Right-to-left language
**• Hardware Platform (Jetson / GPU)**gpu
• DeepStream Version7
• TensorRT Version8.6.1
**• NVIDIA GPU Driver Version (valid for GPU only)**t4
i tried to use right-to-left language in my labels.txt but i get some problems
when i add custom black box and i write my frame number on it(in arabic for example) it will display it in the right section of the whole frame and posiionning not work correctly
and when i change labels.txt to arabic it will not even show me than i can see only black box at the top of the detected faces(foreexample if our model is face detection)
Thanks for the sharing! I am investigating.
I can’t reproduce this issue on dgpu with DeepSream7.0. I set an arabic car name in label.txt. the result shows correctly. could you provide the detailed reproducing steps? Thanks!
labels.txt (36 Bytes)
idk how but you change label to left to right that is answering by issue but also creating new problem you jsut change it left to right and create another problem
I replaced the text “car” with the text “car” in arabic. please refer to the labels.txt.
could you elaborate on “creating new problem you jsut change it left to right and create another problem”?
could you share the detailed reproducing steps? Thanks!
