Thanks for your reply.
i just use UR3 STEP file for test. Because my robot model only have STEP file. i have try Save Flattened As, and Re-Open flattened usd file, added rigid body and colliders,. then Start Robot Wizard. At Step 3,when i have configed robot hierarchy and pressed Add Colliders button. But there is nothing show in Step 4 Window, like below.
In addition, there are numerous errors as follows:
026-05-26T07:28:27Z [2,629,488ms] [Warning] [omni.physx.scripts.utils] setCollider: /UR3/UR3/tn__31220STEP_qD/tn__MoveFace1_j9/Mesh is a part of a rigid body. Resetting approximation shape from none (trimesh) to convexHull
2026-05-26T07:28:51Z [2,652,774ms] [Warning] [omni.physx.scripts.utils] setCollider: /UR3/UR3/tn__31220STEP_qD/tn__CutExtrude23_zH/Mesh is a part of a rigid body. Resetting approximation shape from none (trimesh) to convexHull
2026-05-26T07:28:51Z [2,652,777ms] [Warning] [omni.physx.scripts.utils] setCollider: /UR3/UR3/tn__31220STEP_qD/tn__MoveFace1_j9/Mesh is a part of a rigid body. Resetting approximation shape from none (trimesh) to convexHull
2026-05-26T07:29:55Z [2,717,448ms] [Warning] [omni.physx.scripts.utils] setCollider: /UR3/UR3/tn__31602STEP_qD/Imported1/Mesh is a part of a rigid body. Resetting approximation shape from none (trimesh) to convexHull
2026-05-26T07:29:55Z [2,717,451ms] [Warning] [omni.physx.scripts.utils] setCollider: /UR3/UR3/tn__31602STEP_qD/Imported2/Mesh is a part of a rigid body. Resetting approximation shape from none (trimesh) to convexHull
2026-05-26T07:29:55Z [2,717,454ms] [Warning] [omni.physx.scripts.utils] setCollider: /UR3/UR3/tn__31602STEP_qD/Imported3/Mesh is a part of a rigid body. Resetting approximation shape from none (trimesh) to convexHull
2026-05-26T07:29:55Z [2,717,456ms] [Warning] [omni.physx.scripts.utils] setCollider: /UR3/UR3/tn__31602STEP_qD/Imported5/Mesh is a part of a rigid body. Resetting approximation shape from none (trimesh) to convexHull
2026-05-26T07:29:55Z [2,717,459ms] [Warning] [omni.physx.scripts.utils] setCollider: /UR3/UR3/tn__31602STEP_qD/Imported6/Mesh is a part of a rigid body. Resetting approximation shape from none (trimesh) to convexHull
2026-05-26T07:29:55Z [2,717,462ms] [Warning] [omni.physx.scripts.utils] setCollider: /UR3/UR3/tn__31602STEP_qD/tn__MoveFace2_j9/Mesh is a part of a rigid body. Resetting approximation shape from none (trimesh) to convexHull
2026-05-26T07:29:55Z [2,717,465ms] [Warning] [omni.physx.scripts.utils] setCollider: /UR3/UR3/tn__31126STEP_qD/Revolve2/Mesh is a part of a rigid body. Resetting approximation shape from none (trimesh) to convexHull
2026-05-26T07:29:55Z [2,717,468ms] [Warning] [omni.physx.scripts.utils] setCollider: /UR3/UR3/tn__31126STEP_qD/tn__BossExtrude1_VI/Mesh is a part of a rigid body. Resetting approximation shape from none (trimesh) to convexHull
2026-05-26T07:29:55Z [2,717,470ms] [Warning] [omni.physx.scripts.utils] setCollider: /UR3/UR3/tn__31126STEP_qD/tn__BossExtrude2_VI/Mesh is a part of a rigid body. Resetting approximation shape from none (trimesh) to convexHull
2026-05-26T07:29:55Z [2,717,473ms] [Warning] [omni.physx.scripts.utils] setCollider: /UR3/UR3/tn__31601STEP_qD/tn__MoveFace1_j9/Mesh is a part of a rigid body. Resetting approximation shape from none (trimesh) to convexHull
2026-05-26T07:29:55Z [2,717,476ms] [Warning] [omni.physx.scripts.utils] setCollider: /UR3/UR3/tn__31116STEP_qD/Revolve2/Mesh is a part of a rigid body. Resetting approximation shape from none (trimesh) to convexHull
2026-05-26T07:29:55Z [2,717,479ms] [Warning] [omni.physx.scripts.utils] setCollider: /UR3/UR3/tn__31116STEP_qD/tn__BossExtrude1_VI/Mesh is a part of a rigid body. Resetting approximation shape from none (trimesh) to convexHull
2026-05-26T07:29:55Z [2,717,482ms] [Warning] [omni.physx.scripts.utils] setCollider: /UR3/UR3/tn__31600STEP_qD/NONE/Mesh is a part of a rigid body. Resetting approximation shape from none (trimesh) to convexHull
2026-05-26T07:29:55Z [2,717,485ms] [Warning] [omni.physx.scripts.utils] setCollider: /UR3/UR3/tn__31600STEP_qD/tn__BossExtrude4_VI/Mesh is a part of a rigid body. Resetting approximation shape from none (trimesh) to convexHull
2026-05-26T07:29:55Z [2,717,488ms] [Warning] [omni.physx.scripts.utils] setCollider: /UR3/UR3/tn__31000STEP_qD/tn__BossExtrude15_jJ/Mesh is a part of a rigid body. Resetting approximation shape from none (trimesh) to convexHull
2026-05-26T07:29:55Z [2,717,490ms] [Warning] [omni.physx.scripts.utils] setCollider: /UR3/UR3/tn__31000STEP_qD/tn__BossExtrude16_jJ/Mesh is a part of a rigid body. Resetting approximation shape from none (trimesh) to convexHull
2026-05-26T07:29:55Z [2,717,493ms] [Warning] [omni.physx.scripts.utils] setCollider: /UR3/UR3/tn__31600STEP_1_nG/NONE/Mesh is a part of a rigid body. Resetting approximation shape from none (trimesh) to convexHull
2026-05-26T07:29:55Z [2,717,496ms] [Warning] [omni.physx.scripts.utils] setCollider: /UR3/UR3/tn__31600STEP_1_nG/tn__BossExtrude4_VI/Mesh is a part of a rigid body. Resetting approximation shape from none (trimesh) to convexHull
