Rivermax sampleAPP FAILED (media_sender, media_receiver)
• Hardware Platform ( GPU) A30X,A100X
• RIVERMAX Version 1.10.20
• TensorRT Version 8.2.5.1
• NVIDIA GPU Driver Version (valid for GPU only) 510.39.01
• Issue Type questions
Now, we tried to execute RIVERMAX sample programs, media_sender, media_receiver.
We installed RIVERMAX SDK, got the license in advance.
Our server has two NIC as follows.
if-name IP ADDRESS
A30X ibp3s0f0 192.168.1.1
A100X ibp204s0f0 192.168.1.2
Both media _ sender and media _ receiver are running on the same server.
The runtime commands are:.
(1)media_sender
./media_sender -s ./sdps_samples/sdp.txt -m -f SeaWaves_1080p_50fps_10bits.ycbcr
(2)media_receiver
./media_receiver -m 224.1.1.1 -i 192.168.1.1 -p 2000 -s 192.168.1.2
However, all of the commands failed. Each error messages looks like follows:.
Please advise how to resolve these errors.
(1e)Error messages of media_sender
Rivermax library version: 13.3.11.20
Media sender version: 13.3.11.20
Warning - no CPU affinity set!!!
Writing log to default location: /tmp/rivermax_0630_165012_1685926.log
Created log file: /tmp/rivermax_0630_165012_1685926.log
[22-06-30 16:50:12.873079] Tid: 1685926 info [InitLogger:91] Logger started
[22-06-30 16:50:12.873104] Tid: 1685926 info [rmax_init_version:458] starting Rivermax version 13.3.11.20
[22-06-30 16:50:12.873116] Tid: 1685926 debug [Clock:31]
[22-06-30 16:50:12.873123] Tid: 1685926 debug [SysClock:41]
[22-06-30 16:50:12.873130] Tid: 1685926 debug [rivermax_get_user_env:145] parsed env RIVERMAX_DISABLE_VIDEO_GROUPING to the value true
[22-06-30 16:50:12.873139] Tid: 1685926 debug [rivermax_get_user_env:145] parsed env RIVERMAX_VIDEO_PACE_INTERVAL to the value 1000000
[22-06-30 16:50:12.873147] Tid: 1685926 debug [rivermax_get_user_env:145] parsed env RIVERMAX_OUT_STREAM_SIZE_IN_PKTS to the value 32768
[22-06-30 16:50:12.873153] Tid: 1685926 debug [rivermax_get_user_env:145] parsed env RIVERMAX_HEADER_STRIDE_SIZE to the value 64
[22-06-30 16:50:12.873158] Tid: 1685926 debug [rivermax_get_user_env:145] parsed env RIVERMAX_DISABLE_FLOW_ID to the value false
[22-06-30 16:50:12.873163] Tid: 1685926 debug [rivermax_get_user_env:145] parsed env RIVERMAX_REDUCE_VMA_MEMORY_CONSUMPTION to the value true
[22-06-30 16:50:12.873210] Tid: 1685926 debug [rivermax_get_user_env:145] parsed env RIVERMAX_SDP_PARSER_ENABLE_LOGGING to the value false
[22-06-30 16:50:12.873217] Tid: 1685926 debug [rivermax_get_user_env:145] parsed env RIVERMAX_ENABLE_CUDA to the value false
[22-06-30 16:50:12.873226] Tid: 1685926 debug [rivermax_get_user_env:145] parsed env RIVERMAX_ENABLE_STATISTICS to the value false
[22-06-30 16:50:12.873238] Tid: 1685926 debug [SignalHandler:90] Successfully registered for signal 2
[22-06-30 16:50:12.873247] Tid: 1685926 debug [SignalHandler:95] saving old user signal function for signal 2 at address 0x5564e3fe3a40
[22-06-30 16:50:12.873292] Tid: 1685926 debug [SignalHandler:90] Successfully registered for signal 15
[22-06-30 16:50:12.873334] Tid: 1685926 debug [SignalHandler:90] Successfully registered for signal 15
[22-06-30 16:50:12.873342] Tid: 1685926 debug [rivermax_get_user_env:145] parsed env RIVERMAX_SESSION_MAP_SIZE to the value 2000
[22-06-30 16:50:12.873364] Tid: 1685926 debug [rivermax_get_user_env:145] parsed env RIVERMAX_SESSION_MAP_SIZE to the value 2000
[22-06-30 16:50:12.873573] Tid: 1685926 debug [EventHandlerManager:125]
[22-06-30 16:50:12.873582] Tid: 1685926 info [EventHandlerManager:132] will wakeup before frame begin event in 2000000 ns
[22-06-30 16:50:12.873587] Tid: 1685926 debug [EventHandlerManagerHigh:259]
[22-06-30 16:50:12.873596] Tid: 1685926 debug [start_thread:341] Starting internal thread
[22-06-30 16:50:12.873697] Tid: 1685926 debug [rivermax_set_thread_priority:700] set priority successfully to 99
[22-06-30 16:50:12.873705] Tid: 1685926 debug [start_thread:344] Started event handler thread
[22-06-30 16:50:12.873710] Tid: 1685926 debug [init_globals:228] Time now is 1656575412873709693
[22-06-30 16:50:12.873746] Tid: 1685928 info [print_thread_info:117] High priority internal thread: PID = 1685926, thread ID = 1685928
VMA INFO: ---------------------------------------------------------------------------
VMA INFO: VMA_VERSION: 9.5.2-1 Release built on Apr 4 2022 13:27:26
VMA INFO: Cmd Line: ./media_sender -s ./sdps_samples/sdp.txt -m -f SeaWaves_1080p_50fps_10bits.ycbcr
VMA INFO: OFED Version: MLNX_OFED_LINUX-5.6-2.0.9.0:
VMA INFO: Log Level INFO [VMA_TRACELEVEL]
VMA INFO: Tx Mem Segs TCP 4 [VMA_TX_SEGS_TCP]
VMA INFO: Tx Mem Bufs 256 [VMA_TX_BUFS]
VMA INFO: Tx QP WRE 128 [VMA_TX_WRE]
VMA INFO: Tx Prefetch Bytes 32 [VMA_TX_PREFETCH_BYTES]
VMA INFO: Rx Mem Bufs 256 [VMA_RX_BUFS]
VMA INFO: Rx QP WRE 128 [VMA_RX_WRE]
VMA INFO: Rx Prefetch Bytes 32 [VMA_RX_PREFETCH_BYTES]
VMA INFO: Force Flowtag for MC Enabled [VMA_MC_FORCE_FLOWTAG]
VMA INFO: CQ AIM Max Count 64 [VMA_CQ_AIM_MAX_COUNT]
[22-06-30 16:50:12.912593] Tid: 1685926 debug [os_init_library_post_globals_init:394] using libvma.so libary
VMA WARNING: *******************************************************************************************************
VMA WARNING: * Interface ibp3s0f0 will not be offloaded.
VMA WARNING: * VMA was not able to create QP for this device (errno = 22).
VMA WARNING: * Interface ibp204s0f0 will not be offloaded.
[22-06-30 16:50:13.049112] Tid: 1685926 debug [os_init_library_post_globals_init:417] got 4 DPCP devices
[22-06-30 16:50:13.049747] Tid: 1685926 info [is_supported_device:161] Device lo is not supported
[22-06-30 16:50:13.049892] Tid: 1685926 info [is_supported_device:161] Device enp97s0f0 is not supported
[22-06-30 16:50:13.050021] Tid: 1685926 debug [os_map_dpcp_devices:254] examining 192.168.1.1, of ibp3s0f0 → mlx5_0 (ibp3s0f0)
[22-06-30 16:50:13.050058] Tid: 1685926 debug [init:229] Reserved MKey created lkey=0x700 addr=0x5564e5ab5820
[22-06-30 16:50:13.050065] Tid: 1685926 debug [init:238] Adapter frequency (khz) 1000000
[22-06-30 16:50:13.050117] Tid: 1685926 debug [os_map_dpcp_devices:286] added new device mlx5_0 with ip 192.168.1.1 mac 0x1049fe80
[22-06-30 16:50:13.056257] Tid: 1685926 debug [os_map_dpcp_devices:254] examining 192.168.1.2, of ibp204s0f0 → mlx5_2 (ibp204s0f0)
[22-06-30 16:50:13.056271] Tid: 1685926 debug [init:229] Reserved MKey created lkey=0x700 addr=0x5564e5ab8220
[22-06-30 16:50:13.056303] Tid: 1685926 debug [init:238] Adapter frequency (khz) 1000000
[22-06-30 16:50:13.056320] Tid: 1685926 debug [os_map_dpcp_devices:286] added new device mlx5_2 with ip 192.168.1.2 mac 0x1049fe80
[22-06-30 16:50:13.062497] Tid: 1685926 info [is_supported_device:161] Device docker0 is not supported
[22-06-30 16:50:13.062660] Tid: 1685926 info [is_supported_device:161] Device tmfifo_net0 is not supported
[22-06-30 16:50:13.062835] Tid: 1685926 info [is_supported_device:161] Device tmfifo_net1 is not supported
[22-06-30 16:50:13.062842] Tid: 1685926 debug [rivermax_get_user_env:145] parsed env RIVERMAX_ENABLE_PTP_HW_RT_CLOCK to the value false
[22-06-30 16:50:13.062847] Tid: 1685926 debug [Clock:31]
[22-06-30 16:50:13.062849] Tid: 1685926 debug [ExternalClock:66]
[22-06-30 16:50:13.062852] Tid: 1685926 debug [~SysClock:46]
[22-06-30 16:50:13.062854] Tid: 1685926 debug [~Clock:36]
[22-06-30 16:50:13.062856] Tid: 1685926 debug [set_clock_configurations:145] Using user time handler
[22-06-30 16:50:13.105260] Tid: 1685926 info [license_validate_v4:440] Licensed to: Fujitsu (N/A), evaluation period expires in 123 days
[22-06-30 16:50:13.105272] Tid: 1685926 info [info_product:462] Rivermax license version: 4.1
[22-06-30 16:50:13.105274] Tid: 1685926 info [license_validate:512] Rivermax license id c3544401-d0c0-f6b6-62b0-0e040698bccc, revision 1
[22-06-30 16:50:13.105277] Tid: 1685926 info [rmax_init_version:497] Statistics disabled
TX Thread: 0 CPU affinity not set
File opened successfully: SeaWaves_1080p_50fps_10bits.ycbcr
File size: 1296000000 [bytes]
Mem block length = 50
linux_memory_allocator: (allocated by: mmap) ptr = 0x7f2d91600000, 1386217472 [bytes] (requested size = 1382400000)
sdp for stream 0 is:
v=0
o=- 1443716955 1443716955 IN IP4 192.168.1.2
s=SMPTE ST2110-20 narrow gap 1080p50
t=0 0
m=video 2000 RTP/AVP 96
c=IN IP4 224.1.1.1/64
a=source-filter: incl IN IP4 224.1.1.1 192.168.1.2
a=rtpmap:96 raw/90000
a=fmtp:96 sampling=YCbCr-4:2:2; width=1920; height=1080; exactframerate=50; depth=10; TCS=SDR; colorimetry=BT709; PM=2110GPM; SSN=ST2110-20:2017; TP=2110TPN;
a=mediaclk:direct=0
a=ts-refclk:localmac=40-a3-6b-a0-2b-d2
[22-06-30 16:50:13.628584] Tid: 1685926 debug [mmapHugetlbAlloc:83] allocated 4194304 for 2097152 memory at 0x7f2df0200000 with mmap
[22-06-30 16:50:13.628602] Tid: 1685926 debug [rivermax_get_user_env:145] parsed env RIVERMAX_ENABLE_MP_WQE to the value false
[22-06-30 16:50:13.628605] Tid: 1685926 debug [SessionTX:76] MP_WQE disabled for session
