I’d be happy to help you with your questions about ROI (Region of Interest) encoding on the Jetson AGX Orin.
1. How many ROIs can be defined?
The Jetson AGX Orin supports up to 16 virtual channels with ISP (Image Signal Processor) or 24 virtual channels without ISP. Each virtual channel can be configured to have its own ROI settings. However, the actual number of ROIs that can be defined depends on the specific use case and the available resources on the device.
In general, the Jetson AGX Orin can support multiple ROIs per virtual channel, but the exact number may vary depending on the resolution, frame rate, and other factors. For example, if you’re using a high-resolution camera with a high frame rate, you may be able to define fewer ROIs compared to a lower-resolution camera with a lower frame rate.
2. How to enable ROI encoding?
To enable ROI encoding on the Jetson AGX Orin, you’ll need to use the NVIDIA Video Encoder (NVE) API, which provides a set of APIs for encoding video streams. Specifically, you’ll need to use the NvVideoEncoder API to create an encoder instance and configure it to use ROI encoding.
Here’s a high-level overview of the steps involved:
- Create an
NvVideoEncoder instance using the NvVideoEncoder::create() function.
- Configure the encoder instance to use ROI encoding by setting the
roi_enabled property to true.
- Define the ROI parameters using the
NvVideoEncoder::set_roi() function.
- Start the encoding process using the
NvVideoEncoder::encode() function.
3. How to specify ROI parameters?
To specify ROI parameters, you’ll need to use the NvVideoEncoder::set_roi() function, which takes a NvRoi struct as an argument. The NvRoi struct contains the following fields:
x: The x-coordinate of the top-left corner of the ROI.
y: The y-coordinate of the top-left corner of the ROI.
width: The width of the ROI.
height: The height of the ROI.
You can specify multiple ROIs by creating an array of NvRoi structs and passing it to the NvVideoEncoder::set_roi() function.
4. Is there a C sample code of ROI encoding available?
Yes, NVIDIA provides a sample code for ROI encoding on the Jetson AGX Orin, which is part of the NVIDIA Video Encoder (NVE) API. You can find the sample code in the samples directory of the NVE API package.
Here’s an example code snippet that demonstrates how to enable ROI encoding using the NVE API:
#include <nvvideoencoder.h>
int main() {
// Create an NvVideoEncoder instance
NvVideoEncoder *encoder = NvVideoEncoder::create();
// Configure the encoder to use ROI encoding
encoder->set_roi_enabled(true);
// Define the ROI parameters
NvRoi roi;
roi.x = 100;
roi.y = 100;
roi.width = 200;
roi.height = 200;
// Set the ROI parameters
encoder->set_roi(&roi);
// Start the encoding process
encoder->encode();
return 0;
Note that this is just a simplified example code snippet, and you may need to modify it to suit your specific use case.
I hope this helps! Let me know if you have any further questions.
