RGMII and RTL8211FI-CG
HI NVIDIA,
On R36.4.4, following DevGuide we are able to enable RTL8211.
Following is the relevant kernel message
[    9.000824] nvethernet 2310000.ethernet: Adding to iommu group 48
[    9.003727] nvethernet 2310000.ethernet: failed to read skip mac reset flag, default 0
[    9.003731] nvethernet 2310000.ethernet: failed to read MDIO address
[    9.003734] nvethernet 2310000.ethernet: Failed to read nvida,pause_frames, so setting to default support as disable
[    9.003737] nvethernet 2310000.ethernet: setting to default DMA bit mask
[    9.252386] nvethernet 2310000.ethernet: Ethernet MAC address: 20:46:a1:0c:30:dd
[    9.307331] nvethernet 2310000.ethernet: macsec parameter is missing or disabled
[    9.307335] nvethernet 2310000.ethernet: Macsec not supported/Not enabled
[    9.308793] nvethernet 2310000.ethernet: eth0 (HW ver: 53) created with 8 DMA channels
On R39.2.0, with the same configuration, RTL8211 does not work:
[    6.418877] nvethernet 2310000.ethernet: Adding to iommu group 47
[    6.419030] nvethernet 2310000.ethernet: Virtualization is not enabled
[    6.419036] nvethernet 2310000.ethernet: failed to read skip mac reset flag, default 0
[    6.419039] nvethernet 2310000.ethernet: failed to read MDIO address
[    6.419043] nvethernet 2310000.ethernet: Failed to read nvida,pause_frames, so setting to default support as disable
[    6.419045] nvethernet 2310000.ethernet: Failed to read nvida,disable-rx-checksum, so setting to default - rx checksum offload enabled
[    6.419047] nvethernet 2310000.ethernet: setting to default DMA bit mask
[    6.419055] nvethernet 2310000.ethernet: failed to read UPHY GBE mode- default to 1G
[    6.419228] nvethernet 2310000.ethernet: failed to read or invalid MDC CR - default to 6
[    6.419232] nvethernet 2310000.ethernet: failed to read or invalid force-restart-lane-bringup - default to 0
[    6.687658] nvethernet 2310000.ethernet: macsec parameter is missing or disabled
[    6.687671] nvethernet 2310000.ethernet: Macsec not supported/Not enabled
[    6.689132] nvethernet 2310000.ethernet: eth0 created with 8 DMA channels
[    6.723361] nvethernet 2310000.ethernet lan1: renamed from eth0
[    9.992292] nvethernet 2310000.ethernet: IVC channel not reserved - virtualization disabled
[   10.635550] nvethernet 2310000.ethernet: failed to connect PHY
If we upgrade from R36.4.4 to R39.2.0 without disconnecting the power supply, then the Ethernet port will still work. But once we disconnect the power supply, the port will not work anymore. Any ideas?
what is the power supply here? Supply power to what item here? Orin AGX?
By disconnecting power supply I mean turn off power.
Could you elaborate what is the timing that you power of things here?
And what if you don’t power off board but using something else like reboot, will it become different?
What is the method you “upgrade” the BSP here?
  1. Flash R36.4.4 with l4t_initrd_flash.sh. Ethernet port works.
  2. Enter recovery mode by pressing reset and recovery button. Then flash R39.2.0 with l4t_initrd_flash.sh. Ethernet port still works.
  3. Power the system off. Turn off power. Turn on power. And then boot the system. Ethernet stops working.
Without turn off the power, the port always works.
So you have configured the pinmux and kernel DT?
How about your shared those out for review?
		eqos: ethernet@2310000 {
			status = "okay";
			nvidia,phy-reset-gpio = <&gpio TEGRA234_MAIN_GPIO(G, 5) 0>;
			nvidia,max-platform-mtu = <16383>;
			nvidia,mac-addr-idx = <0>;
			phy-mode = "rgmii-id";
			phy-handle = <&phy>;
			mdio {
				compatible = "nvidia,eqos-mdio";
				#address-cells = <1>;
				#size-cells = <0>;
				phy: phy@1 {
					reg = <1>;
					nvidia,phy-rst-pdelay-msec = <224>; /* msec */
					nvidia,phy-rst-duration-usec = <10000>; /* usec */
					interrupt-parent = <&gpio>;
					interrupts = <TEGRA234_MAIN_GPIO(G, 4) IRQ_TYPE_LEVEL_LOW>;
			eqos_txc_pe0 {
				nvidia,pins = "eqos_txc_pe0";
				nvidia,function = "eqos";
				nvidia,pull = <TEGRA_PIN_PULL_NONE>;
				nvidia,tristate = <TEGRA_PIN_DISABLE>;
				nvidia,enable-input = <TEGRA_PIN_DISABLE>;
			eqos_td0_pe1 {
				nvidia,pins = "eqos_td0_pe1";
			eqos_td1_pe2 {
				nvidia,pins = "eqos_td1_pe2";
			eqos_td2_pe3 {
				nvidia,pins = "eqos_td2_pe3";
			eqos_td3_pe4 {
				nvidia,pins = "eqos_td3_pe4";
			eqos_tx_ctl_pe5 {
				nvidia,pins = "eqos_tx_ctl_pe5";
			eqos_rd0_pe6 {
				nvidia,pins = "eqos_rd0_pe6";
				nvidia,pull = <TEGRA_PIN_PULL_UP>;
				nvidia,tristate = <TEGRA_PIN_ENABLE>;
				nvidia,enable-input = <TEGRA_PIN_ENABLE>;
			eqos_rd1_pe7 {
				nvidia,pins = "eqos_rd1_pe7";
			eqos_rd2_pf0 {
				nvidia,pins = "eqos_rd2_pf0";
			eqos_rd3_pf1 {
				nvidia,pins = "eqos_rd3_pf1";
			eqos_rx_ctl_pf2 {
				nvidia,pins = "eqos_rx_ctl_pf2";
			eqos_rxc_pf3 {
				nvidia,pins = "eqos_rxc_pf3";
			eqos_sma_mdio_pf4 {
				nvidia,pins = "eqos_sma_mdio_pf4";
			eqos_sma_mdc_pf5 {
				nvidia,pins = "eqos_sma_mdc_pf5";
			soc_gpio17_pg4 {
				nvidia,pins = "soc_gpio17_pg4";
				nvidia,function = "rsvd0";
				nvidia,lpdr = <TEGRA_PIN_DISABLE>;
			soc_gpio18_pg5 {
				nvidia,pins = "soc_gpio18_pg5";
Is it possible to probe the HW reset pin status ?