2026-05-26T07:29:55Z [2,717,499ms] [Warning] [omni.physx.scripts.utils] setCollider: /UR3/UR3/tn__34011STEP_qD/tn__BossExtrude8_VI/Mesh is a part of a rigid body. Resetting approximation shape from none (trimesh) to convexHull
2026-05-26T07:29:55Z [2,717,502ms] [Warning] [omni.physx.scripts.utils] setCollider: /UR3/UR3/tn__34011STEP_1_nG/tn__BossExtrude8_VI/Mesh is a part of a rigid body. Resetting approximation shape from none (trimesh) to convexHull
2026-05-26T07:29:55Z [2,717,505ms] [Warning] [omni.physx.scripts.utils] setCollider: /UR3/UR3/tn__31602STEP_1_nG/Imported1/Mesh is a part of a rigid body. Resetting approximation shape from none (trimesh) to convexHull
2026-05-26T07:29:55Z [2,717,508ms] [Warning] [omni.physx.scripts.utils] setCollider: /UR3/UR3/tn__31602STEP_1_nG/Imported2/Mesh is a part of a rigid body. Resetting approximation shape from none (trimesh) to convexHull
2026-05-26T07:29:55Z [2,717,511ms] [Warning] [omni.physx.scripts.utils] setCollider: /UR3/UR3/tn__31602STEP_1_nG/Imported3/Mesh is a part of a rigid body. Resetting approximation shape from none (trimesh) to convexHull
2026-05-26T07:29:55Z [2,717,513ms] [Warning] [omni.physx.scripts.utils] setCollider: /UR3/UR3/tn__31602STEP_1_nG/Imported5/Mesh is a part of a rigid body. Resetting approximation shape from none (trimesh) to convexHull
2026-05-26T07:29:55Z [2,717,516ms] [Warning] [omni.physx.scripts.utils] setCollider: /UR3/UR3/tn__31602STEP_1_nG/Imported6/Mesh is a part of a rigid body. Resetting approximation shape from none (trimesh) to convexHull
2026-05-26T07:29:55Z [2,717,519ms] [Warning] [omni.physx.scripts.utils] setCollider: /UR3/UR3/tn__31602STEP_1_nG/tn__MoveFace2_j9/Mesh is a part of a rigid body. Resetting approximation shape from none (trimesh) to convexHull
2026-05-26T07:29:55Z [2,717,522ms] [Warning] [omni.physx.scripts.utils] setCollider: /UR3/UR3/tn__34011STEP_2_nG/tn__BossExtrude8_VI/Mesh is a part of a rigid body. Resetting approximation shape from none (trimesh) to convexHull
2026-05-26T07:29:55Z [2,717,525ms] [Warning] [omni.physx.scripts.utils] setCollider: /UR3/UR3/tn__31600STEP_2_nG/NONE/Mesh is a part of a rigid body. Resetting approximation shape from none (trimesh) to convexHull
2026-05-26T07:29:55Z [2,717,528ms] [Warning] [omni.physx.scripts.utils] setCollider: /UR3/UR3/tn__31600STEP_2_nG/tn__BossExtrude4_VI/Mesh is a part of a rigid body. Resetting approximation shape from none (trimesh) to convexHull
2026-05-26T07:29:55Z [2,717,530ms] [Warning] [omni.physx.scripts.utils] setCollider: /UR3/UR3/tn__31690STEP_qD/tn__MoveFace5_j9/Mesh is a part of a rigid body. Resetting approximation shape from none (trimesh) to convexHull
2026-05-26T07:29:55Z [2,717,533ms] [Warning] [omni.physx.scripts.utils] setCollider: /UR3/UR3/tn__31690STEP_qD/tn__BossExtrude29_jJ/Mesh is a part of a rigid body. Resetting approximation shape from none (trimesh) to convexHull
2026-05-26T07:29:55Z [2,717,536ms] [Warning] [omni.physx.scripts.utils] setCollider: /UR3/UR3/tn__34111STEP_qD/Imported1/Mesh is a part of a rigid body. Resetting approximation shape from none (trimesh) to convexHull
2026-05-26T07:30:01Z [2,722,689ms] [Warning] [omni.kit.widget.cache_indicator.utils] No [paths] found in omniverse.toml
2026-05-26T07:30:06Z [2,728,278ms] [Warning] [omni.usd] Warning: in SdfPath at line 144 of /builds/omniverse/usd-ci/USD/pxr/usd/sdf/path.cpp -- Ill-formed SdfPath <>: :1:0(0): parse error matching pxrInternal_v0_24__pxrReserved__::Sdf_PathParser::Path
2026-05-26T07:38:52Z [3,253,731ms] [Warning] [omni.kit.window.property.templates.simple_property_widget] GeometrySchemaAttributesWidget.build_items took 0.30205965699860826 seconds
2026-05-26T07:40:48Z [3,369,887ms] [Error] [omni.ui.python] RuntimeError: Accessed invalid null prim
At:
/home/tk/isaacsim/exts/isaacsim.robot_setup.wizard/isaacsim/robot_setup/wizard/utils/utils.py(50): copy_prim_hierarchy
/home/tk/isaacsim/exts/isaacsim.robot_setup.wizard/isaacsim/robot_setup/wizard/pages/robot_hierarchy.py(313): _parent_button_clicked
/home/tk/isaacsim/exts/isaacsim.robot_setup.wizard/isaacsim/robot_setup/wizard/pages/robot_hierarchy.py(139): <lambda>
2026-05-26T07:42:36Z [3,477,884ms] [Warning] [omni.kit.menu.utils.app_menu] add_menu_items: menu [<MenuItemDescription name:'New'>, <MenuItemDescription name:'Open'>, <MenuItemDescription name:'Re-open with New Edit Layer'>, <MenuItemDescription name:'Save'>, <MenuItemDescription name:'Save With Options'>, <MenuItemDescription name:'Save As...'>, <MenuItemDescription name:'Save Flattened As...'>, <MenuItemDescription name:'Add Reference'>, <MenuItemDescription name:'Add Payload'>, <MenuItemDescription name:'Exit'>] cannot change delegate
2026-05-26T07:42:36Z [3,478,166ms] [Warning] [omni.kit.menu.utils.app_menu] add_menu_items: menu [<MenuItemDescription name:'New'>, <MenuItemDescription name:'Open'>, <MenuItemDescription name:'Re-open with New Edit Layer'>, <MenuItemDescription name:'Save'>, <MenuItemDescription name:'Save With Options'>, <MenuItemDescription name:'Save As...'>, <MenuItemDescription name:'Save Flattened As...'>, <MenuItemDescription name:'Add Reference'>, <MenuItemDescription name:'Add Payload'>, <MenuItemDescription name:'Exit'>] cannot change delegate
