Hello.
I have purchased a Rivermax based video ST-2110 using Mellnox Lx6 cards and the swicth time between multcast video input streams in the server takes more than 2 seconds. Could this time be normal?
I supose that the server needs to leave and report the new flows (video,audio, metadata) and decode the streams using CPU. However, more than two seconds seems excessive to me.
Do you have any reference or expected figures for the switching time when using Rivermax with software-based video decoding?
Pablo.
Hi Pablo,
Thanks for your question.
In order to provide performance related recommendations, we need more details about your setup, software and hardware versions, properly applied performance tuning, as well as about the particular scenario you are running (more information is at the following link Log in | NVIDIA Developer )
For this purpose we suggest you to open a new support case in Nvidia portal, and it will be handled according to the entitlement.
To Create a New Enterprise Support Case Please Use One of the Following Methods
Log in and Create a Case in the Enterprise Support Portal
AppHub UI
This is recommended and will provide the fastest response
Call your Regional Enterprise Support Number
Find your regional phone numbers:
NVIDIA Enterprise Customer Support
Create a Case Without a Login
EnterpriseSupport
Can be used to check warranty status
Recommended to reset login passwords
Requires validation and may increase time to respond
Best Regards,
Anatoly