[22-06-30 16:50:13.628619] Tid: 1685926 info [sdp_parse:571] trying to parse using smpte2110…
[22-06-30 16:50:13.628665] Tid: 1685926 info [sdp_parse:587] sdp parsed successfully
[22-06-30 16:50:13.628674] Tid: 1685926 info [license_assert_device:715] Validating Rivermax license for device with local ip 192.168.1.2
[22-06-30 16:50:13.628679] Tid: 1685926 info [is_sn_matched:143] No serial number restriction
[22-06-30 16:50:13.628685] Tid: 1685926 debug [session_tx_initialization:957] got 50 blocks, 16 stride in chunk, 4320 packets per frame, network_len 46
[22-06-30 16:50:13.628689] Tid: 1685926 debug [session_tx_initialization:982] processing block 0 with 21600 packets
[22-06-30 16:50:13.628691] Tid: 1685926 debug [session_tx_initialization:1006] processing application data
[22-06-30 16:50:13.628706] Tid: 1685926 debug [session_tx_initialization:982] processing block 1 with 21600 packets
[22-06-30 16:50:13.628709] Tid: 1685926 debug [session_tx_initialization:1006] processing application data
[22-06-30 16:50:13.628723] Tid: 1685926 debug [session_tx_initialization:982] processing block 2 with 21600 packets
[22-06-30 16:50:13.628726] Tid: 1685926 debug [session_tx_initialization:1006] processing application data
[22-06-30 16:50:13.628741] Tid: 1685926 debug [session_tx_initialization:982] processing block 3 with 21600 packets
[22-06-30 16:50:13.628743] Tid: 1685926 debug [session_tx_initialization:1006] processing application data
[22-06-30 16:50:13.628758] Tid: 1685926 debug [session_tx_initialization:982] processing block 4 with 21600 packets
[22-06-30 16:50:13.628760] Tid: 1685926 debug [session_tx_initialization:1006] processing application data
[22-06-30 16:50:13.628779] Tid: 1685926 debug [session_tx_initialization:982] processing block 5 with 21600 packets
[22-06-30 16:50:13.628781] Tid: 1685926 debug [session_tx_initialization:1006] processing application data
[22-06-30 16:50:13.628797] Tid: 1685926 debug [session_tx_initialization:982] processing block 6 with 21600 packets
[22-06-30 16:50:13.628799] Tid: 1685926 debug [session_tx_initialization:1006] processing application data
[22-06-30 16:50:13.628814] Tid: 1685926 debug [session_tx_initialization:982] processing block 7 with 21600 packets
[22-06-30 16:50:13.628816] Tid: 1685926 debug [session_tx_initialization:1006] processing application data
[22-06-30 16:50:13.628862] Tid: 1685926 debug [session_tx_initialization:982] processing block 8 with 21600 packets
[22-06-30 16:50:13.628865] Tid: 1685926 debug [session_tx_initialization:1006] processing application data
[22-06-30 16:50:13.628882] Tid: 1685926 debug [session_tx_initialization:982] processing block 9 with 21600 packets
[22-06-30 16:50:13.628884] Tid: 1685926 debug [session_tx_initialization:1006] processing application data
[22-06-30 16:50:13.628901] Tid: 1685926 debug [session_tx_initialization:982] processing block 10 with 21600 packets
[22-06-30 16:50:13.628903] Tid: 1685926 debug [session_tx_initialization:1006] processing application data
[22-06-30 16:50:13.628920] Tid: 1685926 debug [session_tx_initialization:982] processing block 11 with 21600 packets
[22-06-30 16:50:13.628922] Tid: 1685926 debug [session_tx_initialization:1006] processing application data
[22-06-30 16:50:13.628939] Tid: 1685926 debug [session_tx_initialization:982] processing block 12 with 21600 packets
[22-06-30 16:50:13.628941] Tid: 1685926 debug [session_tx_initialization:1006] processing application data
[22-06-30 16:50:13.628963] Tid: 1685926 debug [session_tx_initialization:982] processing block 13 with 21600 packets
[22-06-30 16:50:13.628965] Tid: 1685926 debug [session_tx_initialization:1006] processing application data
[22-06-30 16:50:13.628984] Tid: 1685926 debug [session_tx_initialization:982] processing block 14 with 21600 packets
[22-06-30 16:50:13.628986] Tid: 1685926 debug [session_tx_initialization:1006] processing application data
[22-06-30 16:50:13.629002] Tid: 1685926 debug [session_tx_initialization:982] processing block 15 with 21600 packets
[22-06-30 16:50:13.629004] Tid: 1685926 debug [session_tx_initialization:1006] processing application data
[22-06-30 16:50:13.629021] Tid: 1685926 debug [session_tx_initialization:982] processing block 16 with 21600 packets
[22-06-30 16:50:13.629023] Tid: 1685926 debug [session_tx_initialization:1006] processing application data
[22-06-30 16:50:13.629041] Tid: 1685926 debug [session_tx_initialization:982] processing block 17 with 21600 packets