2026-05-26T07:42:36Z [3,478,299ms] [Error] [omni.ui.python] RuntimeError: Accessed invalid expired 'Scope' prim </UR3/UR3/tn__31220STEP_qD/tn__CutExtrude23_zH/Looks>
At:
/home/tk/isaacsim/exts/isaacsim.robot_setup.wizard/isaacsim/robot_setup/wizard/builders/hierarchy_helper.py(170): move_prim_by_type
/home/tk/isaacsim/exts/isaacsim.robot_setup.wizard/isaacsim/robot_setup/wizard/builders/hierarchy_helper.py(172): move_prim_by_type
/home/tk/isaacsim/exts/isaacsim.robot_setup.wizard/isaacsim/robot_setup/wizard/builders/hierarchy_helper.py(91): apply_hierarchy
/home/tk/isaacsim/exts/isaacsim.robot_setup.wizard/isaacsim/robot_setup/wizard/pages/robot_hierarchy.py(392): _apply_new_structure
/home/tk/isaacsim/exts/isaacsim.robot_setup.wizard/isaacsim/robot_setup/wizard/utils/ui_utils.py(159): next_step
/home/tk/isaacsim/exts/isaacsim.robot_setup.wizard/isaacsim/robot_setup/wizard/pages/robot_hierarchy.py(184): <lambda>
2026-05-26T07:42:37Z [3,479,478ms] [Warning] [omni.kit.widget.cache_indicator.utils] No [paths] found in omniverse.toml
2026-05-26T07:43:54Z [3,555,983ms] [Warning] [omni.kit.menu.utils.app_menu] add_menu_items: menu [<MenuItemDescription name:'New'>, <MenuItemDescription name:'Open'>, <MenuItemDescription name:'Re-open with New Edit Layer'>, <MenuItemDescription name:'Save'>, <MenuItemDescription name:'Save With Options'>, <MenuItemDescription name:'Save As...'>, <MenuItemDescription name:'Save Flattened As...'>, <MenuItemDescription name:'Add Reference'>, <MenuItemDescription name:'Add Payload'>, <MenuItemDescription name:'Exit'>] cannot change delegate
2026-05-26T07:43:54Z [3,556,093ms] [Warning] [carb] Client omni.anim.navigation.core.plugin has acquired [carb::settings::ISettings v1.0] 100 times. Consider accessing this interface with carb::getCachedInterface() (Performance warning)
2026-05-26T07:43:54Z [3,556,093ms] [Warning] [carb] Client omni.anim.navigation.core.plugin has acquired [carb::dictionary::IDictionary v1.1] 100 times. Consider accessing this interface with carb::getCachedInterface() (Performance warning)
2026-05-26T07:43:54Z [3,556,273ms] [Warning] [omni.kit.menu.utils.app_menu] add_menu_items: menu [<MenuItemDescription name:'New'>, <MenuItemDescription name:'Open'>, <MenuItemDescription name:'Re-open with New Edit Layer'>, <MenuItemDescription name:'Save'>, <MenuItemDescription name:'Save With Options'>, <MenuItemDescription name:'Save As...'>, <MenuItemDescription name:'Save Flattened As...'>, <MenuItemDescription name:'Add Reference'>, <MenuItemDescription name:'Add Payload'>, <MenuItemDescription name:'Exit'>] cannot change delegate
2026-05-26T07:43:54Z [3,556,395ms] [Error] [omni.ui.python] RuntimeError: Accessed invalid expired 'Scope' prim </UR3/UR3/tn__31602STEP_1_nG/Imported1/Looks>
At:
2026-05-26T07:43:58Z [3,560,483ms] [Warning] [omni.kit.menu.utils.app_menu] add_menu_items: menu [<MenuItemDescription name:'New'>, <MenuItemDescription name:'Open'>, <MenuItemDescription name:'Re-open with New Edit Layer'>, <MenuItemDescription name:'Save'>, <MenuItemDescription name:'Save With Options'>, <MenuItemDescription name:'Save As...'>, <MenuItemDescription name:'Save Flattened As...'>, <MenuItemDescription name:'Add Reference'>, <MenuItemDescription name:'Add Payload'>, <MenuItemDescription name:'Exit'>] cannot change delegate
2026-05-26T07:43:59Z [3,560,766ms] [Warning] [omni.kit.menu.utils.app_menu] add_menu_items: menu [<MenuItemDescription name:'New'>, <MenuItemDescription name:'Open'>, <MenuItemDescription name:'Re-open with New Edit Layer'>, <MenuItemDescription name:'Save'>, <MenuItemDescription name:'Save With Options'>, <MenuItemDescription name:'Save As...'>, <MenuItemDescription name:'Save Flattened As...'>, <MenuItemDescription name:'Add Reference'>, <MenuItemDescription name:'Add Payload'>, <MenuItemDescription name:'Exit'>] cannot change delegate
2026-05-26T07:43:59Z [3,560,885ms] [Error] [omni.ui.python] RuntimeError: Accessed invalid expired 'Scope' prim </UR3/UR3/tn__31602STEP_qD/Imported1/Looks>
At:
2026-05-26T07:44:04Z [3,565,806ms] [Warning] [omni.kit.widget.cache_indicator.utils] No [paths] found in omniverse.toml
2026-05-26T07:44:04Z [3,565,824ms] [Warning] [omni.kit.widget.cache_indicator.utils] No [paths] found in omniverse.toml
2026-05-26T07:47:07Z [3,749,294ms] [Warning] [omni.kit.menu.utils.app_menu] add_menu_items: menu [<MenuItemDescription name:'New'>, <MenuItemDescription name:'Open'>, <MenuItemDescription name:'Re-open with New Edit Layer'>, <MenuItemDescription name:'Save'>, <MenuItemDescription name:'Save With Options'>, <MenuItemDescription name:'Save As...'>, <MenuItemDescription name:'Save Flattened As...'>, <MenuItemDescription name:'Add Reference'>, <MenuItemDescription name:'Add Payload'>, <MenuItemDescription name:'Exit'>] cannot change delegate
2026-05-26T07:47:07Z [3,749,592ms] [Warning] [omni.kit.menu.utils.app_menu] add_menu_items: menu [<MenuItemDescription name:'New'>, <MenuItemDescription name:'Open'>, <MenuItemDescription name:'Re-open with New Edit Layer'>, <MenuItemDescription name:'Save'>, <MenuItemDescription name:'Save With Options'>, <MenuItemDescription name:'Save As...'>, <MenuItemDescription name:'Save Flattened As...'>, <MenuItemDescription name:'Add Reference'>, <MenuItemDescription name:'Add Payload'>, <MenuItemDescription name:'Exit'>] cannot change delegate
