Riva 2.9.0 NMT does not produce translated output
Hardware - Nvidia A100
Hardware - AMD EPYC 7413
Operating System - Ubuntu 20.04.5
Riva Version - 2.9.0
TLT Version - N/a
How to reproduce the issue ? (This is for errors. Please share the command and the detailed log here)
python function, that does not produce error or output:
def send_nmt_request(self, text, target_lang):
	nmt_service = riva.client.NeuralMachineTranslationClient(self.auth)
	if target_lang == 'de-DE':
		model = 'en_de_24x6'
	elif target_lang == 'es-US':
		model = 'en_es_24x6'
	elif target_lang == 'zh-CN':
		model = 'en_zh_24x6'
	elif target_lang == 'ru-RU':
		model = 'en_ru_24x6'
	elif target_lang == 'fr-FR':
		model = 'en_fr_24x6'
	else:
		print(f'Model for language code ({target_lang}) not available')
		return None
	resp = nmt_service.translate(text, model=model, source_language="en-US", target_language=target_lang)
	print(f'Translation Response: {resp}')
	return resp
Attached are docker logs for riva. At the end of the file you can see that I tried twice with en → ru, and once with en → es. Both produced this error in docker logs and returned nothing to my python script.
docker_riva_logs.txt (52.5 KB)
Hi @armstrongsam25
Thanks for your interest in Riva
We will try to try this from our end, can you kindly share your config.sh used
config.sh (12.8 KB)
@rvinobha sorry, didn’t reply to your comment or @ you. My bad.
Hi @armstrongsam25
Apologies for the delay
Found the Cause if the problem
the text (even if a single sentence must be provided as a list)
I also faced the same issue when I passes the text as string, it returned empty response and attribute error in riva-speech logs
Passing text as list will resolve the issue and provide transcript
i.e first param text needs to be of type list
Please try and let me know if it works
Thanks for your patience