[22-06-30 16:50:13.629044] Tid: 1685926 debug [session_tx_initialization:1006] processing application data
[22-06-30 16:50:13.629059] Tid: 1685926 debug [session_tx_initialization:982] processing block 18 with 21600 packets
[22-06-30 16:50:13.629061] Tid: 1685926 debug [session_tx_initialization:1006] processing application data
[22-06-30 16:50:13.629080] Tid: 1685926 debug [session_tx_initialization:982] processing block 19 with 21600 packets
[22-06-30 16:50:13.629082] Tid: 1685926 debug [session_tx_initialization:1006] processing application data
[22-06-30 16:50:13.629098] Tid: 1685926 debug [session_tx_initialization:982] processing block 20 with 21600 packets
[22-06-30 16:50:13.629100] Tid: 1685926 debug [session_tx_initialization:1006] processing application data
[22-06-30 16:50:13.629116] Tid: 1685926 debug [session_tx_initialization:982] processing block 21 with 21600 packets
[22-06-30 16:50:13.629118] Tid: 1685926 debug [session_tx_initialization:1006] processing application data
[22-06-30 16:50:13.629134] Tid: 1685926 debug [session_tx_initialization:982] processing block 22 with 21600 packets
[22-06-30 16:50:13.629137] Tid: 1685926 debug [session_tx_initialization:1006] processing application data
[22-06-30 16:50:13.629153] Tid: 1685926 debug [session_tx_initialization:982] processing block 23 with 21600 packets
[22-06-30 16:50:13.629155] Tid: 1685926 debug [session_tx_initialization:1006] processing application data
[22-06-30 16:50:13.629170] Tid: 1685926 debug [session_tx_initialization:982] processing block 24 with 21600 packets
[22-06-30 16:50:13.629172] Tid: 1685926 debug [session_tx_initialization:1006] processing application data
[22-06-30 16:50:13.629188] Tid: 1685926 debug [session_tx_initialization:982] processing block 25 with 21600 packets
[22-06-30 16:50:13.629190] Tid: 1685926 debug [session_tx_initialization:1006] processing application data
[22-06-30 16:50:13.629209] Tid: 1685926 debug [session_tx_initialization:982] processing block 26 with 21600 packets
[22-06-30 16:50:13.629212] Tid: 1685926 debug [session_tx_initialization:1006] processing application data
[22-06-30 16:50:13.629227] Tid: 1685926 debug [session_tx_initialization:982] processing block 27 with 21600 packets
[22-06-30 16:50:13.629230] Tid: 1685926 debug [session_tx_initialization:1006] processing application data
[22-06-30 16:50:13.629244] Tid: 1685926 debug [session_tx_initialization:982] processing block 28 with 21600 packets
[22-06-30 16:50:13.629247] Tid: 1685926 debug [session_tx_initialization:1006] processing application data
[22-06-30 16:50:13.629262] Tid: 1685926 debug [session_tx_initialization:982] processing block 29 with 21600 packets
[22-06-30 16:50:13.629290] Tid: 1685926 debug [session_tx_initialization:1006] processing application data
[22-06-30 16:50:13.629304] Tid: 1685926 debug [session_tx_initialization:982] processing block 30 with 21600 packets
[22-06-30 16:50:13.629308] Tid: 1685926 debug [session_tx_initialization:1006] processing application data
[22-06-30 16:50:13.629323] Tid: 1685926 debug [session_tx_initialization:982] processing block 31 with 21600 packets
[22-06-30 16:50:13.629326] Tid: 1685926 debug [session_tx_initialization:1006] processing application data
[22-06-30 16:50:13.629341] Tid: 1685926 debug [session_tx_initialization:982] processing block 32 with 21600 packets
[22-06-30 16:50:13.629345] Tid: 1685926 debug [session_tx_initialization:1006] processing application data
[22-06-30 16:50:13.629359] Tid: 1685926 debug [session_tx_initialization:982] processing block 33 with 21600 packets
[22-06-30 16:50:13.629363] Tid: 1685926 debug [session_tx_initialization:1006] processing application data
[22-06-30 16:50:13.629378] Tid: 1685926 debug [session_tx_initialization:982] processing block 34 with 21600 packets
[22-06-30 16:50:13.629381] Tid: 1685926 debug [session_tx_initialization:1006] processing application data
[22-06-30 16:50:13.629396] Tid: 1685926 debug [session_tx_initialization:982] processing block 35 with 21600 packets
[22-06-30 16:50:13.629399] Tid: 1685926 debug [session_tx_initialization:1006] processing application data
[22-06-30 16:50:13.629414] Tid: 1685926 debug [session_tx_initialization:982] processing block 36 with 21600 packets
[22-06-30 16:50:13.629417] Tid: 1685926 debug [session_tx_initialization:1006] processing application data
