[s]I’m trying out the new RHEL beta and trying to install NVIDIA-Linux-x86_64-331.20. I was able to build the module with --no-unified-memory, but after completing the setup, X segfaults with the following error:
This server has a video driver ABI version of 15.0 that is not supported by this NVIDIA driver.[/s]
Edit:
Got the Nvidia driver running properly under RHEL7 beta with the following driver -
Yeah, I didn’t know leigh123linux recommends disabling selinux! Maybe it’s not the same leigh as on fedoraforum.
Anyway, I’m not exactly sure what specific part SELinux blocks that would cause failure to start X server (maybe writeable memory?) with nvidia driver, but there’s a lot of different ways/options to handle SELinux without simply disabling it. As the first step, take a look at the xserver_selinux (8) manual page, which has a lot of pertinent information.
If you believe that SELinux is preventing X server to start, check your logs. This is an example from my system:
# grep -i selinux /var/log/Xorg.*
/var/log/Xorg.0.log:[ 2260.262] (II) SELinux: Disabled by boolean
/var/log/Xorg.9.log:[ 28.407] Initializing built-in extension SELinux
/var/log/Xorg.9.log:[ 28.912] (II) SELinux: Disabled by boolean
/var/log/Xorg.9.log.old:[ 9.398] Initializing built-in extension SELinux
/var/log/Xorg.9.log.old:[ 9.955] (II) SELinux: Disabled by boolean
Then, check the relevant Booleans. As I said, they are listed in detail and in greater number within the manpages ; as a simple example:
# getsebool -a |grep -i xserver
virt_use_xserver --> off
xserver_clients_write_xshm --> off
xserver_execmem --> off
xserver_object_manager --> off
Then, if you want to change the boolean permanently, do:
