Hello all,
So I have spent some time in the forums looking for topics with similar problems as me. It seems that a lot of people have had problems with getting the SDK/tool kit to work with some of their systems. I have tried every ‘solution’ I have seen, but the commands have not worked for me. It is possible that this is true because in the other cases a different distribution of linux was used. Specifically, I installed the SDK and toolkit in the default places following the ‘Getting Started’ pdf file. I would type make in the NVIDIA_CUDA_SDK directory and the first problem I had was with the build not being able to find the glu.h, gl.h files. Following advice on the forums I was able to fix this by running
[codebox]sudo yum install libxmu-dev libxi-dev[/codebox]
and I believe I ran more than just these. I seemed to have fixed the first problem, but now when I try to make the file I get the error:
[codebox]make -C projects/bitonic/
make[1]: Entering directory `/u/brose/NVIDIA_CUDA_SDK/projects/bitonic’
make[1]: Leaving directory `/u/brose/NVIDIA_CUDA_SDK/projects/bitonic’
make -C projects/marchingCubes/
make[1]: Entering directory `/u/brose/NVIDIA_CUDA_SDK/projects/marchingCubes’
/usr/bin/ld: cannot find -lXi
collect2: ld returned 1 exit status
[/codebox]
I have seen this error in other threads and it seems that maybe there is an incompatability issue? Any advice as to what is wrong and how I can fix it would be appreciated. P.S. If you can’t tell I am very new to linux.
