Hi. I have a Mellanox ConnectX-5 with OFED 5.4 on Ubuntu 18.04 LTS . I want to parse some RoCEv2 packets with a custom program. So I need the ConnectX-5 not to capture RoCEv2 packets. I’ve followed the article How to Disable RoCE to disable the RoCE. If I get it right, now the RoCEv2 packets should be passed to kernel. But it seems the RoCE is still enabled:
- ib_send_bw is still working. I used the GID 3 that corresponds to RoCEv2.
- hping3 UDP test fails.
$ hping3 –udp -p 4791
No responding. This command will send some UDP packets to the port on the target host. If I use another port, the target will return an ICMP Unreachable which means the kernel receives the UDP packet. But sending UDP to port 4791 (the port RoCEv2 uses) gets no response so I assume the RoCEv2 is still enabled and the NIC drops the “malformed RoCEv2 packet”.
Besides, I tried to remove the kernel module mlx5_ib to completely shutdown the functionality and it worked. But my program is actually a DPDK program that needs the mlx5_ib module, so this is not the solution.
How can I gently disable the RoCEv2 and let the kernel gets the packets?
I’m sorry if I misunderstand something. Thanks for your advice.
Below are some info:
$ ibv_devinfo
hca_id: mlx5_0
transport: InfiniBand (0)
fw_ver: 16.31.1014
node_guid: ec0d:9a03:00bf:d92c
sys_image_guid: ec0d:9a03:00bf:d92c
vendor_id: 0x02c9
vendor_part_id: 4119
hw_ver: 0x0
board_id: MT_0000000012
phys_port_cnt: 1
port: 1
state: PORT_ACTIVE (4)
max_mtu: 4096 (5)
active_mtu: 1024 (3)
sm_lid: 0
port_lid: 0
port_lmc: 0x00
link_layer: Ethernet
hca_id: mlx5_1
fw_ver: 16.31.1014
node_guid: ec0d:9a03:00bf:d92d
vendor_id: 0x02c9
hw_ver: 0x0
phys_port_cnt: 1
port: 1
max_mtu: 4096 (5)
sm_lid: 0
port_lid: 0
port_lmc: 0x00
$ lspci | grep Mellanox
82:00.0 Ethernet controller: Mellanox Technologies MT27800 Family [ConnectX-5]
82:00.1 Ethernet controller: Mellanox Technologies MT27800 Family [ConnectX-5]
$ cat /sys/bus/pci/devices/0000:82:00.*/roce_enable
0
0
$ cat /sys/class/infiniband/mlx5_*/ports/1/gid_attrs/types/3
RoCE v2
RoCE v2
