Rivermax testing recommendation
It’s recommended that the Rivermax generic_receiver be started prior to starting the generic_sender when testing Rivermax between two Clara AGX DevKits. The DevKits should be connected using a suitable QSFP interconnect between the ConnectX QSFP ports on the DevKits (note: the latest firmware ConnectX firmware update disables the ConnectX RJ45 port on the Clara AGX DevKit). The following are recommended alternative steps for running the Rivermax generic send/receive test between a sender and receiver Clara AGX:
Sender:
$ sudo ip a add 192.168.31.1/24 dev eth1
$ sudo ip link set dev eth1 up
Receiver:
$ sudo ip a add 192.168.31.2/24 dev eth1
$ ping 192.168.31.1
(confirm can ping sender)
Sender:
$ ping 192.168.31.2
(confirm can ping receiver)
Receiver:
$ sudo ./generic_receiver -i 192.168.31.2 -m 192.168.31.2 -s 192.168.31.1 -p 5001 -g 0
Sender:
$ sudo ./generic_sender -l 192.168.31.1 -d 192.168.31.2 -p 5001 -y 1462 -k 8192 -z 500 -v
