Riva python client API
The below link was referred for installing python-clients for Riva
While running the below script we are facing error:
python scripts/asr/transcribe_file.py
–input-file data/examples/en-US_AntiBERTa_for_word_boosting_testing.wav
–simulate-realtime
–show-intermediate
File “scripts/asr/transcribe_file.py”, line 6, in
import riva.client
File “/home/ubuntu/nvidia_riva/riva_quickstart_v2.5.0-1/python-clients/riva/client/init.py”, line 4, in
from riva.client.asr import (
File “/home/ubuntu/nvidia_riva/riva_quickstart_v2.5.0-1/python-clients/riva/client/asr.py”, line 15, in
import riva.client.proto.riva_asr_pb2 as rasr
ModuleNotFoundError: No module named ‘riva.client.proto.riva_asr_pb2’
Can you please suggest how to resolve this?
Hi @iamgarimanarang,
Could you please confirm if you are trying to run the script within the conda virtual environment created in step 1:
You can also try below NGC container to avoid system dependencies :
Hi Sunil,
Thanks for the response.
Is it required to use conda environment? Can we use python env instead?
Hi @iamgarimanarang
Thanks for your interest in Riva
We recommend using Conda environment,
In current env, we request to run the following command and share us the output
pip list
Hi @rvinobha
Tried with conda env as well. Getting the same error.
sharing the result for pip list below:
Package Version
certifi 2022.6.15
charset-normalizer 2.1.1
filelock 3.8.0
grpcio 1.49.1
grpcio-tools 1.49.1
huggingface-hub 0.10.0
idna 3.4
joblib 1.2.0
numpy 1.23.3
nvidia-riva-client 0.0.5
packaging 21.3
pip 22.1.2
protobuf 4.21.7
PyAudio 0.2.11
pyparsing 3.0.9
PyYAML 6.0
regex 2022.9.13
requests 2.28.1
scikit-learn 1.1.2
scipy 1.9.1
setuptools 61.2.0
six 1.16.0
threadpoolctl 3.1.0
tokenizers 0.12.1
tqdm 4.64.1
transformers 4.22.2
typing_extensions 4.3.0
urllib3 1.26.12
wheel 0.37.1