2026-05-26T07:47:08Z [3,749,719ms] [Error] [omni.ui.python] RuntimeError: Accessed invalid expired 'GeomSubset' prim </UR3/UR3/tn__31126STEP_qD/Revolve2/Mesh/Diffuse_10>
At:
2026-05-26T07:47:12Z [3,754,374ms] [Warning] [omni.kit.widget.cache_indicator.utils] No [paths] found in omniverse.toml
2026-05-26T07:47:16Z [3,758,508ms] [Warning] [omni.kit.menu.utils.app_menu] add_menu_items: menu [<MenuItemDescription name:'New'>, <MenuItemDescription name:'Open'>, <MenuItemDescription name:'Re-open with New Edit Layer'>, <MenuItemDescription name:'Save'>, <MenuItemDescription name:'Save With Options'>, <MenuItemDescription name:'Save As...'>, <MenuItemDescription name:'Save Flattened As...'>, <MenuItemDescription name:'Add Reference'>, <MenuItemDescription name:'Add Payload'>, <MenuItemDescription name:'Exit'>] cannot change delegate
2026-05-26T07:47:17Z [3,758,809ms] [Warning] [omni.kit.menu.utils.app_menu] add_menu_items: menu [<MenuItemDescription name:'New'>, <MenuItemDescription name:'Open'>, <MenuItemDescription name:'Re-open with New Edit Layer'>, <MenuItemDescription name:'Save'>, <MenuItemDescription name:'Save With Options'>, <MenuItemDescription name:'Save As...'>, <MenuItemDescription name:'Save Flattened As...'>, <MenuItemDescription name:'Add Reference'>, <MenuItemDescription name:'Add Payload'>, <MenuItemDescription name:'Exit'>] cannot change delegate
2026-05-26T07:47:17Z [3,758,927ms] [Error] [omni.ui.python] RuntimeError: Accessed invalid expired 'Scope' prim </UR3/UR3/tn__31601STEP_qD/tn__MoveFace1_j9/Looks>
At:
2026-05-26T07:47:18Z [3,760,185ms] [Warning] [omni.kit.widget.cache_indicator.utils] No [paths] found in omniverse.toml
2026-05-26T07:47:22Z [3,764,223ms] [Warning] [omni.kit.menu.utils.app_menu] add_menu_items: menu [<MenuItemDescription name:'New'>, <MenuItemDescription name:'Open'>, <MenuItemDescription name:'Re-open with New Edit Layer'>, <MenuItemDescription name:'Save'>, <MenuItemDescription name:'Save With Options'>, <MenuItemDescription name:'Save As...'>, <MenuItemDescription name:'Save Flattened As...'>, <MenuItemDescription name:'Add Reference'>, <MenuItemDescription name:'Add Payload'>, <MenuItemDescription name:'Exit'>] cannot change delegate
2026-05-26T07:47:22Z [3,764,514ms] [Warning] [omni.kit.menu.utils.app_menu] add_menu_items: menu [<MenuItemDescription name:'New'>, <MenuItemDescription name:'Open'>, <MenuItemDescription name:'Re-open with New Edit Layer'>, <MenuItemDescription name:'Save'>, <MenuItemDescription name:'Save With Options'>, <MenuItemDescription name:'Save As...'>, <MenuItemDescription name:'Save Flattened As...'>, <MenuItemDescription name:'Add Reference'>, <MenuItemDescription name:'Add Payload'>, <MenuItemDescription name:'Exit'>] cannot change delegate
2026-05-26T07:47:23Z [3,764,639ms] [Error] [omni.ui.python] RuntimeError: Accessed invalid expired 'Scope' prim </UR3/UR3/tn__34111STEP_qD/Imported1/Looks>
At:
2026-05-26T07:47:24Z [3,765,741ms] [Warning] [omni.kit.widget.cache_indicator.utils] No [paths] found in omniverse.toml
2026-05-26T07:47:26Z [3,768,190ms] [Warning] [omni.kit.menu.utils.app_menu] add_menu_items: menu [<MenuItemDescription name:'New'>, <MenuItemDescription name:'Open'>, <MenuItemDescription name:'Re-open with New Edit Layer'>, <MenuItemDescription name:'Save'>, <MenuItemDescription name:'Save With Options'>, <MenuItemDescription name:'Save As...'>, <MenuItemDescription name:'Save Flattened As...'>, <MenuItemDescription name:'Add Reference'>, <MenuItemDescription name:'Add Payload'>, <MenuItemDescription name:'Exit'>] cannot change delegate
2026-05-26T07:47:26Z [3,768,487ms] [Warning] [omni.kit.menu.utils.app_menu] add_menu_items: menu [<MenuItemDescription name:'New'>, <MenuItemDescription name:'Open'>, <MenuItemDescription name:'Re-open with New Edit Layer'>, <MenuItemDescription name:'Save'>, <MenuItemDescription name:'Save With Options'>, <MenuItemDescription name:'Save As...'>, <MenuItemDescription name:'Save Flattened As...'>, <MenuItemDescription name:'Add Reference'>, <MenuItemDescription name:'Add Payload'>, <MenuItemDescription name:'Exit'>] cannot change delegate
2026-05-26T07:47:26Z [3,768,613ms] [Error] [omni.ui.python] RuntimeError: Accessed invalid expired 'GeomSubset' prim </UR3/UR3/tn__31690STEP_qD/tn__MoveFace5_j9/Mesh/Diffuse_25>
At:
2026-05-26T07:47:28Z [3,769,835ms] [Warning] [omni.kit.widget.cache_indicator.utils] No [paths] found in omniverse.toml
2026-05-26T07:47:30Z [3,771,639ms] [Warning] [omni.kit.menu.utils.app_menu] add_menu_items: menu [<MenuItemDescription name:'New'>, <MenuItemDescription name:'Open'>, <MenuItemDescription name:'Re-open with New Edit Layer'>, <MenuItemDescription name:'Save'>, <MenuItemDescription name:'Save With Options'>, <MenuItemDescription name:'Save As...'>, <MenuItemDescription name:'Save Flattened As...'>, <MenuItemDescription name:'Add Reference'>, <MenuItemDescription name:'Add Payload'>, <MenuItemDescription name:'Exit'>] cannot change delegate
