I’ve pulled isaac-sim 2022.1.1
X docker images --all
Emulate Docker CLI using podman. Create #etc#containers#nodocker to quiet msg.
REPOSITORY TAG IMAGE ID CREATED SIZE
nvcr.io#nvidia#isaac-sim 2022.1.1 f7b293669041 2 months ago 12.9 GB
I will be running this on rhel8.5.
When I try to start the image with the supplied script:
Request: Can you make a script that uses the native podman syntax?
Justification: RHEL 8.5 doesn’t allow docker and podman to be installed at the same time.
