I am currently using riva-build and riva-deploy in the serrvicemaker docker to generate the models from the rmir files from the riva files download from the nvidia ngc.
I am currently working with TTS: HifiGan and Fastpitch for both male and female voices.
Riva-build executes correctly. Following with riva deploy:
riva-deploy servicemaker-dev/English-US-Female-1.rmir:<key_encode> data/models
I subsitute <key_encode> for the appropriate key, and am met with the following error:
File “src/opt/apollo/base/oled/samples/hello-world.py”, line 13, in
from demo_opts import get_device
File “/usr/local/lib/python3.6/dist-packages/demo_opts/init.py”, line 1, in
from .demo_opts import display_settings
File “/usr/local/lib/python3.6/dist-packages/demo_opts/demo_opts.py”, line 10, in
import Jetson.GPIO as GPIO
File “/usr/lib/python3/dist-packages/Jetson/GPIO/init.py”, line 1, in
from .gpio import *
File “/usr/lib/python3/dist-packages/Jetson/GPIO/gpio.py”, line 33, in
raise RuntimeError("The current user does not have permissions set to "
RuntimeError: The current user does not have permissions set to access the library functionalites. Please configure permissions or use the root user to run this
However, when I run the program a second time, Riva-deploy works and generates the models!
Could anyone clarify what is happening please?
Best regards