2026-05-26T07:47:30Z [3,771,936ms] [Warning] [omni.kit.menu.utils.app_menu] add_menu_items: menu [<MenuItemDescription name:'New'>, <MenuItemDescription name:'Open'>, <MenuItemDescription name:'Re-open with New Edit Layer'>, <MenuItemDescription name:'Save'>, <MenuItemDescription name:'Save With Options'>, <MenuItemDescription name:'Save As...'>, <MenuItemDescription name:'Save Flattened As...'>, <MenuItemDescription name:'Add Reference'>, <MenuItemDescription name:'Add Payload'>, <MenuItemDescription name:'Exit'>] cannot change delegate
2026-05-26T07:47:30Z [3,772,060ms] [Error] [omni.ui.python] RuntimeError: Accessed invalid expired 'Scope' prim </UR3/UR3/tn__31116STEP_qD/Revolve2/Looks>
At:
2026-05-26T07:47:31Z [3,773,041ms] [Warning] [omni.kit.widget.cache_indicator.utils] No [paths] found in omniverse.toml
2026-05-26T07:47:33Z [3,775,173ms] [Warning] [omni.kit.menu.utils.app_menu] add_menu_items: menu [<MenuItemDescription name:'New'>, <MenuItemDescription name:'Open'>, <MenuItemDescription name:'Re-open with New Edit Layer'>, <MenuItemDescription name:'Save'>, <MenuItemDescription name:'Save With Options'>, <MenuItemDescription name:'Save As...'>, <MenuItemDescription name:'Save Flattened As...'>, <MenuItemDescription name:'Add Reference'>, <MenuItemDescription name:'Add Payload'>, <MenuItemDescription name:'Exit'>] cannot change delegate
2026-05-26T07:47:33Z [3,775,474ms] [Warning] [omni.kit.menu.utils.app_menu] add_menu_items: menu [<MenuItemDescription name:'New'>, <MenuItemDescription name:'Open'>, <MenuItemDescription name:'Re-open with New Edit Layer'>, <MenuItemDescription name:'Save'>, <MenuItemDescription name:'Save With Options'>, <MenuItemDescription name:'Save As...'>, <MenuItemDescription name:'Save Flattened As...'>, <MenuItemDescription name:'Add Reference'>, <MenuItemDescription name:'Add Payload'>, <MenuItemDescription name:'Exit'>] cannot change delegate
2026-05-26T07:47:33Z [3,775,596ms] [Error] [omni.ui.python] RuntimeError: Accessed invalid expired 'GeomSubset' prim </UR3/UR3/tn__31600STEP_qD/NONE/Mesh/Diffuse_17>
At:
2026-05-26T07:47:33Z [3,775,604ms] [Warning] [carb] Client omni.kit.viewport.legacy_gizmos has acquired [carb::settings::ISettings v1.0] 100 times. Consider accessing this interface with carb::getCachedInterface() (Performance warning)
2026-05-26T07:47:33Z [3,775,604ms] [Warning] [carb] Client omni.kit.viewport.legacy_gizmos has acquired [carb::dictionary::IDictionary v1.1] 100 times. Consider accessing this interface with carb::getCachedInterface() (Performance warning)
2026-05-26T07:47:35Z [3,777,351ms] [Warning] [omni.kit.widget.cache_indicator.utils] No [paths] found in omniverse.toml
2026-05-26T07:47:37Z [3,778,783ms] [Warning] [omni.kit.menu.utils.app_menu] add_menu_items: menu [<MenuItemDescription name:'New'>, <MenuItemDescription name:'Open'>, <MenuItemDescription name:'Re-open with New Edit Layer'>, <MenuItemDescription name:'Save'>, <MenuItemDescription name:'Save With Options'>, <MenuItemDescription name:'Save As...'>, <MenuItemDescription name:'Save Flattened As...'>, <MenuItemDescription name:'Add Reference'>, <MenuItemDescription name:'Add Payload'>, <MenuItemDescription name:'Exit'>] cannot change delegate
2026-05-26T07:47:37Z [3,779,089ms] [Warning] [omni.kit.menu.utils.app_menu] add_menu_items: menu [<MenuItemDescription name:'New'>, <MenuItemDescription name:'Open'>, <MenuItemDescription name:'Re-open with New Edit Layer'>, <MenuItemDescription name:'Save'>, <MenuItemDescription name:'Save With Options'>, <MenuItemDescription name:'Save As...'>, <MenuItemDescription name:'Save Flattened As...'>, <MenuItemDescription name:'Add Reference'>, <MenuItemDescription name:'Add Payload'>, <MenuItemDescription name:'Exit'>] cannot change delegate
2026-05-26T07:47:37Z [3,779,217ms] [Error] [omni.ui.python] RuntimeError: Accessed invalid expired 'Scope' prim </UR3/UR3/tn__34011STEP_1_nG/tn__BossExtrude8_VI/Looks>
At:
2026-05-26T07:47:38Z [3,780,314ms] [Warning] [omni.kit.widget.cache_indicator.utils] No [paths] found in omniverse.toml
2026-05-26T07:47:40Z [3,782,408ms] [Warning] [omni.kit.menu.utils.app_menu] add_menu_items: menu [<MenuItemDescription name:'New'>, <MenuItemDescription name:'Open'>, <MenuItemDescription name:'Re-open with New Edit Layer'>, <MenuItemDescription name:'Save'>, <MenuItemDescription name:'Save With Options'>, <MenuItemDescription name:'Save As...'>, <MenuItemDescription name:'Save Flattened As...'>, <MenuItemDescription name:'Add Reference'>, <MenuItemDescription name:'Add Payload'>, <MenuItemDescription name:'Exit'>] cannot change delegate
2026-05-26T07:47:41Z [3,782,718ms] [Warning] [omni.kit.menu.utils.app_menu] add_menu_items: menu [<MenuItemDescription name:'New'>, <MenuItemDescription name:'Open'>, <MenuItemDescription name:'Re-open with New Edit Layer'>, <MenuItemDescription name:'Save'>, <MenuItemDescription name:'Save With Options'>, <MenuItemDescription name:'Save As...'>, <MenuItemDescription name:'Save Flattened As...'>, <MenuItemDescription name:'Add Reference'>, <MenuItemDescription name:'Add Payload'>, <MenuItemDescription name:'Exit'>] cannot change delegate
2026-05-26T07:47:41Z [3,782,859ms] [Error] [omni.ui.python] RuntimeError: Accessed invalid expired 'Scope' prim </UR3/UR3/tn__34011STEP_2_nG/tn__BossExtrude8_VI/Looks>
