Please provide the following info (check/uncheck the boxes after creating this topic): Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
After working very reliably, our system is showing a “Camera disconnect” message and RoadRunner shows a blank screen which sometimes recovers itself but sometimes just stays like that and a power cycle is required.
Checking the logs, it seems the attached message correlates with this event: “RRMainpipeline: camera queue pop_front time out 500000”
Also, this message shows up as well: [15483.617776] serial-tegra 3110000.serial: RxData DMA copy to tty layer failed
Trying to understand if this could be a hardware issue, Xavier A thing or software related (DriveWorks).
Any suggestions or ideas to troubleshoot the issue are welcome
@VickNV, We narrowed down the camera issue to the Forward 60 FOV camera. Will check connections and possibly swap it to another GSML port. Just to provide an update.
