We flashed the Jetson Linux 35.1 image from sdk manager into our carrier board + P3668-0001 NX SOM (EMMC SKU). We used the NVP Model clock configuration tool for set the power mode to “20W-6 Core” and did the reboot stress test for testing system stabiblity. The main differnece between our carrier board and devkit is that carrier board has USB LAN (rt8152) and LTE module (Quectel EG25) . We meet a problem is “Root device was not found and cause system hang”. Please help to check this. Thanks
Normal log
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[ 6.882553] mmcblk0: mmc0:0001 DG4016 14.7 GiB
[ 6.883162] mmcblk0rpmb: mmc0:0001 DG4016 partition 3 4.00 MiB, chardev (510:0)
[ 6.967665] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19
[ 7.370115] Root device found: mmcblk0p1
[ 7.376803] Found dev node: /dev/mmcblk0p1
[ 7.411764] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 7.415730] Rootfs mounted over mmcblk0p1
[ 8.488298] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
Fail log:
[ 6.825295] mmcblk0: mmc0:0001 DG4016 14.7 GiB
[ 6.825423] mmcblk0rpmb: mmc0:0001 DG4016 partition 3 4.00 MiB, chardev (510:0)
[ 6.829299] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19
jetpack502-mount emmc fail.log (1.8 MB)