[22-06-30 16:50:13.629437] Tid: 1685926 debug [session_tx_initialization:982] processing block 37 with 21600 packets
[22-06-30 16:50:13.629442] Tid: 1685926 debug [session_tx_initialization:1006] processing application data
[22-06-30 16:50:13.629521] Tid: 1685926 debug [session_tx_initialization:982] processing block 38 with 21600 packets
[22-06-30 16:50:13.629530] Tid: 1685926 debug [session_tx_initialization:1006] processing application data
[22-06-30 16:50:13.629544] Tid: 1685926 debug [session_tx_initialization:982] processing block 39 with 21600 packets
[22-06-30 16:50:13.629549] Tid: 1685926 debug [session_tx_initialization:1006] processing application data
[22-06-30 16:50:13.629565] Tid: 1685926 debug [session_tx_initialization:982] processing block 40 with 21600 packets
[22-06-30 16:50:13.629570] Tid: 1685926 debug [session_tx_initialization:1006] processing application data
[22-06-30 16:50:13.629586] Tid: 1685926 debug [session_tx_initialization:982] processing block 41 with 21600 packets
[22-06-30 16:50:13.629588] Tid: 1685926 debug [session_tx_initialization:1006] processing application data
[22-06-30 16:50:13.629603] Tid: 1685926 debug [session_tx_initialization:982] processing block 42 with 21600 packets
[22-06-30 16:50:13.629636] Tid: 1685926 debug [session_tx_initialization:1006] processing application data
[22-06-30 16:50:13.629651] Tid: 1685926 debug [session_tx_initialization:982] processing block 43 with 21600 packets
[22-06-30 16:50:13.629654] Tid: 1685926 debug [session_tx_initialization:1006] processing application data
[22-06-30 16:50:13.629669] Tid: 1685926 debug [session_tx_initialization:982] processing block 44 with 21600 packets
[22-06-30 16:50:13.629678] Tid: 1685926 debug [session_tx_initialization:1006] processing application data
[22-06-30 16:50:13.629698] Tid: 1685926 debug [session_tx_initialization:982] processing block 45 with 21600 packets
[22-06-30 16:50:13.629701] Tid: 1685926 debug [session_tx_initialization:1006] processing application data
[22-06-30 16:50:13.629718] Tid: 1685926 debug [session_tx_initialization:982] processing block 46 with 21600 packets
[22-06-30 16:50:13.629722] Tid: 1685926 debug [session_tx_initialization:1006] processing application data
[22-06-30 16:50:13.629737] Tid: 1685926 debug [session_tx_initialization:982] processing block 47 with 21600 packets
[22-06-30 16:50:13.629739] Tid: 1685926 debug [session_tx_initialization:1006] processing application data
[22-06-30 16:50:13.629754] Tid: 1685926 debug [session_tx_initialization:982] processing block 48 with 21600 packets
[22-06-30 16:50:13.629756] Tid: 1685926 debug [session_tx_initialization:1006] processing application data
[22-06-30 16:50:13.629771] Tid: 1685926 debug [session_tx_initialization:982] processing block 49 with 21600 packets
[22-06-30 16:50:13.629773] Tid: 1685926 debug [session_tx_initialization:1006] processing application data
[22-06-30 16:50:13.629788] Tid: 1685926 debug [session_tx_initialization:1046] fix intv is every 50 frames
[22-06-30 16:50:13.630640] Tid: 1685926 debug [get_vlan_by_ip:593] vlan not detected
[22-06-30 16:50:13.630653] Tid: 1685926 info [session_tx_initialization:1124] Detected ST2110-20 video stream
[22-06-30 16:50:13.630658] Tid: 1685926 debug [init:80] MP_WQE disabled for ring
[22-06-30 16:50:13.630703] Tid: 1685926 debug [init:49] created socket fd 27
[22-06-30 16:50:13.630720] Tid: 1685926 debug [init:94] added ring profile with type VMA_RING_EXTERNAL_MEM and got ret 0
[22-06-30 16:50:13.630726] Tid: 1685926 debug [init:112] setsockopt for ring profile with key 1 and got 0
[22-06-30 16:50:13.630748] Tid: 1685926 debug [init:129] called bind to source addr 192.168.1.2 port 0 got 0
[22-06-30 16:50:13.630762] Tid: 1685926 warning [init:165] failed to shutdown rx side, this can cause to performance degradation
[22-06-30 16:50:13.630767] Tid: 1685926 debug [init:172] called connect to addr 224.1.1.1 port 2000 got 0
[22-06-30 16:50:13.630769] Tid: 1685926 critical [init_hw_related:216] failed retrieving ring fd 22
[22-06-30 16:50:13.630776] Tid: 1685926 error [calculate:233] got invalid device id 0
[22-06-30 16:50:13.630780] Tid: 1685926 info [calculate:255] no rate limit set
[22-06-30 16:50:13.630782] Tid: 1685926 warning [init:179] failed calculating rate
[22-06-30 16:50:13.630784] Tid: 1685926 error [init:50] failed creating data socket
[22-06-30 16:50:13.630786] Tid: 1685926 critical [session_tx_initialization:1342] Ring 0 wasn’t initialized!