At:
2026-05-26T07:47:42Z [3,784,360ms] [Warning] [omni.kit.widget.cache_indicator.utils] No [paths] found in omniverse.toml
2026-05-26T07:47:43Z [3,785,550ms] [Warning] [omni.kit.menu.utils.app_menu] add_menu_items: menu [<MenuItemDescription name:'New'>, <MenuItemDescription name:'Open'>, <MenuItemDescription name:'Re-open with New Edit Layer'>, <MenuItemDescription name:'Save'>, <MenuItemDescription name:'Save With Options'>, <MenuItemDescription name:'Save As...'>, <MenuItemDescription name:'Save Flattened As...'>, <MenuItemDescription name:'Add Reference'>, <MenuItemDescription name:'Add Payload'>, <MenuItemDescription name:'Exit'>] cannot change delegate
2026-05-26T07:47:43Z [3,785,609ms] [Warning] [carb] Client rtx.scenedb.plugin has acquired [carb::settings::ISettings v1.0] 100 times. Consider accessing this interface with carb::getCachedInterface() (Performance warning)
2026-05-26T07:47:44Z [3,785,858ms] [Warning] [omni.kit.menu.utils.app_menu] add_menu_items: menu [<MenuItemDescription name:'New'>, <MenuItemDescription name:'Open'>, <MenuItemDescription name:'Re-open with New Edit Layer'>, <MenuItemDescription name:'Save'>, <MenuItemDescription name:'Save With Options'>, <MenuItemDescription name:'Save As...'>, <MenuItemDescription name:'Save Flattened As...'>, <MenuItemDescription name:'Add Reference'>, <MenuItemDescription name:'Add Payload'>, <MenuItemDescription name:'Exit'>] cannot change delegate
2026-05-26T07:47:44Z [3,785,984ms] [Error] [omni.ui.python] RuntimeError: Accessed invalid expired 'GeomSubset' prim </UR3/UR3/tn__31600STEP_2_nG/NONE/Mesh/Diffuse_17>
At:
2026-05-26T07:47:46Z [3,788,299ms] [Warning] [omni.kit.widget.cache_indicator.utils] No [paths] found in omniverse.toml
2026-05-26T07:47:58Z [3,800,613ms] [Warning] [omni.kit.menu.utils.app_menu] add_menu_items: menu [<MenuItemDescription name:'New'>, <MenuItemDescription name:'Open'>, <MenuItemDescription name:'Re-open with New Edit Layer'>, <MenuItemDescription name:'Save'>, <MenuItemDescription name:'Save With Options'>, <MenuItemDescription name:'Save As...'>, <MenuItemDescription name:'Save Flattened As...'>, <MenuItemDescription name:'Add Reference'>, <MenuItemDescription name:'Add Payload'>, <MenuItemDescription name:'Exit'>] cannot change delegate
2026-05-26T07:47:59Z [3,800,924ms] [Warning] [omni.kit.menu.utils.app_menu] add_menu_items: menu [<MenuItemDescription name:'New'>, <MenuItemDescription name:'Open'>, <MenuItemDescription name:'Re-open with New Edit Layer'>, <MenuItemDescription name:'Save'>, <MenuItemDescription name:'Save With Options'>, <MenuItemDescription name:'Save As...'>, <MenuItemDescription name:'Save Flattened As...'>, <MenuItemDescription name:'Add Reference'>, <MenuItemDescription name:'Add Payload'>, <MenuItemDescription name:'Exit'>] cannot change delegate
2026-05-26T07:47:59Z [3,801,053ms] [Error] [omni.ui.python] RuntimeError: Accessed invalid expired 'Scope' prim </UR3/UR3/tn__34011STEP_qD/tn__BossExtrude8_VI/Looks>
At:
2026-05-26T07:48:02Z [3,804,097ms] [Warning] [omni.kit.menu.utils.app_menu] add_menu_items: menu [<MenuItemDescription name:'New'>, <MenuItemDescription name:'Open'>, <MenuItemDescription name:'Re-open with New Edit Layer'>, <MenuItemDescription name:'Save'>, <MenuItemDescription name:'Save With Options'>, <MenuItemDescription name:'Save As...'>, <MenuItemDescription name:'Save Flattened As...'>, <MenuItemDescription name:'Add Reference'>, <MenuItemDescription name:'Add Payload'>, <MenuItemDescription name:'Exit'>] cannot change delegate
2026-05-26T07:48:02Z [3,804,412ms] [Warning] [omni.kit.menu.utils.app_menu] add_menu_items: menu [<MenuItemDescription name:'New'>, <MenuItemDescription name:'Open'>, <MenuItemDescription name:'Re-open with New Edit Layer'>, <MenuItemDescription name:'Save'>, <MenuItemDescription name:'Save With Options'>, <MenuItemDescription name:'Save As...'>, <MenuItemDescription name:'Save Flattened As...'>, <MenuItemDescription name:'Add Reference'>, <MenuItemDescription name:'Add Payload'>, <MenuItemDescription name:'Exit'>] cannot change delegate
2026-05-26T07:48:02Z [3,804,543ms] [Error] [omni.ui.python] RuntimeError: Accessed invalid expired 'GeomSubset' prim </UR3/UR3/tn__31600STEP_1_nG/NONE/Mesh/Diffuse_17>
At:
2026-05-26T07:48:05Z [3,807,096ms] [Warning] [omni.kit.menu.utils.app_menu] add_menu_items: menu [<MenuItemDescription name:'New'>, <MenuItemDescription name:'Open'>, <MenuItemDescription name:'Re-open with New Edit Layer'>, <MenuItemDescription name:'Save'>, <MenuItemDescription name:'Save With Options'>, <MenuItemDescription name:'Save As...'>, <MenuItemDescription name:'Save Flattened As...'>, <MenuItemDescription name:'Add Reference'>, <MenuItemDescription name:'Add Payload'>, <MenuItemDescription name:'Exit'>] cannot change delegate
2026-05-26T07:48:05Z [3,807,418ms] [Warning] [omni.kit.menu.utils.app_menu] add_menu_items: menu [<MenuItemDescription name:'New'>, <MenuItemDescription name:'Open'>, <MenuItemDescription name:'Re-open with New Edit Layer'>, <MenuItemDescription name:'Save'>, <MenuItemDescription name:'Save With Options'>, <MenuItemDescription name:'Save As...'>, <MenuItemDescription name:'Save Flattened As...'>, <MenuItemDescription name:'Add Reference'>, <MenuItemDescription name:'Add Payload'>, <MenuItemDescription name:'Exit'>] cannot change delegate
