zebleck
November 23, 2022, 8:00pm
1
Using Jetson Orin NGX 64GB
Operating System - Ubuntu 20.04.5 LTS
Riva Version - arm64 v2.7.0
TLT Version (if relevant)
How to reproduce the issue ? (This is for errors. Please share the command and the detailed log here)
Used the riva quick start guide for embedded systems found here: Quick Start Guide — NVIDIA Riva
Didnt modify config.sh
After starting riva_start.sh, it fails to load the models and stops after some time.
Included are all the relevant logs.
riva_start_logs.txt
riva_init_logs.txt
docker_logs.txt
config.sh
Hi @zebleck
Apologies you are facing issue
Thanks for sharing the logs and config,
Kindly request to share the Jetpack Version installed in your device
zebleck
November 24, 2022, 10:24am
3
Thank you for the quick response.
“cat /etc/nv_tegra_release” gives me:
# R34 (release), REVISION: 1.1, GCID: 30414990, BOARD: t186ref, EABI: aarch64, DATE: Tue May 17 04:20:55 UTC 2022
And “sudo apt-cache show nvidia-jetpack”:
Package: nvidia-jetpack
Version: 5.0.1-b118
Architecture: arm64
Maintainer: NVIDIA Corporation
Installed-Size: 194
Depends: nvidia-jetpack-runtime (= 5.0.1-b118), nvidia-jetpack-dev (= 5.0.1-b118)
Homepage: Autonomous Machines | NVIDIA Developer
Priority: standard
Section: metapackages
Filename: pool/main/n/nvidia-jetpack/nvidia-jetpack_5.0.1-b118_arm64.deb
SHA256: 78f182886cc85b6467f37e32553ee79adcf4aaf6b68031fe948f33cc8e008f92
SHA1: 3371de1f109f313379ed19f41a860fb60a555c86
MD5sum: 51cf5d858d2e533f063f3a7467bed6da
Description: NVIDIA Jetpack Meta Package
Description-md5: ad1462289bdbc54909ae109d1d32c0a8
zebleck
November 27, 2022, 7:06pm
5
had to update my jetpack from 5.0.1 to 5.0.2
system
Closed
December 12, 2022, 6:06am
7