failed creating stream
thread 0 initialization failed
Cleanup called
[22-06-30 16:50:13.630849] Tid: 1685926 debug [~EventHandlerManagerHigh:265]
[22-06-30 16:50:13.630854] Tid: 1685926 debug [~EventHandlerManager:139]
[22-06-30 16:50:13.630857] Tid: 1685926 debug [free_evh_resources:148]
[22-06-30 16:50:13.630941] Tid: 1685926 debug [stop_thread:163] event handler thread stopped
[22-06-30 16:50:13.630945] Tid: 1685926 debug [free_evh_resources:152] Thread stopped
[22-06-30 16:50:13.631020] Tid: 1685926 debug [~ExternalClock:71]
[22-06-30 16:50:13.631024] Tid: 1685926 debug [~Clock:36]
[22-06-30 16:50:13.631027] Tid: 1685926 debug [~DeviceCollection:27] ~DeviceCollection()
[22-06-30 16:50:13.744627] Tid: 1685926 info [~RiverLogger:101] logger closing
(2e)Error messages of media_receiver
Media receiver version: 13.3.11.20
Writing log to default location: /tmp/rivermax_0630_165130_1686397.log
Created log file: /tmp/rivermax_0630_165130_1686397.log
[22-06-30 16:51:30.550952] Tid: 1686397 info [InitLogger:91] Logger started
[22-06-30 16:51:30.550984] Tid: 1686397 info [rmax_init_version:458] starting Rivermax version 13.3.11.20
[22-06-30 16:51:30.550999] Tid: 1686397 debug [Clock:31]
[22-06-30 16:51:30.551006] Tid: 1686397 debug [SysClock:41]
[22-06-30 16:51:30.551010] Tid: 1686397 debug [rivermax_get_user_env:145] parsed env RIVERMAX_DISABLE_VIDEO_GROUPING to the value true
[22-06-30 16:51:30.551021] Tid: 1686397 debug [rivermax_get_user_env:145] parsed env RIVERMAX_VIDEO_PACE_INTERVAL to the value 1000000
[22-06-30 16:51:30.551031] Tid: 1686397 debug [rivermax_get_user_env:145] parsed env RIVERMAX_OUT_STREAM_SIZE_IN_PKTS to the value 32768
[22-06-30 16:51:30.551039] Tid: 1686397 debug [rivermax_get_user_env:145] parsed env RIVERMAX_HEADER_STRIDE_SIZE to the value 64
[22-06-30 16:51:30.551049] Tid: 1686397 debug [rivermax_get_user_env:145] parsed env RIVERMAX_DISABLE_FLOW_ID to the value false
[22-06-30 16:51:30.551056] Tid: 1686397 debug [rivermax_get_user_env:145] parsed env RIVERMAX_REDUCE_VMA_MEMORY_CONSUMPTION to the value true
[22-06-30 16:51:30.551064] Tid: 1686397 debug [rivermax_get_user_env:145] parsed env RIVERMAX_SDP_PARSER_ENABLE_LOGGING to the value false
[22-06-30 16:51:30.551107] Tid: 1686397 debug [rivermax_get_user_env:145] parsed env RIVERMAX_ENABLE_CUDA to the value false
[22-06-30 16:51:30.551114] Tid: 1686397 debug [rivermax_get_user_env:145] parsed env RIVERMAX_ENABLE_STATISTICS to the value false
[22-06-30 16:51:30.551130] Tid: 1686397 debug [SignalHandler:90] Successfully registered for signal 2
[22-06-30 16:51:30.551140] Tid: 1686397 debug [SignalHandler:95] saving old user signal function for signal 2 at address 0x561256b54850
[22-06-30 16:51:30.551147] Tid: 1686397 debug [SignalHandler:90] Successfully registered for signal 15
[22-06-30 16:51:30.551155] Tid: 1686397 debug [SignalHandler:90] Successfully registered for signal 15
[22-06-30 16:51:30.551163] Tid: 1686397 debug [rivermax_get_user_env:145] parsed env RIVERMAX_SESSION_MAP_SIZE to the value 2000
[22-06-30 16:51:30.551188] Tid: 1686397 debug [rivermax_get_user_env:145] parsed env RIVERMAX_SESSION_MAP_SIZE to the value 2000
[22-06-30 16:51:30.551379] Tid: 1686397 debug [EventHandlerManager:125]
[22-06-30 16:51:30.551386] Tid: 1686397 info [EventHandlerManager:132] will wakeup before frame begin event in 2000000 ns
[22-06-30 16:51:30.551394] Tid: 1686397 debug [EventHandlerManagerHigh:259]
[22-06-30 16:51:30.551400] Tid: 1686397 debug [start_thread:341] Starting internal thread
[22-06-30 16:51:30.551497] Tid: 1686397 debug [rivermax_set_thread_priority:700] set priority successfully to 99
[22-06-30 16:51:30.551504] Tid: 1686397 debug [start_thread:344] Started event handler thread
[22-06-30 16:51:30.551511] Tid: 1686397 debug [init_globals:228] Time now is 1656575490551511364
[22-06-30 16:51:30.551603] Tid: 1686398 info [print_thread_info:117] High priority internal thread: PID = 1686397, thread ID = 1686398
