Riva: Health Check Failed on Orin
Hardware - Orin AGX 64G
Riva Version: 2.12 - 2.14
JetPack: 5.1.1-b56
CUDA: 12.3.103
CuDNN: 8.6.0.166
TensorRT: 5.1.1
Python: 3.8.10
Ubuntu: 20.04
Release: 5.10.104-tegra
L4T: 35.3.1
I have no errors installing ngc, nvidia-container-toolkit, Docker and Riva, following instructions directly from official websites. While running bash riva_start.sh, I get the “health check failed” error, after retrying to load models for the given 30 trials. I followed the suggested fixes such as reboot, put false for nlp & nmt, use riva_clean.sh after riva_stop.sh, set gpu to 1 in config.sh, unlocking model_repository with chmod and re-installing same and different versions of Riva.
docker volume ls empty.
I attached logs for Riva logs that was on my terminal and config.sh (only changed nlp & nmt to false).
riva-speech.txt (61.4 KB)
riva_clean.txt (653 Bytes)
riva_start.txt (2.2 KB)
riva_init.txt (4.4 KB)
config.txt (18.1 KB)
Hi @sweatydog
Thanks for your interest in Riva
Can we try using
  • CUDA 11.8.89
And let us know if this problem gets resolved
