Could you stop doing this “because you told me the pinmux might be wrong so I just changed it” thing?
Your flash log will tell which pinmux file got flashed. If you really cannot read, you could post out the log and we can tell you which file is in use.
Also, if this is a switch case, then your RGMII setting in the device tree is wrong.
There are other users sharing their expereince which you could check.
@WayneWWW why i am asking confirmation of dtsi files means.
eth1 is showing in ifconfig -a
eth1 is now showing in ifconfig there might be hardware problem also.
@WayneWWW I looked into hardware also i found Ethernet switch configured in SPI mode,We make changed into MIIM.
Now we are getting
[ 16.160535] nvethernet 2310000.ethernet: [poll_check][42][type:0x4][loga-0x0] poll_check: timeout
[ 16.160548] nvethernet 2310000.ethernet: ether_open: failed to initialize MAC HW core with reason -1 dmesg log.txt (6.6 KB)
we need to configure gpio,pinmux and dts file is correct
there is issue with reset pin issue hardware.
now i am able see the eth0 in ifconfig.
I checked with ethtool eth0 link status is ok.
Thank @WayneWWW but ping is not happens.if you have any idea on it please let me know
@WayneWWW can you refer any document i need to follow for pinging issue.
I configure the eth0 with ifconfig tool
ifconfig 192.168.1.90 netmask 255:255:255:0.
