I’m developing FPGA parallel to CSI bridge based on Lattice csi2tx reference design. I tried their YUV example project but TX1 didn’t recognize it (packet header multi-bit error). When I tried RGB example everything is working (including v4l-ctl). I want to encode x264, but for this I need to convert BGRA to format supported by encoder (I420,NV12) (I have no idea where RGB888 becomes AR24 (BGRA), because in driver I set Pixel format to RGB888, but v4l-ctl reports:
v4l2-ctl --all
Driver Info (not using libv4l2):
Driver name : tegra-video
Card type : vi-output, kmtifpga 6-0036
Bus info : platform:54080000.vi:0
Driver version: 4.4.38
Capabilities : 0x84200001
Video Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04200001
Video Capture
Streaming
Extended Pix Format
Priority: 2
Video input : 0 (Camera 0: ok)
Format Video Capture:
Width/Height : 800/480
Pixel Format : 'AR24'
Field : None
Bytes per Line : 3328
Size Image : 1597440
Colorspace : sRGB
Transfer Function : Default
YCbCr Encoding : Default
Quantization : Default
Flags :
Camera Controls
frame_length (int) : min=0 max=32767 step=1 default=1984 value=1984 flags=slider
coarse_time (int) : min=2 max=32761 step=1 default=1978 value=1978 flags=slider
coarse_time_short (int) : min=2 max=32761 step=1 default=1978 value=1978 flags=slider
group_hold (intmenu): min=0 max=1 default=0 value=0
hdr_enable (intmenu): min=0 max=1 default=0 value=0
otp_data (str) : min=0 max=1024 step=2 value='8009057dc0ffffff00c028fbc0ffffff001e00fbc0ffffffc08040020000000090f928fbc0ffffff40b90c00c0ffffffc0f928fbc0fffffff8efb200c0ffffff5898037dc0ffffff8009057dc0ffffff07209a00000000000200000000000000d0f928fbc0ffffff40b90c00c0ffffff00fa28fbc0fffffff8efb200c0ffffff5898037dc0ffffff01000000000000000700000000000000010000000000000020fa28fbc0ffffff9c0d7a00c0ffffff01000000000000005898037dc0fffffff0fa28fbc0ffffff900f7a00c0ffffffc8ff3a01c0ffffff0000000000000000000000000000000000000000000000005898037dc0ffffff000000000000000005209a000000000000000000000000001898037dc0ffffff1812037dc0ffffffb8260801c0ffffff20130801c0ffffff20fb28fb07209a000000000000000000b0fa28fbc0ffffff40b90c00c0ffffffe0fa28fbc0ffffff54901b00c0ffffffd0fa28fbc0ffffff40b90c00c0ffffff00fb28fbc0fffffff8efb200c0ffffff5898037dc0ffffffc89e037dc0ffffff002e057dc0ffffffd0f05f00c0ffffff10fb28fbc0ffffffb4fa7900c0ffffff20fb28fbc0ffffffb0fb7900c0ffffff60fb28fbc0ffffffe4177900c0ffffff0000000000000000c89e037dc0ffffff002e057dc0ffffff208ccdf9c0ffffff48003b01c0ffffff5898037dc0ffffff' flags=read-only, has-payload
fuse_id (str) : min=0 max=16 step=2 value='5898037dc0ffffff' flags=read-only, has-payload
gain (int) : min=256 max=4096 step=1 default=256 value=256 flags=slider
bypass_mode (intmenu): min=0 max=1 default=0 value=0
override_enable (intmenu): min=0 max=1 default=0 value=0
height_align (int) : min=1 max=16 step=1 default=1 value=1
size_align (intmenu): min=0 max=2 default=0 value=0
write_isp_format (bool) : default=0 value=0
I have tried this pipeline and it works (I get flashing video but I think this is due high frame rate generated by FPGA 130fps and CPU cant convert video fast enough)
gst-launch-1.0 -v v4l2src device=/dev/video0 ! 'video/x-raw, format=(string)BGRA, width=(int)800, height=(int)480, framerate=(fraction)30/1' ! videoconvert ! 'video/x-raw, format=(string)NV12' ! omxh264enc ! qtmux ! filesink location=test.mp4 -ev
So my question is what pipeline should I use for nvvideconv?