2026-05-26T07:48:05Z [3,807,543ms] [Error] [omni.ui.python] RuntimeError: Accessed invalid expired 'Scope' prim </UR3/UR3/tn__31000STEP_qD/tn__BossExtrude15_jJ/Looks>
At:
2026-05-26T07:48:06Z [3,808,086ms] [Warning] [omni.kit.widget.cache_indicator.utils] No [paths] found in omniverse.toml
2026-05-26T07:48:06Z [3,808,098ms] [Warning] [omni.kit.widget.cache_indicator.utils] No [paths] found in omniverse.toml
2026-05-26T07:48:08Z [3,809,674ms] [Warning] [omni.kit.menu.utils.app_menu] add_menu_items: menu [<MenuItemDescription name:'New'>, <MenuItemDescription name:'Open'>, <MenuItemDescription name:'Re-open with New Edit Layer'>, <MenuItemDescription name:'Save'>, <MenuItemDescription name:'Save With Options'>, <MenuItemDescription name:'Save As...'>, <MenuItemDescription name:'Save Flattened As...'>, <MenuItemDescription name:'Add Reference'>, <MenuItemDescription name:'Add Payload'>, <MenuItemDescription name:'Exit'>] cannot change delegate
2026-05-26T07:48:08Z [3,809,989ms] [Warning] [omni.kit.menu.utils.app_menu] add_menu_items: menu [<MenuItemDescription name:'New'>, <MenuItemDescription name:'Open'>, <MenuItemDescription name:'Re-open with New Edit Layer'>, <MenuItemDescription name:'Save'>, <MenuItemDescription name:'Save With Options'>, <MenuItemDescription name:'Save As...'>, <MenuItemDescription name:'Save Flattened As...'>, <MenuItemDescription name:'Add Reference'>, <MenuItemDescription name:'Add Payload'>, <MenuItemDescription name:'Exit'>] cannot change delegate
no reference mesh found for Base_Link, keeping the link at its original position
no reference mesh found for Link1, keeping the link at its original position
no reference mesh found for Link2, keeping the link at its original position
no reference mesh found for Link3, keeping the link at its original position
no reference mesh found for Link4, keeping the link at its original position
no reference mesh found for Link5, keeping the link at its original position
no reference mesh found for Link6, keeping the link at its original position
2026-05-26T07:48:08Z [3,810,330ms] [Warning] [omni.kit.menu.utils.app_menu] add_menu_items: menu [<MenuItemDescription name:'New'>, <MenuItemDescription name:'Open'>, <MenuItemDescription name:'Re-open with New Edit Layer'>, <MenuItemDescription name:'Save'>, <MenuItemDescription name:'Save With Options'>, <MenuItemDescription name:'Save As...'>, <MenuItemDescription name:'Save Flattened As...'>, <MenuItemDescription name:'Add Reference'>, <MenuItemDescription name:'Add Payload'>, <MenuItemDescription name:'Exit'>] cannot change delegate
2026-05-26T07:48:30Z [3,831,732ms] [Warning] [omni.kit.widget.cache_indicator.utils] No [paths] found in omniverse.toml
2026-05-26T07:48:53Z [3,855,487ms] [Warning] [omni.kit.widget.cache_indicator.utils] No [paths] found in omniverse.toml
2026-05-26T07:53:51Z [4,153,285ms] [Warning] [omni.usd] Warning: in SdfPath at line 144 of /builds/omniverse/usd-ci/USD/pxr/usd/sdf/path.cpp -- Ill-formed SdfPath <>: :1:0(0): parse error matching pxrInternal_v0_24__pxrReserved__::Sdf_PathParser::Path
2026-05-26T07:53:51Z [4,153,286ms] [Warning] [omni.usd] Warning: in SdfPath at line 144 of /builds/omniverse/usd-ci/USD/pxr/usd/sdf/path.cpp -- Ill-formed SdfPath <>: :1:0(0): parse error matching pxrInternal_v0_24__pxrReserved__::Sdf_PathParser::Path
2026-05-26T07:53:51Z [4,153,287ms] [Warning] [omni.usd] Warning: in SdfPath at line 144 of /builds/omniverse/usd-ci/USD/pxr/usd/sdf/path.cpp -- Ill-formed SdfPath <>: :1:0(0): parse error matching pxrInternal_v0_24__pxrReserved__::Sdf_PathParser::Path
2026-05-26T07:53:51Z [4,153,288ms] [Warning] [omni.usd] Warning: in SdfPath at line 144 of /builds/omniverse/usd-ci/USD/pxr/usd/sdf/path.cpp -- Ill-formed SdfPath <>: :1:0(0): parse error matching pxrInternal_v0_24__pxrReserved__::Sdf_PathParser::Path
2026-05-26T07:53:51Z [4,153,289ms] [Warning] [omni.usd] Warning: in SdfPath at line 144 of /builds/omniverse/usd-ci/USD/pxr/usd/sdf/path.cpp -- Ill-formed SdfPath <>: :1:0(0): parse error matching pxrInternal_v0_24__pxrReserved__::Sdf_PathParser::Path
2026-05-26T07:53:51Z [4,153,290ms] [Warning] [omni.usd] Warning: in SdfPath at line 144 of /builds/omniverse/usd-ci/USD/pxr/usd/sdf/path.cpp -- Ill-formed SdfPath <>: :1:0(0): parse error matching pxrInternal_v0_24__pxrReserved__::Sdf_PathParser::Path
2026-05-26T07:53:51Z [4,153,291ms] [Warning] [omni.usd] Warning: in SdfPath at line 144 of /builds/omniverse/usd-ci/USD/pxr/usd/sdf/path.cpp -- Ill-formed SdfPath <>: :1:0(0): parse error matching pxrInternal_v0_24__pxrReserved__::Sdf_PathParser::Path
2026-05-26T07:53:51Z [4,153,292ms] [Warning] [omni.usd] Warning: in SdfPath at line 144 of /builds/omniverse/usd-ci/USD/pxr/usd/sdf/path.cpp -- Ill-formed SdfPath <>: :1:0(0): parse error matching pxrInternal_v0_24__pxrReserved__::Sdf_PathParser::Path
2026-05-26T07:53:51Z [4,153,296ms] [Warning] [omni.usd] Warning: in SdfPath at line 144 of /builds/omniverse/usd-ci/USD/pxr/usd/sdf/path.cpp -- Ill-formed SdfPath <>: :1:0(0): parse error matching pxrInternal_v0_24__pxrReserved__::Sdf_PathParser::Path