VMA INFO: Cmd Line: ./media_receiver -m 224.1.1.1 -i 192.168.1.1 -p 2000 -s 192.168.1.2
[22-06-30 16:51:30.592661] Tid: 1686397 debug [os_init_library_post_globals_init:394] using libvma.so libary
[22-06-30 16:51:30.729713] Tid: 1686397 debug [os_init_library_post_globals_init:417] got 4 DPCP devices
[22-06-30 16:51:30.730271] Tid: 1686397 info [is_supported_device:161] Device lo is not supported
[22-06-30 16:51:30.730412] Tid: 1686397 info [is_supported_device:161] Device enp97s0f0 is not supported
[22-06-30 16:51:30.730548] Tid: 1686397 debug [os_map_dpcp_devices:254] examining 192.168.1.1, of ibp3s0f0 → mlx5_0 (ibp3s0f0)
[22-06-30 16:51:30.730592] Tid: 1686397 debug [init:229] Reserved MKey created lkey=0x700 addr=0x561259c27420
[22-06-30 16:51:30.730600] Tid: 1686397 debug [init:238] Adapter frequency (khz) 1000000
[22-06-30 16:51:30.730669] Tid: 1686397 debug [os_map_dpcp_devices:286] added new device mlx5_0 with ip 192.168.1.1 mac 0x1049fe80
[22-06-30 16:51:30.736830] Tid: 1686397 debug [os_map_dpcp_devices:254] examining 192.168.1.2, of ibp204s0f0 → mlx5_2 (ibp204s0f0)
[22-06-30 16:51:30.736843] Tid: 1686397 debug [init:229] Reserved MKey created lkey=0x700 addr=0x561259c29e20
[22-06-30 16:51:30.736877] Tid: 1686397 debug [init:238] Adapter frequency (khz) 1000000
[22-06-30 16:51:30.736896] Tid: 1686397 debug [os_map_dpcp_devices:286] added new device mlx5_2 with ip 192.168.1.2 mac 0x1049fe80
[22-06-30 16:51:30.743026] Tid: 1686397 info [is_supported_device:161] Device docker0 is not supported
[22-06-30 16:51:30.743183] Tid: 1686397 info [is_supported_device:161] Device tmfifo_net0 is not supported
[22-06-30 16:51:30.743354] Tid: 1686397 info [is_supported_device:161] Device tmfifo_net1 is not supported
[22-06-30 16:51:30.785735] Tid: 1686397 info [license_validate_v4:440] Licensed to: Fujitsu (N/A), evaluation period expires in 123 days
[22-06-30 16:51:30.785747] Tid: 1686397 info [info_product:462] Rivermax license version: 4.1
[22-06-30 16:51:30.785749] Tid: 1686397 info [license_validate:512] Rivermax license id c3544401-d0c0-f6b6-62b0-0e040698bccc, revision 1
[22-06-30 16:51:30.785753] Tid: 1686397 info [rmax_init_version:497] Statistics disabled
Adding 20 bytes of the header to payload size
Create in_2110_stream stream
buffer elements: 262144 data size:1220 header size:0
[22-06-30 16:51:30.786139] Tid: 1686397 debug [mmapHugetlbAlloc:83] allocated 4194304 for 2097152 memory at 0x7f59e2a00000 with mmap
[22-06-30 16:51:30.786147] Tid: 1686397 info [license_assert_device:715] Validating Rivermax license for device with local ip 192.168.1.1
[22-06-30 16:51:30.786151] Tid: 1686397 info [is_sn_matched:143] No serial number restriction
[22-06-30 16:51:30.786153] Tid: 1686397 debug [init_session:160] buffer attribute - requested payload pointer: 0x0, header pointer: N/A
[22-06-30 16:51:30.786426] Tid: 1686397 debug [get_vlan_by_ip:593] vlan not detected
[22-06-30 16:51:30.786676] Tid: 1686397 debug [get_vlan_by_ip:593] vlan not detected
[22-06-30 16:51:30.786681] Tid: 1686397 debug [init_ring:125] net header len 42 stride_sz 2048 hdr_stride_sz 0 payload_stride_sz 1220
[22-06-30 16:51:30.786685] Tid: 1686397 debug [allocate_memory:302] rx_type 0, local addr 192.168.1.1, local port 0 buffer_attr: num_of_elems 262144
[22-06-30 16:51:30.786688] Tid: 1686397 debug [allocate_memory:305] data_sz min/max 1220/1220, hdr_sz min/max 0/0, timestamp 1 in_flags 1
[22-06-30 16:51:30.786690] Tid: 1686397 debug [calc_buffer_size:166] requested-> 262144 elements, payload_sz min/max 1220/1220, hdr_sz min/max 0/0
[22-06-30 16:51:30.786693] Tid: 1686397 debug [calc_buffer_size:260] calculated-> stride size: 2048 packet buffer size of 536870912 bytes
[22-06-30 16:51:30.786695] Tid: 1686397 debug [calc_buffer_size:273] configured-> 4 elements, tot_wqes: 4, strides num: 65536, data stride size 2048, hdr stride size: 42 [net_len = 42], *payload_size_out = 536870912 *hdr_size_out = 0
