Robot Becomes Unresponsive After Saving USD — Policy Not Persisting in Project
Isaac Sim Version
4.5.0
Operating System
Ubuntu 22.04
GPU Information
  • Model: NVIDIA L4
  • Driver Version: 550.54.15
  • CUDA Version: 12.4
Problem
I opened an example project that includes a robot with a Policy, such as the Spot example. After that, I made some edits—like modifying the scene and adding some ROS node graph scripts. Everything runs fine at that stage: Spot moves correctly according to the control policy.
However, once I save the project (as a USD) and reopen it, Spot becomes completely rigid and unresponsive. I currently suspect that the Policy is not being saved into my project, but I can’t find where I’m supposed to store it or how to assign an existing Policy to a robot directly through the interface.
Could anybody tell me how to resolve this issue?
Screenshots
I directly opened Robotics Examples / POLICY / Quadruped, and after modifying the background and other elements, the simulation and control of the quadruped robot still worked normally before saving.
But after I save and reopen the project, the quadruped becomes completely rigid or collapses, and I can’t control it at all.
@patrick.hou i am just another user, but can you confirm if the same issue persists if you were to load the robotic example, save the USD without making any changes, and reopen the USD? i am trying to isolate the issue to whether it’s related to your custom changes first before making further assumptions.
Yes, even if I open the example file, make no changes, and save it directly, the same issue still occurs.
Could you please try upgrading to the latest Isaac Sim release (5.1.0 GA) and check if the issue still occurs?
Hello!
Best regards,
