β’ Hardware Platform (Jetson / GPU) β’ DeepStream Version β’ JetPack Version (valid for Jetson only) β’ TensorRT Version β’ NVIDIA GPU Driver Version (valid for GPU only) β’ Issue Type( questions, new requirements, bugs) β’ How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) β’ Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
no problem.
i have 2 bits of text that i want to show if the inference detects something.
on the left of a persons face i want to show βon phoneβ and on the right βfacemaskβ (detected)
and because the face changes inside the image, i would like to draw it inside the face-box and have it left aligned for one text and right aligned for the other text.
my question was if it was possible, then you ask what my use case is.
why donβt you just answer the question instead of passive aggressive βRight"sβ?
i know i can make an ugly solution with the current api, i was just expecting a bit more from nvidia and nvidia support, that is all.
I want to conform if the feature blocked you. I also want to know the use case to understand if it is one valueable feature we can add it in following DS release. Thanks for your sharing.
so to get back to the original question:
can you confirm that there currently is no way to find out either the width of the text ? or is there a different way to right align text ?