[22-06-30 16:51:30.830008] Tid: 1686397 debug [mmapHugetlbAlloc:83] allocated 538968064 for 536870912 memory at 0x7f59bbe00000 with mmap
[22-06-30 16:51:30.835157] Tid: 1686397 debug [create_direct_mkey:335] map sz = 2 lkey 0x5b24
[22-06-30 16:51:30.835177] Tid: 1686397 debug [allocate_memory:358] registered addr 0x7f59bbe00000 size 536870912 with lkey 0x5b24
[22-06-30 16:51:30.835184] Tid: 1686397 debug [create_memory_layout:261] using non-KLM direct memory mapping
[22-06-30 16:51:30.835187] Tid: 1686397 debug [create_non_umr_layout:167] header start 0x0 payload start 0x7f59bbe00000 hdr_stride_sz 0
[22-06-30 16:51:30.835877] Tid: 1686397 debug [mmapHugetlbAlloc:83] allocated 8388608 for 4194320 memory at 0x7f59e2200000 with mmap
[22-06-30 16:51:30.835883] Tid: 1686397 debug [PacketInfoFiller:47] strides 262144 net_len 0 hdr_len0
[22-06-30 16:51:30.835886] Tid: 1686397 debug [init_session:204] created ring successfully net len 0 strides 262144
[22-06-30 16:51:30.835890] Tid: 1686397 debug [add_session:113] created new RX session with id 0
Rivermax created: session type: 0 with: 262144 packet skip size:2048
[22-06-30 16:51:30.840348] Tid: 1686397 debug [create_striding_rq:608] created striding_rq 0x561259c0a500 state RQ_RDY status 0 wqe 0x561259c2f000 stride num/sz 4/512 rq 12582985
[22-06-30 16:51:30.840485] Tid: 1686397 debug [RxHandler:34] got CQ parameters: buf 0x7f59e1200000 cqe_size 64 cqn 0x407, cq_size 0x40000, db 0x561259c2d000
[22-06-30 16:51:30.840491] Tid: 1686397 debug [RxHandler:36] got RQ parameters: buf 0x561259c2f000 db 0x561259c31000, stride 32, wqe_cnt 4, m_wqe_idx 0, user wqes 4
[22-06-30 16:51:30.840530] Tid: 1686397 debug [create_rx_dp:407] using 65536 strides with 4 wqes, each stride size is 2048 rx_dp 0x561259c0b870
[22-06-30 16:51:30.841487] Tid: 1686397 debug [join_mc:82] joined group with ip 224.1.1.1 with interface ip 192.168.1.1 with source multicast 192.168.1.2
[22-06-30 16:51:30.841498] Tid: 1686397 debug [attach_flow_rule:703] mac 1: 0:5e: 1: 1: 1 ethertype 0x800, vlan 0x0 dst ip 0xe0010101 src ip 0xc0a80102 dst port 0x7d0 protocol 0x11
[22-06-30 16:51:30.841927] Tid: 1686397 debug [attach_flow_rule:726] attached flow 0 to rq_num 12582985 and tir 73
[22-06-30 16:51:30.843186] Tid: 1686397 error [attach_flow_rule:737] failed applying settings -9
[22-06-30 16:51:30.843200] Tid: 1686397 error [attach_flow:469] attach flow failed = 13
[22-06-30 16:51:30.843217] Tid: 1686397 debug [attach_flow:221] attached to local 224.1.1.1, port 2000 remote 192.168.1.2 port 0, flow 0 attached_num 0
Failed to attach flow, status:13
failed attaching
[22-06-30 16:51:30.843319] Tid: 1686397 debug [~EventHandlerManagerHigh:265]
[22-06-30 16:51:30.843326] Tid: 1686397 debug [~EventHandlerManager:139]
[22-06-30 16:51:30.843328] Tid: 1686397 debug [free_evh_resources:148]
[22-06-30 16:51:30.843391] Tid: 1686397 debug [stop_thread:163] event handler thread stopped
[22-06-30 16:51:30.843397] Tid: 1686397 debug [free_evh_resources:152] Thread stopped
[22-06-30 16:51:30.843503] Tid: 1686397 debug [~SysClock:46]
[22-06-30 16:51:30.843509] Tid: 1686397 debug [~Clock:36]
[22-06-30 16:51:30.843514] Tid: 1686397 debug [~DeviceCollection:27] ~DeviceCollection()
@kawasaki.kohei,
My Name is Nir - I’m Rivermax Product Manager.
It seems that you are trying to use an advanced converged cards (DPU+GPU). Currently Rivermax doesn’t provide support for these cards.
I suggest that you open a support ticket in order for us to understand the use case and the needs for these cards.
Thanks,
Nir Nitzani
Hi, Nir-san
Thank you for your reply.
I have a question.
I would like to issue a support ticket. Could you tell me which one I should enter?
Thank you.
Networking support cases can be accessed here - NVIDIA Enterprise Support Portal
If you have any technical support issue with NVIDIA Networking solution and you are not able to access the NVIDIA Enterprise Support Portal, you can:
