RL: Franka not able to reach the goal
Hi all,
I am trying to train the Franka so that it can autonomously move towards a shape that I randomly place in the environment. However, as it was not able to learn it at all, I simplified the task so that the goal shape is not even randomly placed, but fixed at one position (see the attached video):
This can also be seen in the training log. One more weird thing is that the reward suddenly collapses after a certain amount of training steps. (The attached video however is from the state reward=450, before the collapse)
Do you have any tips for me…?
import numpy as np
import os
import torch
from isaacgym import gymutil, gymtorch, gymapi
from isaacgym.torch_utils import *
from tasks.base.vec_task import VecTask
import random
class FrankaReach(VecTask):
def __init__(self, cfg, sim_device, graphics_device_id, headless):
    self.cfg = cfg
    self.max_episode_length = self.cfg["env"]["episodeLength"]
    self.action_scale = self.cfg["env"]["actionScale"]
    self.start_position_noise = self.cfg["env"]["startPositionNoise"]
    self.start_rotation_noise = self.cfg["env"]["startRotationNoise"]
    self.num_props = self.cfg["env"]["numProps"]
    self.aggregate_mode = self.cfg["env"]["aggregateMode"]
    self.dof_vel_scale = self.cfg["env"]["dofVelocityScale"]
    self.dist_reward_scale = self.cfg["env"]["distRewardScale"]
    self.rot_reward_scale = self.cfg["env"]["rotRewardScale"]
    self.around_handle_reward_scale = self.cfg["env"]["aroundHandleRewardScale"]
    self.open_reward_scale = self.cfg["env"]["openRewardScale"]
    self.finger_dist_reward_scale = self.cfg["env"]["fingerDistRewardScale"]
    self.action_penalty_scale = self.cfg["env"]["actionPenaltyScale"]
    self.debug_viz = self.cfg["env"]["enableDebugVis"]
    self.up_axis = "z"
    self.up_axis_idx = 2
    self.distX_offset = 0.04
    self.dt = 1/60.
    # prop dimensions
    self.prop_width = 0.08
    self.prop_height = 0.08
    self.prop_length = 0.08
    self.prop_spacing = 0.09
    num_obs = 23
    num_acts = 9
    self.cfg["env"]["numObservations"] = 21
    self.cfg["env"]["numActions"] = 9
    super().__init__(config=self.cfg, sim_device=sim_device, graphics_device_id=graphics_device_id, headless=headless)
    # get gym GPU state tensors
    actor_root_state_tensor = self.gym.acquire_actor_root_state_tensor(self.sim)
    dof_state_tensor = self.gym.acquire_dof_state_tensor(self.sim)
    rigid_body_tensor = self.gym.acquire_rigid_body_state_tensor(self.sim)
    self.gym.refresh_actor_root_state_tensor(self.sim)
    self.gym.refresh_dof_state_tensor(self.sim)
    self.gym.refresh_rigid_body_state_tensor(self.sim)
    # create some wrapper tensors for different slices
    self.franka_default_dof_pos = to_torch([1.157, -1.066, -0.155, -2.239, -1.841, 1.003, 0.469, 0.035, 0.035], device=self.device)
    self.dof_state = gymtorch.wrap_tensor(dof_state_tensor)
    self.franka_dof_state = self.dof_state.view(self.num_envs, -1, 2)[:, :self.num_franka_dofs]
    self.franka_dof_pos = self.franka_dof_state[..., 0]
    self.franka_dof_vel = self.franka_dof_state[..., 1]
    self.cabinet_dof_state = self.dof_state.view(self.num_envs, -1, 2)[:, self.num_franka_dofs:]
    self.cabinet_dof_pos = self.cabinet_dof_state[..., 0]
    self.cabinet_dof_vel = self.cabinet_dof_state[..., 1]
    self.rigid_body_states = gymtorch.wrap_tensor(rigid_body_tensor).view(self.num_envs, -1, 13)
    self.num_bodies = self.rigid_body_states.shape[1]
    #self.root_state_tensor = gymtorch.wrap_tensor(actor_root_state_tensor).view(self.num_envs, -1, 13)
    if self.num_props > 0:
        self.prop_states = self.root_state_tensor[:, 2:]
    self.num_dofs = self.gym.get_sim_dof_count(self.sim) // self.num_envs
    self.franka_dof_targets = torch.zeros((self.num_envs, self.num_dofs), dtype=torch.float, device=self.device)
    self.global_indices = torch.arange(self.num_envs * (2 + self.num_props), dtype=torch.int32, device=self.device).view(self.num_envs, -1)
    self.reset_idx(torch.arange(self.num_envs, device=self.device))
def create_sim(self):
    self.sim_params.up_axis = gymapi.UP_AXIS_Z
    self.sim_params.gravity.x = 0
    self.sim_params.gravity.y = 0
    self.sim_params.gravity.z = -9.81
    self.sim = super().create_sim(
        self.device_id, self.graphics_device_id, self.physics_engine, self.sim_params)
    self._create_ground_plane()
    self._create_envs(self.num_envs, self.cfg["env"]['envSpacing'], int(np.sqrt(self.num_envs)))
def _create_ground_plane(self):
    plane_params = gymapi.PlaneParams()
    plane_params.normal = gymapi.Vec3(0.0, 0.0, 1.0)
    self.gym.add_ground(self.sim, plane_params)
def _create_envs(self, num_envs, spacing, num_per_row):
    lower = gymapi.Vec3(-spacing, -spacing, 0.0)
    upper = gymapi.Vec3(spacing, spacing, spacing)
    asset_root = os.path.join(os.path.dirname(os.path.abspath(__file__)), "../../assets")
    franka_asset_file = "urdf/franka_description/robots/franka_panda.urdf"
    #cabinet_asset_file = "urdf/sektion_cabinet_model/urdf/sektion_cabinet_2.urdf"
    if "asset" in self.cfg["env"]:
        asset_root = os.path.join(os.path.dirname(os.path.abspath(__file__)), self.cfg["env"]["asset"].get("assetRoot", asset_root))
        franka_asset_file = self.cfg["env"]["asset"].get("assetFileNameFranka", franka_asset_file)
        #cabinet_asset_file = self.cfg["env"]["asset"].get("assetFileNameCabinet", cabinet_asset_file)
    ball_asset_options = gymapi.AssetOptions()
    ball_asset_options.disable_gravity = True
    ball_asset_options.fix_base_link = True
    ball_asset= self.gym.create_sphere (self.sim, 0.05 , ball_asset_options)
    ball_dof_props = self.gym.get_asset_dof_properties(ball_asset)
    # load franka asset
    asset_options.flip_visual_attachments = True
    asset_options.collapse_fixed_joints = True
    asset_options.thickness = 0.001
    asset_options.default_dof_drive_mode = gymapi.DOF_MODE_POS
    asset_options.use_mesh_materials = True
    franka_asset = self.gym.load_asset(self.sim, asset_root, franka_asset_file, asset_options)
    franka_dof_stiffness = to_torch([400, 400, 400, 400, 400, 400, 400, 1.0e6, 1.0e6], dtype=torch.float, device=self.device)
    franka_dof_damping = to_torch([80, 80, 80, 80, 80, 80, 80, 1.0e2, 1.0e2], dtype=torch.float, device=self.device)
    self.num_franka_bodies = self.gym.get_asset_rigid_body_count(franka_asset)
    self.num_franka_dofs = self.gym.get_asset_dof_count(franka_asset)
    print("num franka bodies: ", self.num_franka_bodies)
    print("num franka dofs: ", self.num_franka_dofs)
    # set franka dof properties
    franka_dof_props = self.gym.get_asset_dof_properties(franka_asset)
    self.franka_dof_lower_limits = []
    self.franka_dof_upper_limits = []
    for i in range(self.num_franka_dofs):
        franka_dof_props['driveMode'][i] = gymapi.DOF_MODE_POS
        if self.physics_engine == gymapi.SIM_PHYSX:
            franka_dof_props['stiffness'][i] = franka_dof_stiffness[i]
            franka_dof_props['damping'][i] = franka_dof_damping[i]
        else:
            franka_dof_props['stiffness'][i] = 7000.0
            franka_dof_props['damping'][i] = 50.0
        self.franka_dof_lower_limits.append(franka_dof_props['lower'][i])
        self.franka_dof_upper_limits.append(franka_dof_props['upper'][i])
    self.franka_dof_lower_limits = to_torch(self.franka_dof_lower_limits, device=self.device)
    self.franka_dof_upper_limits = to_torch(self.franka_dof_upper_limits, device=self.device)
    self.franka_dof_speed_scales = torch.ones_like(self.franka_dof_lower_limits)
    self.franka_dof_speed_scales[[7, 8]] = 0.1
    franka_dof_props['effort'][7] = 200
    franka_dof_props['effort'][8] = 200
    franka_start_pose = gymapi.Transform()
    franka_start_pose.p = gymapi.Vec3(1.0, 0.0, 0.0)
    franka_start_pose.r = gymapi.Quat(0.0, 0.0, 1.0, 0.0)
    franka_start_tip_pose = gymapi.Transform()
    franka_start_tip_pose.p = gymapi.Vec3 (1.3,0.0, 1)
    # compute aggregate size
    num_franka_shapes = self.gym.get_asset_rigid_shape_count(franka_asset)
    num_ball_bodies = self.gym.get_asset_rigid_body_count(ball_asset)
    num_ball_shapes = self.gym.get_asset_rigid_shape_count(ball_asset)
    max_agg_bodies = num_franka_bodies + num_ball_bodies
    max_agg_shapes = num_franka_shapes + num_ball_shapes
    self.frankas = []
    self.cabinets = []
    self.default_prop_states = []
    self.prop_start = []
    self.envs = []
    self.ball_handles=[]
    self.ball_actor_indices=[]
    for i in range(self.num_envs):
        # create env instance
        env_ptr = self.gym.create_env(
            self.sim, lower, upper, num_per_row
        if self.aggregate_mode >= 3:
            self.gym.begin_aggregate(env_ptr, max_agg_bodies, max_agg_shapes, True)
        franka_actor = self.gym.create_actor(env_ptr, franka_asset, franka_start_pose, "franka", i, 1, 0)
        self.gym.set_actor_dof_properties(env_ptr, franka_actor, franka_dof_props)
        ball_actor = self.gym.create_actor (env_ptr,ball_asset, franka_start_tip_pose, "ball", 2)
        ball_actor_idx = self.gym.get_actor_index(env_ptr, ball_actor, gymapi.DOMAIN_SIM)
        self.ball_actor_indices.append(ball_actor_idx)
        self.gym.set_actor_dof_properties(env_ptr, ball_actor, ball_dof_props)
        if self.aggregate_mode == 2:
        if self.aggregate_mode > 0:
            self.gym.end_aggregate(env_ptr)
        self.envs.append(env_ptr)
        self.frankas.append(franka_actor)
    self.hand_handle = self.gym.find_actor_rigid_body_handle(env_ptr, franka_actor, "panda_link7")
    self.ball_actor_indices = to_torch(self.ball_actor_indices, dtype=torch.long, device=self.device)
    self.init_data()
def init_data(self):
    hand = self.gym.find_actor_rigid_body_handle(self.envs[0], self.frankas[0], "panda_link7")
    hand_pose = self.gym.get_rigid_transform(self.envs[0], hand)
def compute_reward(self, actions):
    self.rew_buf[:], self.reset_buf[:] = compute_franka_reward(
        self.reset_buf, self.progress_buf, self.hand_pos, self.sphere_poses, self.max_episode_length
def compute_observations(self):
    self.hand_pos = self.rigid_body_states[:, self.hand_handle][:, 0:3]
    self.sphere_poses = self.root_state_tensor[self.ball_actor_indices, 0:3]
    dof_pos_scaled = (2.0 * (self.franka_dof_pos - self.franka_dof_lower_limits)
                      / (self.franka_dof_upper_limits - self.franka_dof_lower_limits) - 1.0)
    #to_target = self.sphere_poses - self.hand_pos
    self.obs_buf[..., 0:9] = dof_pos_scaled
    self.obs_buf[..., 9:18] = self.franka_dof_vel
    print (self.franka_dof_vel[0])
    self.obs_buf[..., 18:21] = self.sphere_poses
    #self.obs_buf[..., 21:24] = self.sphere_poses
    return self.obs_buf
def reset_idx(self, env_ids):
    env_ids_int32 = env_ids.to(dtype=torch.int32)
    # reset franka
    pos = tensor_clamp(
        self.franka_default_dof_pos.unsqueeze(0) + 0.25 * (torch.rand((len(env_ids), self.num_franka_dofs), device=self.device) - 0.5),
        self.franka_dof_lower_limits, self.franka_dof_upper_limits)
    self.franka_dof_pos[env_ids, :] = pos
    self.franka_dof_vel[env_ids, :] = torch.zeros_like(self.franka_dof_vel[env_ids])
    self.franka_dof_targets[env_ids, :self.num_franka_dofs] = pos
    multi_env_ids_int32 = self.global_indices[env_ids, :1].flatten()
    self.gym.set_dof_position_target_tensor_indexed(self.sim,
                                                     gymtorch.unwrap_tensor(self.franka_dof_targets),
                                                     gymtorch.unwrap_tensor(multi_env_ids_int32), len(multi_env_ids_int32))
    self.gym.set_dof_state_tensor_indexed(self.sim,
                                      gymtorch.unwrap_tensor(self.dof_state),
    self.progress_buf[env_ids] = 0
    self.reset_buf[env_ids] = 0
def pre_physics_step(self, actions):
    self.actions = actions.clone().to(self.device)
    targets = self.franka_dof_targets[:, :self.num_franka_dofs] + self.franka_dof_speed_scales * self.dt * self.actions * self.action_scale
    self.franka_dof_targets[:, :self.num_franka_dofs] = tensor_clamp(
        targets, self.franka_dof_lower_limits, self.franka_dof_upper_limits)
    env_ids_int32 = torch.arange(self.num_envs, dtype=torch.int32, device=self.device)
    self.gym.set_dof_position_target_tensor(self.sim,
                                            gymtorch.unwrap_tensor(self.franka_dof_targets))
def post_physics_step(self):
    self.progress_buf += 1
    env_ids = self.reset_buf.nonzero(as_tuple=False).squeeze(-1)
    if len(env_ids) > 0:
        self.reset_idx(env_ids)
    self.compute_observations()
    self.compute_reward(self.actions)
    # debug viz
    if self.viewer and self.debug_viz:
        self.gym.clear_lines(self.viewer)
###=========================jit functions=========================###
@torch.jit.script
def compute_franka_reward(
reset_buf, progress_buf,hand_pos, sphere_poses, max_episode_length
# type: (Tensor, Tensor, Tensor, Tensor, float) β†’ Tuple[Tensor, Tensor]
# distance from hand to the drawer
d = torch.norm(hand_pos - sphere_poses, p=2, dim=-1)
dist_reward = 1.0 / (1.0 + d ** 2)
dist_reward *= dist_reward
dist_reward = torch.where(d <= 0.02, dist_reward * 2, dist_reward)
rewards= dist_reward
reset_buf = torch.where( abs(d)< 0.02,
                        torch.ones_like(reset_buf), reset_buf)
reset_buf = torch.where(progress_buf >= max_episode_length - 1, torch.ones_like(reset_buf), reset_buf)
return rewards, reset_buf
@torch.jit.script
def compute_grasp_transforms(hand_rot, hand_pos, franka_local_grasp_rot, franka_local_grasp_pos,
drawer_rot, drawer_pos, drawer_local_grasp_rot, drawer_local_grasp_pos
# type: (Tensor, Tensor, Tensor, Tensor, Tensor, Tensor, Tensor, Tensor) β†’ Tuple[Tensor, Tensor, Tensor, Tensor]
global_franka_rot, global_franka_pos = tf_combine(
    hand_rot, hand_pos, franka_local_grasp_rot, franka_local_grasp_pos)
global_drawer_rot, global_drawer_pos = tf_combine(
    drawer_rot, drawer_pos, drawer_local_grasp_rot, drawer_local_grasp_pos)
return global_franka_rot, global_franka_pos, global_drawer_rot, global_drawer_pos
Have you solved this problem?
Not yet, trying to apply different reward functions, but not actually moving forward:(