2026-05-26T07:53:51Z [4,153,509ms] [Warning] [omni.kit.menu.utils.app_menu] add_menu_items: menu [<MenuItemDescription name:'New'>, <MenuItemDescription name:'Open'>, <MenuItemDescription name:'Re-open with New Edit Layer'>, <MenuItemDescription name:'Save'>, <MenuItemDescription name:'Save With Options'>, <MenuItemDescription name:'Save As...'>, <MenuItemDescription name:'Save Flattened As...'>, <MenuItemDescription name:'Add Reference'>, <MenuItemDescription name:'Add Payload'>, <MenuItemDescription name:'Exit'>] cannot change delegate
2026-05-26T07:53:52Z [4,153,632ms] [Warning] [omni.usd] Warning: in _ReportErrors at line 3172 of /builds/omniverse/usd-ci/USD/pxr/usd/usd/stage.cpp -- Could not load sublayer @UR3_configed_robot.usd@ of layer @/home/tk/Downloads/ur3step/usd/configurations/UR3_configed_physics.usd@; skipping. (Recomposing stage on stage @/home/tk/Downloads/ur3step/usd/configurations/UR3_configed_physics.usd@ <0x63b719c89d90>)
2026-05-26T07:53:52Z [4,153,646ms] [Warning] [omni.usd] Warning: in _ReportErrors at line 3172 of /builds/omniverse/usd-ci/USD/pxr/usd/usd/stage.cpp -- In </UR3_configed>: Could not open asset @configurations/UR3_configed_base.usd@ for payload introduced by @anon:0x63b7239edb50:tmp.usda@</UR3_configed{Physics=None}>. (recomposing stage on stage @anon:0x63b7239edb50:tmp.usda@ <0x63b72b70ebb0>)
2026-05-26T07:53:52Z [4,153,646ms] [Warning] [omni.usd] Warning: in _ReportErrors at line 3172 of /builds/omniverse/usd-ci/USD/pxr/usd/usd/stage.cpp -- In </UR3_configed>: Could not open asset @configurations/UR3_configed_physics.usd@ for payload introduced by @anon:0x63b7239edb50:tmp.usda@</UR3_configed{Physics=PhysX}>. (recomposing stage on stage @anon:0x63b7239edb50:tmp.usda@ <0x63b72b70ebb0>)
2026-05-26T07:53:52Z [4,153,647ms] [Warning] [omni.usd] Warning: in _ReportErrors at line 3172 of /builds/omniverse/usd-ci/USD/pxr/usd/usd/stage.cpp -- In </UR3_configed>: Could not open asset @configurations/UR3_configed_robot.usd@ for payload introduced by @anon:0x63b7239edb50:tmp.usda@</UR3_configed{Physics=Robot}>. (recomposing stage on stage @anon:0x63b7239edb50:tmp.usda@ <0x63b72b70ebb0>)
2026-05-26T07:53:52Z [4,153,852ms] [Warning] [omni.kit.menu.utils.app_menu] add_menu_items: menu [<MenuItemDescription name:'New'>, <MenuItemDescription name:'Open'>, <MenuItemDescription name:'Re-open with New Edit Layer'>, <MenuItemDescription name:'Save'>, <MenuItemDescription name:'Save With Options'>, <MenuItemDescription name:'Save As...'>, <MenuItemDescription name:'Save Flattened As...'>, <MenuItemDescription name:'Add Reference'>, <MenuItemDescription name:'Add Payload'>, <MenuItemDescription name:'Exit'>] cannot change delegate
2026-05-26T07:53:52Z [4,153,916ms] [Warning] [omni.usd] Warning: in _ReportErrors at line 3172 of /builds/omniverse/usd-ci/USD/pxr/usd/usd/stage.cpp -- Sublayer hierarchy with root layer @/home/tk/Downloads/ur3step/usd/configurations/UR3_configed_robot.usd@ has cycles. Detected when layer @/home/tk/Downloads/ur3step/usd/configurations/UR3_configed_robot.usd@ was seen in the layer stack for the second time. (instantiating stage on stage @/home/tk/Downloads/ur3step/usd/UR3_configed.usd@ <0x63b726000cc0>)
2026-05-26T07:53:52Z [4,153,996ms] [Error] [omni.kit.window.property.templates.simple_property_widget] Exception when async '<function SimplePropertyWidget._delayed_rebuild at 0x7597df5c3600>'
2026-05-26T07:53:52Z [4,153,996ms] [Error] [omni.kit.window.property.templates.simple_property_widget] Python argument types in
Stage.GetPrimAtPath(Stage, Path)
did not match C++ signature:
GetPrimAtPath(pxrInternal_v0_24__pxrReserved__::UsdStage {lvalue}, pxrInternal_v0_24__pxrReserved__::SdfPath path)
2026-05-26T07:53:52Z [4,153,996ms] [Error] [omni.kit.window.property.templates.simple_property_widget] Traceback (most recent call last):
File "/home/tk/isaacsim/extscache/omni.kit.window.property-1.12.1+8131b85d/omni/kit/window/property/templates/simple_property_widget.py", line 79, in wrapper
return await func(*args, **kwargs)
File "/home/tk/isaacsim/extscache/omni.kit.window.property-1.12.1+8131b85d/omni/kit/window/property/templates/simple_property_widget.py", line 374, in _delayed_rebuild
self._build_frame()
File "/home/tk/isaacsim/extscache/omni.kit.window.property-1.12.1+8131b85d/omni/kit/window/property/templates/simple_property_widget.py", line 357, in _build_frame
self.build_items()
File "/home/tk/isaacsim/extscache/omni.kit.property.geometry-2.0.4+8131b85d/omni/kit/property/geometry/scripts/prim_kind_widget.py", line 71, in build_items
prim = stage.GetPrimAtPath(path)
Boost.Python.ArgumentError: Python argument types in
I ignored these errors and continued with steps 5 and 6 until the robot wizard was completed. The resulting robot model is shown in the figure.
The joints are at the same point.In robot hierarchy, the visual scope and collider scope have nothing.
My STEP file is below.
ur3step.zip (3.1 MB)
Are there any step-by-step tutorials on importing a robot from a STEP file and configuring the robot using the robot wizard?
