Greetings, we’d like to use Red Hat Enterprise 3 as our CUDA platform.
This was the only platform supported during pre-beta, as I recall, but
the problem now is that building the SDK project examples requires
libraries that are not available on RHEL3. Suggestions? Workarounds?
(Report from our sysadmin below.)
JDO
The Display Driver, CUDA Toolkit, and CUDA SDK installations succeed on
our RHEL3 lab workstations, building the SDK project examples however
fail as follows:
bash-2.05b$ export PATH=${PATH}:/opt/cuda/bin
bash-2.05b$ export LD_LIBRARY_PATH=${LD_LIBRARY_PATH}:/opt/cuda/lib
make[1]: Entering directory `/tmp/tmetz/NVIDIA_CUDA_SDK/common’
ar qv ./…/lib/libcutil.a ./…/bin/obj/release/bank_checker.cpp_o
./…/bin/obj/release/cmd_arg_reader.cpp_o
nvcc -o …/…/bin/obj/release/bitonic.cu_o -c bitonic.cu -Xcompiler
“-m32” -Xcompiler “” -I. -I/opt/cuda/include -I…/…/common/inc -DUNIX -O3
nvcc: error while loading shared libraries: libstdc++.so.6: cannot open
shared object file: No such file or directory
make[1]: *** […/…/bin/obj/release/bitonic.cu_o] Error 127
make[1]: Leaving directory `/tmp/tmetz/NVIDIA_CUDA_SDK/projects/bitonic’
make: *** [projects/bitonic/Makefile.ph_build] Error 2
bash-2.05b$
It appears to require libstdc++.so.6 / gcc 3.4.5, which are not
available on RHEL3.
