    ├── xformOp:transform (property)
    └── Mesh
    When I import the USD exported using Connector 203.0 into Unreal Engine, some child meshes are placed incorrectly or appear repositioned toward the centre of the model. The same exported USD appears correctly positioned in USD Composer.
    Questions
    1. Is moving the transform from the Mesh prim to its parent Xform an intentional change in Connector 203.0?
      Omni Connector 202.1 Exported USD file.zip (4.5 MB)
      Omni Connector 203.0 Exported usd file.zip (54.2 MB)
    2. Could this hierarchy change affect how Unreal Engine’s USD importer interprets mesh transforms or world-space placement?
    3. Is there a documented migration note, known compatibility issue, or recommended workaround for applications that import USD exported by Connector 203.0?
    4. Is there a recommended way to preserve the same transformation behaviour in Unreal Engine as in USD Composer?
      I Have provided sample USDA files exported with both connector versions, along with Recording demonstrating the difference in mesh placement.
      I would appreciate clarification on the expected USD hierarchy and whether any changes are required on the importer side.
      Thank you.
